#225 |
Drives: GR Corolla
Well, without a Dremel, I don't think I could get off the orange peel as much as I want to. Barely made a difference after wet sanding with 2500 grit (over sanded near one of the side skirts since I started seeing red on the polishing stages), and then followed up with the detailing products I had laying around (not a fan of Chemical Guys), CG V32, V34, V36, and V38. Did those by hand with a microfiber towel only and I didn't want to put too much pressure for fear of bending/cracking the plastic. oh well.
#226 | |
Drives: Subaru BRZ
#227 | |
ProCrastinationConsultant
https://www.club3g.com/threads/scrat...2#post-3118649
| The Following User Says Thank You to soundman98 For This Useful Post: | Spuds (10-25-2020) |
#228 | |
Drives: GR Corolla
#229 |
Drives: GR Corolla
Almost happened when I tried cementing the rear wing on. The wax prevented it from bonding, and just ate away at the paint. You can kind of see it in this picture. Wing also slid off and dragged some cement onto the trunk above where the Nissan sticker would go. Not sure if I can polish that off
| The Following User Says Thank You to Kaotic Lazagna For This Useful Post: | JD001 (10-26-2020) |
#230 | |
Drives: Subaru BRZ
| The Following 2 Users Say Thank You to JD001 For This Useful Post: | Dadhawk (10-26-2020), Kaotic Lazagna (10-26-2020) |
#231 |
Drives: GR Corolla
LOL, donor car. I can buy the "cheaper" non Nismo version and start over with that body. But if I do that, I'm going to want to buy the R34 "curbside" kit and retrofit the RB26 from the cheaper R32 into the R34. No, no, no, I don't want to fall into the rabbit hole. hahaha
#232 | |
The Dictater
Drives: '13 Red Scion FRS
| The Following User Says Thank You to Spuds For This Useful Post: | Kaotic Lazagna (10-26-2020) |
#233 |
Wes
NSX!
![]() ![]() Forgot about the strut bar
Instagram: @gt86ws
| The Following 6 Users Say Thank You to StraightOuttaCanadaEh For This Useful Post: | Dadhawk (10-26-2020), Kaotic Lazagna (10-26-2020), shiumai (10-28-2020), soundman98 (10-26-2020), spike021 (10-26-2020), Spuds (10-26-2020) |
#234 |
The Dictater
| The Following 2 Users Say Thank You to Spuds For This Useful Post: | soundman98 (10-26-2020), spike021 (10-26-2020) |
#235 |
Wes
Here you go!
![]() Forgot the front end as well. Just the battery missing
Instagram: @gt86ws
| The Following 4 Users Say Thank You to StraightOuttaCanadaEh For This Useful Post: |
#236 |
Drives: GR Corolla
Did you have to glue the wheels in place so they are no longer able to "roll?"
#237 |
Wes
They can roll and steer. I use hubs from tkdiecast.com
Instagram: @gt86ws
| The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post: | Kaotic Lazagna (10-26-2020) |
#238 |
Drives: GR Corolla
| TRD ABS Plastic Kit? | Shims | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 07-19-2015 07:31 PM |
| Front lip - abs plastic | _frs | Want-To-Buy Requests | 0 | 09-21-2014 11:11 AM |
| Trade my black dash plastic for your silver dash plastic thread. | F3dzo | Southeast | 0 | 07-17-2012 10:06 PM |
| plastic interior | lancie | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 10-16-2011 01:02 PM |
