Old 11-02-2020, 08:18 AM   #1
Thomas K
Drives: 2017 BRZ
OFT Stage 1 Gains on 2017 MY?
Hey guys,
I'm thinking about getting an OFT and going stage 1 (stage 2 later down the track) and I was just wondering what the performance gains were like on a 2017 model year. Couple of people have been saying the gains are quite minimal compared to the older models (2012-2016).
Thomas K is offline   Reply With Quote
Old 11-02-2020, 09:16 AM   #2
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Gains are minimal, but it does help with the dip at 4-5000 RPM. It does smooth out the engine a bit too. I'd recommend doing the stage one for now, then after you get headers, if that is your plan, unmarry the tablet and get ECUTek so you can maximize tune gains. With OFT you'll get about 80% or so maximum gains compared to ECUTek. Unless you datalog, ROMRaider the OFT, but is that is another process in itself.
spcmafia is offline   Reply With Quote
Old 11-02-2020, 09:22 AM   #3
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
To clarify.
ECUTek so you can have someone do a custom tune, not just an off the shelf tune.
The Following User Says Thank You to x808drifter For This Useful Post:
spcmafia (11-02-2020)
Old 11-02-2020, 09:28 AM   #4
spcmafia
spcmafia's Avatar
Originally Posted by x808drifter View Post
To clarify.
Yes, thank you. That is correct.
Old 11-02-2020, 01:22 PM   #5
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
One benefit of the oft is you can switch from e85 to 98. Our e85 is good.
Old 11-02-2020, 11:26 PM   #6
HaXx
Drives: jrsc_brz
I wouldnt bother wasting money on engine gains. 500$ toward your engine will get you precisely nothing, but 500$ of tires or $500 of suspension will transform your car
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
HaXx is offline   Reply With Quote
The Following User Says Thank You to HaXx For This Useful Post:
Decep (11-02-2020)
Old 11-03-2020, 04:31 AM   #7
Purist
Purist's Avatar
Drives: Subaru BRZ
OFT E85 and headers
Agree with the $500 comment. I think I paid 600 AUD for my OFT and 750 AUD for my headers. Best. Value. Ever.
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
The Following User Says Thank You to Purist For This Useful Post:
HaXx (11-04-2020)
Old 11-03-2020, 05:06 AM   #8
Purist
Purist's Avatar
Drives: Subaru BRZ
Let me tell you what needs to happen:
You' need to save your money and get an OFT and a set of UEL headers installed.
You need to ignore all the jibberjabber.
You then need to go to your nearest United servo and fill up with E85.
You need to follow the procedure and flash the applicable UEL E85 tune and then go for a nice, hard drive.
You're welcome.
Less More
Tcoat (11-03-2020)
Old 11-03-2020, 05:53 AM   #9
gen3v8
gen3v8's Avatar
Drives: My18 wrxsti
Headers, OFT, and good Aussie e85 has got my vote
Tires, good shocks/CO`s, brakes and some track time with an instructor will be hardest to beat
Old 11-03-2020, 07:15 AM   #10
Purist
Purist's Avatar
Drives: Subaru BRZ
Don't forget a 4.67 diff for an additional 15%( That's right folks, 15%) wheel torque.
Less More
Petah78 (11-03-2020)
Old 11-03-2020, 07:54 AM   #11
Thomas K
Drives: 2017 BRZ
What headers do you run? also catted or uncatted?
Old 11-03-2020, 08:41 AM   #12
Windycitystig
Drives:
I plan to get an Ace EL header with over pipe, flex-fuel kit to take advantage of e85 when available, and tune (delicious tuning) after my powertrain warranty ends.
I have read that combo should get me at least 40 hp extra at the wheel, which is like 50 hp at the crank.
This combo is almost $4000. Please chime in if anyone has data to refute the above hp claims.
Windycitystig is offline   Reply With Quote
Old 11-03-2020, 09:41 AM   #13
Petah78
Drives: 2022 BRZ sport-tech
I think final drive upgrade is often overlooked. Increasing wheel torque always = faster accelerations.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
Old 11-03-2020, 10:32 AM   #14
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I have a friend with a 2017 series.yellow.
I installed catted UEL headers and flashed the openflash tablet stage 1 map onto his car. The overall "GAINZ" may not be significant, but it definitely improved the area under the curve. I 100% advocate for the openflash tablet if you want to turn the car into something that seems willing without getting into expensive territory.
OFT stage 1 worth it on 2017+ desertbound1024 Scion FR-S / Toyota 86 GT86 General Forum 19 07-09-2019 07:51 PM
The WORKS 2017+ Stage 2 Turbo Kit is here! WORKS Forced Induction 11 02-09-2019 04:27 PM
Full Blown's New Build for the 2015 Season Stage 3 (2.19L motor) + Stage 3 Turbo kit FullBlown Forced Induction 47 06-20-2018 02:38 AM
FRS single stage vs dual stage driver's airbag mhiscott Issues | Warranty | Recalls / TSB 2 09-23-2017 03:43 PM
2017 Toyota 86 Baseline Dyno vs OFT Stage 1 JermMX5 Software Tuning 29 08-18-2017 07:11 PM
