Old 10-25-2020, 05:26 PM   #1
ThaDonJsuan
Drives: 2020 Subaru BRZ Sport-tech
Master Cylinder Brace
Can anyone suggest a brand of master cylinder brace? Is it even worth getting? Is it something I can install myself without any special tools or should this be done at a shop?
ThaDonJsuan is offline   Reply With Quote
Old 10-25-2020, 05:39 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
It's all the same shit. Technically it's stopping the flex. If you're not driving on the edge on track you'd be hard pressed to notice. It installs very easily
Old 10-25-2020, 05:49 PM   #3
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Buy the cheapest one.
I got a radium brace used from a part out. Does the job.
Old 10-25-2020, 07:26 PM   #4
fatoni
better places to spend money
Drive upgrades. Don't buy them.
Old 10-25-2020, 08:42 PM   #5
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I have a Perrin one. Normal easy braking, I do not notice a difference. Braking at >50%, the pedal is a a bit firmer. You will also get a bit of vibration in the pedal coming from the strut tower.
The Following User Says Thank You to Spuds For This Useful Post:
norcalpb (10-25-2020)
Old 10-25-2020, 10:24 PM   #6
norcalpb
norcalpb's Avatar
Never knew that but it totally makes sense.
There is also this option that bolts onto the cabin side of the car.
https://www.reflectedimagemotorsport...baru-brz-13-17
Old 10-26-2020, 12:01 AM   #7
p1l0t
p1l0t's Avatar
Wow I read that title too fast.
Old 10-26-2020, 12:41 AM   #8
therealstoly
therealstoly's Avatar
Drives: 2020 BRZ Limited
I'm new to this platform as well and have found searching and reading to be quite informative. I did a quick 'advanced search' and found 83 threads that address this very question. Let me know how many you find.
Maybe. And completely subjective based on the prepositional phrase most people don't seem to be able to piece together both figuratively and literally... "in conjunction with..."
I can prove that my 60-0 stop distances decreased with a brace. In conjunction with...
therealstoly is offline   Reply With Quote
Old 10-26-2020, 06:55 AM   #9
BRZBlack
BRZBlack's Avatar
Drives: 2013 Subaru BRZ
I have one (Perrin) and the install was very easy. However, I also upgraded the brake lines to SS as well as slotted rotors with Hawk pads all at the same. All of those together gave me a way better brake "feel" and can be done for about $600 give or take. The brace alone is not really worth it IMO. I can also confirm a bit of vibration from the strut tower under heavy braking.
BRZBlack is offline   Reply With Quote
Old 10-28-2020, 01:21 PM   #10
bfrank1972
Drives: 2013 FR-S Argento
I have one of these:
https://www.aliexpress.com/item/4001...E&gclsrc=aw.ds
Knockoff, works perfectly, agree with Spuds that light braking you won't notice a difference, but under more firm braking even on street I definitely feel a difference. Less soggy as you approach the bottom of the brake pedal, more confidence inspiring. I was skeptical after reading some comments like "you'll only feel it on the track" but it was definitely a worth mod for me (and I don't really drive like a maniac on the street). A side thought also - if your fluid needs replacement that may mask any benefit from the brace.
Edit: stock pads, lines, rotors, fluid, before and after
WTB: Master cylinder brace Chuckable Want-To-Buy Requests 1 01-29-2020 06:47 PM
NEW - AEM STRUT TOWER BRACE w/ Master Cylinder Brace prj3ctm4yh3m Brakes, Suspension, Chassis 4 01-24-2017 01:24 AM
WTB: AEM Front Strut tower brace with master cylinder brace prj3ctm4yh3m Want-To-Buy Requests 0 08-05-2016 01:49 PM
FS: Cusco Front Strut Tower Brace with Master Cylinder Brace / Adj Chassis Brace VoiD Brakes, Suspension, Chassis 2 03-16-2016 04:19 PM
WTB: Master Cylinder Brace DAEMANO Want-To-Buy Requests 8 09-03-2015 12:12 PM
