OEM Headlight Glare
I have a 2020 BRZ and found that the headlights have good light output -- maybe too good.
I frequently drive on unlit rural roads in the evening and have noticed a large number of people flashing their high beams at me. Anybody experience this with their stock BRZ headlights? There was another BRZ behind me one evening and I did notice the stock headlights seem to produce a lot of glare. Never thought I'd say this but I'm at the point where I'm thinking of throwing tint on the headlights so I don't keep blinding oncoming traffic. Last edited by SCFD; 11-08-2020 at 08:37 PM. |
#2 |
LMGTFY
Drives: 13 FRS, 91 Miata
Step 1, make sure they are aimed correctly.
IDK what is up with manufactures today, but just about every new car a family member has gotten needed the headlights adjusted. |
| The Following User Says Thank You to x808drifter For This Useful Post: | Spuds (11-08-2020) |
#3 |
Drives: 2017 Toyota 86 (860 SE)
I've gotten a lot of the same on my 86. I haven't checked the aiming of the headlights, but it's probably worth a look.
#4 |
ProCrastinationConsultant
The BRZ has motorized adjusters. Were they set right?
The official spec is 2" drop every 35'. I usually just get mine so they're completely flat, or just under depending on vehicle loading conditions
| The Following User Says Thank You to soundman98 For This Useful Post: | Spuds (11-08-2020) |
#5 | |
I'm hoping they are since I just bought the vehicle new off the dealer lot. How do you set headlight cut off on the BRZ with motorized adjusters? |
#6 |
this knob:
![]() the higher the number, the lower they go.
#7 |
The Dictater
Drives: '13 Red Scion FRS
#8 |
Thanks. It appears I'm missing that knob so I'm assuming I have manual headlights. I bought a base model without the heated seats and dual-zone climate control so I guess it also doesn't come with fancy motorized headlight adjusters. |
#9 |
Drives: 2019 BRZ w/ PP
The 2017+ BRZs (probably the 86 as well) with LED headlights don't have the adjustment knobs. They're "automatically" leveled using a sensor mounted on the rear lower control arms.
| The Following 2 Users Say Thank You to NaturallyAspirated For This Useful Post: | soundman98 (11-08-2020), Tcoat (11-09-2020) |
#10 |
Drives: '20 BRZ tS (15/300) / '09 Scion tC
Try this thread: https://www.ft86club.com/forums/showthread.php?t=123568
| The Following User Says Thank You to 2020BRZtS For This Useful Post: | SCFD (11-08-2020) |
#11 |
All of the oem hid models had it. One of the things that reinforced my choice to buy a BRZ over an fr-s
#12 |
The Dictater
#13 |
Only until 2016.
#14 |
Drives: 17 Asphalt 86
If you have fog lights turn them off. I don't run mine in rural areas or I get flashed.
| First only left headlight works, then only right headlight | russsak | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 09-23-2020 03:05 PM |
| BRZ headlight shroud inside FRS headlight? | S84kam | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 04-02-2016 12:24 AM |
| Product To Reduce Dash Glare? | Captain Snooze | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 08-20-2015 06:55 PM |
| Tinting mirrors to reduce nighttime glare | Assphalt | Cosmetic Modification (Interior/Exterior/Lighting) | 38 | 03-27-2015 08:48 AM |
| WTB Stock headlight projectors from retrofit OR a broken headlight | official_george | Exterior Parts (Aero, Lighting, Etc.) | 3 | 12-02-2013 03:32 PM |
