Old 04-02-2020, 04:17 PM   #1
kimcheefists
kimcheefists's Avatar
Drives: 2017 BRZ PP
Low Oil Pressure?
Hey guys,
I’m not entirely sure if I have a problem here but I am a little concerned...basically my engine’s oil pressure doesn’t seem to increase past 40psi after full warm up. I know the general rule of thumb is at least 10psi per 1000rpm but at 5k rpm and above, the oil pressure doesn’t go past 40psi.
I initially thought I spun another bearing but my idle oil pressure is at ~10psi with no oil light at all.
I just changed the oil to Motul 0w-30 from straight 30wt (Lucas Break-in Oil). Do you think it has to do with changing oil viscosity or do you think have another engine problem....?
Screenshots from the video I recorded are attached.
kimcheefists is offline   Reply With Quote
Old 04-02-2020, 04:27 PM   #2
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
That's definitely low, but your idle pressure seems fine.
Where is your gauge getting the oil pressure? if it's not at the below location it might read different:
Old 04-02-2020, 04:32 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
What temperature are you checking oil pressure at?
What mods on the car?
Old 04-02-2020, 04:41 PM   #4
kimcheefists
Drives: 2017 BRZ PP
The gauge is reading from the port right next to the A/C compressor. Car has a JDL Turbo Kit and JR Dual Radiator/Oil Cooler. The pictures I uploaded also shows oil temp. It’s the middle bar on the gauge cluster. I think it’s around 212-225F..
Old 04-02-2020, 05:03 PM   #5
Yoshoobaroo
TRACKBREAD
Might be worth to plug the gauge into the oem pressure switch spot and check the pressure again.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
DarkPira7e (04-02-2020)
Old 04-02-2020, 06:19 PM   #6
kimcheefists
Drives: 2017 BRZ PP
So if I change the pressure reference point and see an increase, should I still be worried?
I was under the impression that the pressure port by the A/C compressor gives more accurate readings since it’s basically the same oil journal as the main/rod journals...
Old 04-03-2020, 03:19 PM   #7
Grady
Grady's Avatar
No.
Do you have a restrictor on your turbo feed?
Old 04-03-2020, 03:29 PM   #8
Yoshoobaroo
TRACKBREAD
it may be more accurate wit respect to the actual oil pressure on the journals, but we don't have Subaru supplied reference data for that port. 40psi could be normal for that port, who knows?
I'd check the pressure switch port against Subaru's literature, then start worrying if it's low. Also make sure you test standing still and in neutral, so your turbo doesn't suck down a ton of pressure cause it's under load.
Last edited by Yoshoobaroo; 04-03-2020 at 03:31 PM. Reason: can't type to save my life
NoHaveMSG (04-03-2020)
Old 11-10-2020, 07:26 PM   #9
michaelxchristopher
michaelxchristopher's Avatar
Drives: 2016 Scion FR-S | Hot Lava
Any update?? I spun a rod bearing last year. Had a block built by GCH longblock racing, installed sbd turbo kit that failed. They linked it to low oil pressure so upon installing an oil pressure gauge we have the same issue as you. Low idle pressure around 4-8psi and it won't go above 30psi at any rpm range.
2016 Scion FR-S | Motoeast E85 tuned | Magnaflow Exhaust | MXP Performance 4-1 Header | Skunk2Racing Intake | Cusco Street Zero A | Front & rear strut bars | Seibon Carbon DV hood | Enkei RPF1s 17x9 +35 | Ventus Autoworks v2 splitter & diffuser | JDM OEM grille | Winjet Headlights | Helix Tribar tail lights | JDM OEM interior
michaelxchristopher is offline   Reply With Quote
Old 11-10-2020, 07:31 PM   #10
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Have you dropped the oil pan and checked your oil pickup? Someone putting something together also means that someone could've made a sealant mistake and now it's clogging your oil pickup
Tcoat (11-12-2020)
Old 07-17-2023, 03:37 AM   #11
fableluke
Drives: BLue 2013 frs
Necro. This sounds like my issue. Did you ever figure our your issue?
I have pulled my oil pan and looked at my pickup, there was some stuff but i doubt it would make this much of an issue.
fableluke is offline   Reply With Quote
Oil Pressure drz400dude Engine, Exhaust, Transmission 9 04-30-2019 10:32 PM
oil pressure Legend@wheels Engine, Exhaust, Transmission 23 12-25-2018 11:45 AM
best tire pressure gauge (tire pressure question) steveholt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 03-21-2015 10:27 PM
Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate PineappleFriedRice Transmission and Driveline 0 11-08-2013 04:54 PM
Oil Pressure.. too low? Dave-ROR Tracking / Autocross / HPDE / Drifting 65 08-24-2013 12:43 AM
