Old 11-08-2020, 05:52 PM   #11033
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
mine stopped too, but I think my batteries finally died (dual pack: original batteries 2014). I still get the vacuum assist kick when engine is under heavy load but phantom not engaged, then as soon as i trigger the switch, the motor spins up and the voltage drops, and the turbine stops within 1/2 a second, the voltage goes back up and shows good again. I wonder if the auto parts store will check the batteries for me and see if I still have 2 good ones.
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
Old 11-08-2020, 06:05 PM   #11034
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
If you need my snail, then i can part it out
Sent from my SM-N986U using Tapatalk
Old 11-09-2020, 07:38 AM   #11035
WNDSRFR
Drives: FR-S,GTI
If your batteries are 6 years old, then I can pretty much guarantee you that your batteries are dead. I replace mine about every two years. Is your starter battery 6 years old too?
Old 11-09-2020, 06:12 PM   #11036
Target70
Target70's Avatar
I relocated my starter battery (original factory) to the trunk when I installed the Phantom. It died/was replaced on 07/2017 with an AGM. I doubled up on the power-sonics with a dual dump, and I think that made them last much longer by halving the workload.
I'm not sure what to replace them with. I know there was a newer battery replacement option for the power-sonics, but not sure what it was. I also wonder if anyone has worked out a capacitor/super cap setup that would work to buffer battery output. I would think it would maximize initial peak current plus help the dump pack last longer.
Old 11-10-2020, 07:36 AM   #11037
WNDSRFR
Drives: FR-S,GTI
The newer battery replacement uses a different tray. The advantage of the newer batteries is the terminal is alot more user friendly than the originals. But the PowerSonic's are alot cheaper. Just use extreme care when attaching the terminals. If you touch anything with the wrench attaching the positive terminal you'll cause an arc you won't believe.
I know. Done it a couple times. Lucky I haven't blown anything up. Yet.
Old 11-10-2020, 10:59 PM   #11038
Target70
Target70's Avatar
just pulled the dump packs out, no surprise one of the buss bars was covered in corrosion and one of the cables as well.
found Fenton's post on page 1 listing this as the upgrade battery: http://www.batterymart.com/p-Big-Cra...6-Battery.html
I read that Big Crank is the exact same battery as Deka with different label. The cheapest I found was $88 per for the Deka EXT16, but the EXT16L with the same stats (assuming the L swaps positive location) is only $80 or 2 for $160, with a weight of 32lbs: https://www.amazon.com/Deka-Power-Sp.../dp/B0007Z2XBM
vs $142 for 4 power sonics at 48 lbs: https://www.amazon.com/Powersonic-PS.../dp/B0002ILJZU
Does anyone have any lifespan comparisons? or am I just being too picky?
Old 11-13-2020, 03:28 PM   #11039
zc06_kisstherain
Drives: SWP BRZ
if you were close to NJ, i could sell mine
Old 11-19-2020, 07:35 AM   #11040
zc06_kisstherain
Drives: SWP BRZ
any update on someone developing controller or repair?
Old 11-23-2020, 07:10 PM   #11041
zc06_kisstherain
Drives: SWP BRZ
I ordered new switch to test it out if switch is the problem or not. i will update once i get new switch. hopefully its switch..haha
Old 11-23-2020, 07:11 PM   #11042
BlOody_BoOger
BlOody_BoOger's Avatar
Drives: Hot lava FRS Monogram Charizard
Nice! This guy I fallow on insta just got his torqamp it'll be awesome to see his results once they come in
Sent from my IN2017 using Tapatalk
BlOody_BoOger is offline   Reply With Quote
Old 11-23-2020, 07:13 PM   #11043
zc06_kisstherain
Drives: SWP BRZ
I just want my kit to work again..
Old 11-28-2020, 05:19 PM   #11044
zc06_kisstherain
Drives: SWP BRZ
ok. new switch came and I just finished wiring up to new switch. I will test the kit tomorrow and see if switch was the problem or not. wish GL
Old 11-29-2020, 10:20 AM   #11045
zc06_kisstherain
Drives: SWP BRZ
I just tested new switch and it's not switch so it did not work >.<
voltage shows battery level correctly and i hear controller working but it just doesnt activate when applying switch.
I am pretty much done since i have no resource to repair.
if anyone interested, i will let whole things go with $500 plus shipping (if you're local, i will also provide battery cheap as well)
Thanks
Old 12-01-2020, 09:40 AM   #11046
BlOody_BoOger
@geraldjust don't know if you guys have seen the channel before. But this guy is coming up with his own E Charger using TP power motors and a vortech turbo housing. Rather than our 24v system he's pushing 48v lots of great information.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
