Old 11-08-2020, 07:28 AM   #22527
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
Originally Posted by JesseG View Post
What are these steering wheels and how expensive??! They look awesome. I really like the stock Lotus type steering wheel, but mine feels a little slick, the PO really rubbed it a lot apparently.
Alcantara wheel made by Prova.
I bought mine used locally. Their site and most retailers indicate they're discontinued, but Japan Parts still has it on their site, so maybe they have some left? They're definitely kinda pricey when new...
https://www.japanparts.com/parts/detail/43185
Old 11-08-2020, 10:21 AM   #22528
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
Put on the OEM mudflap kit and some Drambeenie risers. I like how the latter look, but I don't think I got the fit quite right or something.
Cephas is offline   Reply With Quote
Old 11-08-2020, 12:03 PM   #22529
arxm
Drives: 2013 FR-S, 2023 BRZ
Originally Posted by Cephas View Post
Yeah, the stock stuff for SURE didn't like to be cold. I've used Redline MTL before and it was quite good in the cold, but the MT-90 is only so-so. Still takes some persuading to go into 1st and 2nd for the first few miles. Then it's quite nice, though. Hardly something to keep me up at night at this point, but we'll see how it does when we get a real cold snap in a month or so.
i mean ive driven with the motul at -35c it isnt much worse than at freezing
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
Old 11-08-2020, 03:18 PM   #22530
jflogerzi
jflogerzi's Avatar
Not gonna do much cruising with 20 gallons! Keep in mind you will use up to a possible 30% more of it to go the same distance.
he is using a blend is my guess. I normally use 5-6 gals per fill up of e85 to keep and e45-55 range.
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
Tcoat (11-08-2020)
Old 11-08-2020, 04:03 PM   #22531
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Installed my VEMS wideband gauge! I pinned the connector after routing it along the firewall for a clean install.
The gauge has a separate input for EGT, boost, boost control, etc. I may try to configure it for oil pressure, we'll see.
MJones_RB (11-09-2020)
Old 11-08-2020, 07:42 PM   #22532
Phdpsy
Drives: 2015 FR-S
True, but so worth it. Not a daily, so it is easy to prioritize fun drives in it vs. using it to just get from point A to B. Don’t get me wrong, 93 is great fun in this car as well. In fact, can’t think of a time I did not enjoy driving it.
2015 AVO Turbo FR-S
New to the FR-S, long time car enthusiast
Phdpsy is offline   Reply With Quote
The Following User Says Thank You to Phdpsy For This Useful Post:
Tcoat (11-08-2020)
Old 11-09-2020, 12:17 AM   #22533
jflogerzi
jflogerzi's Avatar
Order some goodies:
Whiteline Transmission Mount Bushing Insert and Perrin Support insert combo
Mtec Spring kit
OE 2017 rear sway bar
Pedders Offset camber/caster top hats
Can't wait to get all these installed.
Old 11-09-2020, 01:57 AM   #22534
q335r49
Drives: 2013 scion fr-s
Finished some various minor interior stuff I've been putting off for a long time. Made a bracket to mount a fire extinguisher and the passenger seat occupancy sensor (so I don't get an airbag light with the passenger seat removed); sewed together a transmission tunnel cover out of car carpet
q335r49 is offline   Reply With Quote
The Following 2 Users Say Thank You to q335r49 For This Useful Post:
bcj (11-14-2020), jflogerzi (11-10-2020)
Old 11-12-2020, 07:58 PM   #22535
BigHugeFatGuy
BigHugeFatGuy's Avatar
Drives: 2016 FRS
OLM spats.
Spent 2 hours fighting with the MFing fender liner and junk. Then read on here that a guy took a 3/8 drill bit and made his own holes, used the car's hardware and threw away the included junk. Done in 5 minutes.
BigHugeFatGuy is offline   Reply With Quote
The Following 3 Users Say Thank You to BigHugeFatGuy For This Useful Post:
humfrz (11-13-2020), RToyo86 (11-13-2020), Tcoat (11-13-2020)
Old 11-13-2020, 01:06 PM   #22536
Originally Posted by BigHugeFatGuy View Post
OLM spats.
Ahhhhh ........ YES, the Bubba method -
Old 11-13-2020, 01:24 PM   #22537
StraightOuttaCanadaEh
Wes
Installed one of these DSS alu driveshafts. Got it used locally for a good price and thought why not. This is the only pic I have of the thing
Also while I was at the mechanic, they told me I mounted two of my wheels the wrong way. Didn't realize they were directional. That explains the weird handling which is now completely resolved. Embarrassing
Instagram: @gt86ws
The Following 4 Users Say Thank You to StraightOuttaCanadaEh For This Useful Post:
DarkPira7e (11-13-2020), FLIPDADY (11-13-2020), MJones_RB (11-13-2020), new2subaru (11-13-2020)
Old 11-13-2020, 07:21 PM   #22538
DarkPira7e
DarkPira7e's Avatar
Damn, your trunk is clean. Post a review of the driveshaft!
Old 11-13-2020, 09:54 PM   #22539
don't do that no more -
Old 11-13-2020, 10:00 PM   #22540
Wes
yessir
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
humfrz (11-13-2020)
