Old 10-25-2020, 04:07 PM   #225
Kaotic Lazagna
Drives: GR Corolla
Well, without a Dremel, I don't think I could get off the orange peel as much as I want to. Barely made a difference after wet sanding with 2500 grit (over sanded near one of the side skirts since I started seeing red on the polishing stages), and then followed up with the detailing products I had laying around (not a fan of Chemical Guys), CG V32, V34, V36, and V38. Did those by hand with a microfiber towel only and I didn't want to put too much pressure for fear of bending/cracking the plastic. oh well.
Old 10-25-2020, 05:53 PM   #226
JD001
JD001's Avatar
Drives: Subaru BRZ
I'm surprised that you haven't ended up with the following:
Old 10-25-2020, 06:05 PM   #227
soundman98
ProCrastinationConsultant
soundman98's Avatar
starting with 2500grit is fine. it'll work, but will take a lot longer. you definitely don't want to be using a dremel for this. personal experience, you'll sand through the paint before even thinking about it.
https://www.club3g.com/threads/scrat...2#post-3118649
Spuds (10-25-2020)
Old 10-25-2020, 09:03 PM   #228
Kaotic Lazagna
Drives: GR Corolla
The Dremel would be for the polishing compounds, not the wet sanding. haha. I've polished real cars, and didn't think of a model being different, but I forgot that I can't apply as much pressure, nor use a DA like on a real car.
Old 10-26-2020, 03:09 PM   #229
Kaotic Lazagna
Drives: GR Corolla
Almost happened when I tried cementing the rear wing on. The wax prevented it from bonding, and just ate away at the paint. You can kind of see it in this picture. Wing also slid off and dragged some cement onto the trunk above where the Nissan sticker would go. Not sure if I can polish that off
The Following User Says Thank You to Kaotic Lazagna For This Useful Post:
JD001 (10-26-2020)
Old 10-26-2020, 03:54 PM   #230
JD001
JD001's Avatar
Drives: Subaru BRZ
Sounds like it's a "write-off", part out...
The Following 2 Users Say Thank You to JD001 For This Useful Post:
Dadhawk (10-26-2020), Kaotic Lazagna (10-26-2020)
Old 10-26-2020, 03:59 PM   #231
Kaotic Lazagna
Drives: GR Corolla
LOL, donor car. I can buy the "cheaper" non Nismo version and start over with that body. But if I do that, I'm going to want to buy the R34 "curbside" kit and retrofit the RB26 from the cheaper R32 into the R34. No, no, no, I don't want to fall into the rabbit hole. hahaha
JD001 (10-26-2020)
Old 10-26-2020, 04:27 PM   #232
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Anything can be polished off with enough abrasives. What you really mean is whether you can polish it off without damaging everything else.
The Following User Says Thank You to Spuds For This Useful Post:
Old 10-26-2020, 07:58 PM   #233
StraightOuttaCanadaEh
Wes
NSX!
Forgot about the strut bar
Instagram: @gt86ws
The Following 6 Users Say Thank You to StraightOuttaCanadaEh For This Useful Post:
Dadhawk (10-26-2020), Kaotic Lazagna (10-26-2020), shiumai (10-28-2020), soundman98 (10-26-2020), spike021 (10-26-2020), Spuds (10-26-2020)
Old 10-26-2020, 08:02 PM   #234
Spuds
The Dictater
Spuds's Avatar
NSX!
You also forgot pics of the exterior in general.
Old 10-26-2020, 08:39 PM   #235
Wes
Here you go!
Forgot the front end as well. Just the battery missing
Instagram: @gt86ws
The Following 4 Users Say Thank You to StraightOuttaCanadaEh For This Useful Post:
Kaotic Lazagna (10-26-2020), soundman98 (10-26-2020), spike021 (10-27-2020), Spuds (10-26-2020)
Old 10-26-2020, 10:37 PM   #236
Kaotic Lazagna
Drives: GR Corolla
Did you have to glue the wheels in place so they are no longer able to "roll?"
Old 10-26-2020, 10:44 PM   #237
Wes
They can roll and steer. I use hubs from tkdiecast.com
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
Old 10-26-2020, 10:56 PM   #238
Kaotic Lazagna
Drives: GR Corolla
Will have to check them out when I get home. Otherwise, gotta hack up the Fujimi ones I have.
TRD ABS Plastic Kit? Shims Cosmetic Modification (Interior/Exterior/Lighting) 5 07-19-2015 07:31 PM
Front lip - abs plastic _frs Want-To-Buy Requests 0 09-21-2014 11:11 AM
Trade my black dash plastic for your silver dash plastic thread. F3dzo Southeast 0 07-17-2012 10:06 PM
plastic interior lancie Scion FR-S / Toyota 86 GT86 General Forum 34 10-16-2011 01:02 PM
