Old 11-10-2020, 03:36 PM   #1
Rocketman
Drives: 2013 Blue FR-S
Excessive torque steer - differential?
My car seems to have developed excessive torque steer. Moderately aggressive acceleration kicks the rear end to the left (car goes right). Letting off the gas during cruising causes the rear end to go right. Engine is stock. Car is lowered with TRD springs and sway bars and gets a lot of track time.
Could this be a differential issue? Going to change the diff oil to Motul 300LS to see if that helps. (Now using the regular Motul 300.)
Rocketman is offline   Reply With Quote
Old 11-10-2020, 03:44 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
What tires are you running? How much air in them? How is your suspension? What size tires? How is your alignment? Diff is probably the least suspicious thing until you've ruled out most everything else.
I get this issue with my winter tires every year
Tcoat (11-10-2020)
Old 11-10-2020, 03:58 PM   #3
Have you driven it in the cooler weather before?
DarkPira7e (11-10-2020)
Old 11-10-2020, 04:19 PM   #4
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
This is my first season dealing with the skating on the road feel. New rubber isn't as competent
I'm hoping they will feel better when temps drop below freezing.
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
DarkPira7e (11-10-2020), Tcoat (11-10-2020)
Old 11-10-2020, 05:32 PM   #5
ZDan
ZDan's Avatar
Drives: '23 BRZ
Check tire pressures. All good, same problem? Swap rear tires left/right and see if the problem persists but in opposite directions. If so, bad tire....
The Following 2 Users Say Thank You to ZDan For This Useful Post:
smackrel (05-23-2025), Tcoat (11-10-2020)
Old 11-10-2020, 05:36 PM   #6
Rocketman
Hankook RS4 225/45 17@ 36psi. No recent alignment. I have driven the car under most every condition but this problem only crept up recently. No relation to temperature, although (not surprisingly) wet roads exacerbate the condition. The tires are a coupe years old maybe not as soft as new. The funny thing is that I don't notice it on the track except for accelerating out of the pits.
The Following User Says Thank You to Rocketman For This Useful Post:
Tcoat (11-10-2020)
Old 11-10-2020, 05:59 PM   #7
WNDSRFR
Drives: FR-S,GTI
Torque steer?
What do you mean? Torque steer is usually associated with front wheel drive.
Do you mean understeer?
Oversteer?
Old 11-10-2020, 07:11 PM   #8
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Are you sure your suspension is tight. I've had that happen before on another car and a control arm bolt was loose.
If it isn't the main culprit of tires / tire pressure start to look for marks in the suspension pieces. Then maybe progress to alignment.
The Following 2 Users Say Thank You to Summerwolf For This Useful Post:
anticubus (11-13-2020), soundman98 (11-13-2020)
Old 11-10-2020, 07:40 PM   #9
Jdmjunkie
Drives: Scion FR-S 10 Series
Check to make sure your rear toe arms are tight. Mine were not torqued properly when I got my last alignment done and I was getting excessive toe changes on acceleration and decel.
Jdmjunkie is offline   Reply With Quote
Old 11-12-2020, 06:36 AM   #10
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
A torsen binds under load, so tires or alignment are more suspect.
Old 11-12-2020, 11:30 AM   #11
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
Rear Toe. I had this issue a couple times. Cruising steady, it would be straight, hands off the wheel. If I gave it gas, it would steer left, again, hands off the wheel. The steering wheel would be straight but the car would turn. The proper term is THRUST ANGLE when dealing with a RWD car. My best guess is my issue came from severe wheel hop leaving stop lights in the rain. Im looking forward to getting better toe arms and trailing arm bushings.
Dont use LS oil in the rear diff! Yes, the car has a LS. But there are NO friction clutches. Its just all gears.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Westen86 For This Useful Post:
anticubus (11-13-2020), Ohio Enthusiast (11-12-2020)
Old 11-12-2020, 07:57 PM   #12
Rocketman
Torque steer = thrust angle(?): Torque from the drive train (accel or decel) pushes the rear end according to right-hand rule - left on accel, right on decel.
Not over/understeer = occurs in straight line.
Western86, et al: Yes I read on line that it could be wear in suspension parts. I am going to have my mechanic check it out. Car has had a lot of track time so would make sense. And thanks for tip on LS oil.
I don't think it is the tires. They are evenly worn - no obvious defects. But I switched ties and haven't driven it since - so we will see.
Thanks to all.
Old 11-12-2020, 08:56 PM   #13
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Broken diff is not outside of the realm of possibility but that is the last tire I would want to run in your current conditions. Hankook doesn't even advise storing them at freezing temperatures let alone driving on them.
Old 11-13-2020, 09:35 PM   #14
Rocketman
The Hankooks are off, Winter tires on.
differential, torque steer
Review soon:OS Giken Super Lock Limited Slip Differential + Greddy differential cover mav1178 Engine, Exhaust, Transmission 5 02-11-2021 02:20 PM
Rear Differential Bushing Bolt Torque Specs? brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 11-06-2017 11:36 PM
Anyone else have torque steer while turning right? babydriver Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 05-24-2016 09:45 PM
I don't believe that unequal shaft lengths causes torque steer pushrod Other Vehicles & General Automotive Discussions 12 01-31-2016 10:32 AM
Enkei 17x8 RPF1 Gold with Hankook Ventus R-S3, Torque Steer?! issue solved enginrd Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 11-08-2014 02:00 PM
