Old 10-31-2020, 09:40 PM   #22499
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Temp is starting to drop, so I swapped over to the winter tires today.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 11-01-2020, 10:24 AM   #22500
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Since I need to adjust the clock today,
I'll top up the tire pressures too.
Old 11-01-2020, 07:25 PM   #22501
DarkSunrise
DarkSunrise's Avatar
Switched to a 2017 oem header and tested it out in the canyons. Also topped off with some fresh e85.
2022 BRZ Build
2013 FR-S Build
Old 11-01-2020, 08:21 PM   #22502
jflogerzi
jflogerzi's Avatar
What did you have before? Any noticable performance difference?
2013 Series 10 FRS #553
Old 11-01-2020, 08:57 PM   #22503
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Did Fall maintenance on the FRS today. Changed oil, cleaned the air filter, switched to my "winter" set of tires and inspected everything. Even the brake pads. Even. The. Brake. Pads.
Anyway, everything still looks good underneath.
Exciting, I know.
ddevl_86 (11-14-2020), JesseG (11-03-2020)
Old 11-01-2020, 10:10 PM   #22504
DarkSunrise
I had the OEM 2013 header before. I've also had a JDL catless UEL and FT86SF catted.
Can't really tell much of a difference vs. 2013 OEM. My datalogs show a slight increase in max MAF voltage and engine load (about 2%), but obviously not the most reliable indicators.
I think it sounds slightly better than the 2013 OEM though. Might be in my head but I feel like it's a little smoother and a little more aggressive at the top end. I wonder if Toyota/Subaru revised the runner lengths to be more EL.
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
JesseG (11-03-2020), jflogerzi (11-01-2020)
Old 11-01-2020, 10:23 PM   #22505
Spuds
The Dictater
Spuds's Avatar
Originally Posted by beltax90 View Post
changed my clock
Shit! I knew I was forgetting something!
Old 11-02-2020, 09:17 AM   #22506
changed my clock
Did the same. Also, time change did not fix the issue with my onboard GPS. It still shows the wrong time, and the wrong arrival time. Offset by 6 hours and 12 minutes.
Old 11-02-2020, 09:17 AM   #22507
FLIPDADY
FLIPDADY's Avatar
Drives: 2015 Subaru BRZ Sport Tech
Exciting, I know.
Did you change your cabin filter too? Just did mine. Better vent flow with a fresh clean one.
Sent from my LM-G900 using Tapatalk
FLIPDADY is offline   Reply With Quote
Old 11-02-2020, 09:38 AM   #22508
Spuds
The Dictater
Spuds's Avatar
Nope. I changed it a few years back and the old one looked fine.
The Following User Says Thank You to Spuds For This Useful Post:
FLIPDADY (11-02-2020)
Old 11-02-2020, 09:42 AM   #22509
Pretty much. The larger diameter would account for the sound change.
DarkSunrise (11-02-2020), humfrz (11-02-2020)
Old 11-02-2020, 11:18 AM   #22510
DarkSunrise
So it’s not just in my head! Thanks, that description matches exactly what I was feeling (and hearing) with the new header. It’s not a huge difference but definitely better. With the sound tube blocked off and with the 2017 header, the engine has a smoother feel down low with a bit of a scream at the top end.
2022 BRZ Build
2013 FR-S Build
Old 11-02-2020, 11:29 AM   #22511
Part of that would also be the more free flowing CAI.
Old 11-02-2020, 05:45 PM   #22512
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
Did the trans and diff oil on Friday night (that's right, I know how to party). Went with Motul for the diff and Redline for the trans. Diff seems a bit quieter? Trans for sure shifts faster when warm, but I didn't feel the improvement when cold that I was hoping for. It's fine for now, but I'll try something else in the trans next time.
Cephas is offline   Reply With Quote
