Old 07-25-2012, 06:10 PM   #1
cgrey
Drives: 2013 Argento Silver FR-S
Hot fuse tap - Which fuse?
Anyone know, offhand, if any of the fuses are constant on with ignition off?
I need to tap for a powerbox/camera.
cgrey is offline   Reply With Quote
Old 07-25-2012, 06:45 PM   #2
FRSPirate
FRSPirate's Avatar
Drives: 13 Scion FRS Raven M/T, 05 Raven R6
There are some unused open terminals in there (cabin fuse box) that are constant hot. I remember running into them when i was wiring the remote line for my sub. Other than telling you to use multimeter or test light to figure it out, i have no idea offhand which are constant. If you do not have a test light, you could always make one with a spare 194 bulb, some wire and a couple alligator clips.
-Alex
05 Raven R6
13 Raven FRS M/T
FRSPirate is offline   Reply With Quote
Old 07-26-2012, 12:05 AM   #3
cgrey
Yeah, I'll have to bust out the multimeter and play with it. I expected the fusebox to be more easily accessible...and bigger.
Otherwise I'll try to find a wire to tap. Possibly the clock, or the dome light. Must be an always on power somewhere convenient.
Old 07-26-2012, 08:06 AM   #4
xjohnx
Grip>Slip
xjohnx's Avatar
Please document your findings, if you can. Pics would be helpful.
Old 07-26-2012, 08:56 AM   #5
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
I think the only always hot lead in the drivers area is going to be the dome light.
Lee358 is offline   Reply With Quote
Old 08-25-2012, 11:27 PM   #6
cgrey
Update: Looking for a hot fuse in the Scion FR-S or Subaru BRZ to wire an electronic device.
The STOP fuse, 7.5A, fourth from the top of the left column. Brake light circuit, it's hot.
For switched power plenty of options but I recommend the DRL circuit.
FYI Subaru uses short mini fuses, they're like mini fuses with cut blades and a slot in the middle. The box will accept normal mini fuses but you can't use a tap-a-fuse and still close the cover, not that the cover is very important.
Behind the plastic panel housing the hood release is plenty of space to hide excess wires or connectors.
Old 08-26-2012, 04:42 AM   #7
cgrey
Someone posted this image:
Old 08-20-2015, 09:27 AM   #8
pepe
Drives: gt86
I need to know a constant 12v and 12v fuse and the fuse only when ignition key is operational. I want to install Gauges.
Thank you!
pepe is offline   Reply With Quote
Old 09-17-2016, 02:06 PM   #9
Ahbrz
Drives: Brz
great info, thanks! i am just about to install my ls370 with hard wire kit, but was wondering which fuse is hot since i don't see dome fuse by itself.
Ahbrz is offline   Reply With Quote
Old 09-17-2016, 07:24 PM   #10
QHawk
QHawk's Avatar
Drives: 2020 86GT
That's one, but the options connector (in the dash behind the HU) has another.
QHawk is offline   Reply With Quote
