| Software Tuning Discuss all software tuning topics. |
Drives: 2013 FRS GTX3076R
Ethanol blend
Hi guys,
Just read Shiv's post regarding e85 and how if we are N/A there isn't a necessity for e85 since our dynamic compression when N/A can't take full advantage of full e85, and ideally all we need is e40. So my question is has anyone run e40 on the oft STG 2+ e85 maps? If so what was your experience in terms fuel economy, fuel trims, performance, cold starts etc...? Also if e40 isn't an ideal blend, what blend would you recommend? I have a catless header. The post I'm referring to https://r.tapatalk.com/shareLink/top...ink_source=app Thanks Sent from my SM-G950W using Tapatalk Last edited by yzf219; 11-13-2020 at 06:07 AM. |
#2 |
Wheels for Brains
Try not to run anything other than e85 on an e85 map. The engine is expecting e85, and will run rich unless the engine fuel trim can cover for it.
A few % off of 85 would probably be just fine, but I don't know enough about the engine to say that it can adjust for e40 If you care about running e40, blend it yourself an get a flex fuel kit. |
| The Following User Says Thank You to EndlessAzure For This Useful Post: | yzf219 (11-14-2020) |
#3 | |
30 minute maintenance
Drives: My18 wrxsti
#4 | |
Sent from my SM-G950W using Tapatalk |
#5 |
Drives: My18 wrxsti
Cheers I remember it now.Good e85 is 105ron and runs 14:1 comp safely. 93ron runs 10.5:1 comp safely. Obviously with modern ecu`s you can push safety limits further. The fa20 is 12.5:1 so it would fall in between.
Nothing like having a nice anti knock safety margin with your fuel. For 2hp loss why run crappy fuel. !`m possibly a bit spoiled with our e85 its exxy but always e80+. |
| The Following User Says Thank You to gen3v8 For This Useful Post: | yzf219 (11-13-2020) |
#6 |
Our Cars love E85. If you can do 1 mod and have reliable e85, Tune+Flex Fuel is all I would do+ Axleback for sound.
2013 Series 10 FRS #553
#7 |
#8 | |
| Does summer e85 have higher ethanol content than winter blend? | Steveiam | Engine, Exhaust, Transmission | 15 | 05-24-2020 01:59 PM |
| F@@ck!! Good body shops to blend swp in Gta? | Muskokan | CANADA | 21 | 06-17-2015 05:29 PM |
| How much latitute in stock ecu for low blend E85 flexfuel? | Trettiosjuan | Software Tuning | 17 | 07-03-2014 05:42 AM |
| synthetic blend on first oil change | jp_r6 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 9 | 01-21-2014 11:55 AM |
