go_a_way1, MisterSheep
Old 10-20-2020, 06:20 PM   #22485
Originally Posted by RToyo86 View Post
That was this car.
Bumper cover was badly damaged from a hit and run just before the meet, and decided to send it anyways.
Larry would be proud.
Old 10-23-2020, 04:04 PM   #22486
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
Did a little soundproofing. ~640g of Dynamat in the trunk, and a before/after test drive with Decibel X Pro on my phone. Shows a teeny tiny ~1.5dB(A) decrease in similar conditions on my test loop. It does sound a bit different, too. I'll take it!
Cephas is offline   Reply With Quote
The Following 2 Users Say Thank You to Cephas For This Useful Post:
humfrz (10-23-2020), soundman98 (10-23-2020)
Old 10-24-2020, 06:58 AM   #22487
new2subaru
Weight Weenie
Drives: 15 FR-S
Originally Posted by new2subaru View Post
Alright. I went over the whole suspension today. I found a nut loose of my front WL end link and tightened that. That did the front. Bouncing the car up and down and I had zero noise form the front.
I re-installed the rear bar without end links and greased that crap out of the bushings. The still squeaked as I rotated the bar...I pulled it off again and notice a bit of material sticking out from the edge of the bushing. I found an inner sleeve that appeared to have not been formed correctly when made. I looked that the other side and saw the same thing. These are the new greaseless bushings but all of the area wasn't covered by this sleeve. I used a file and needle nose and removed the sleeves completely. I took the whole assembly apart including the end links. I regreased the bushings and used Break-free CLP-4 everywhere.
So far, I'm only getting a minor squeak/bind when going up a driveway/incline. I'm very happy and hope it stays this way! If not, I'll order new bushings. The rear bar makes a huge difference.
Making the same noises again, now!
Next up, rubber bushings off a 2017+
Old 10-25-2020, 04:58 AM   #22488
PandaEighty-Six
Drives: 2018 Toyota 86 GT Black
Was going for a short drive today and pulled up at a stop sign. As I'm about to make the left turn, I hear and feel a loud "boom" and felt my care get hit from the rear. I got out and though there was some minor cosmetic damage to the bumper, the trunk seems fine. Traded insurance information and filed a claim.
I'm pretty sad about the whole ordeal given it's my first auto collison and am worried about the car's resale value.
2018 Toyota 86, GT Black Edition (white with black accents)
- Blitz air filter
PandaEighty-Six is offline   Reply With Quote
Old 10-25-2020, 08:40 AM   #22489
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
Put some sound deadening in the door cards, since I was taking them off to change the speakers for upgraded units.
alex87f is offline   Reply With Quote
Old 10-25-2020, 09:43 AM   #22490
e30cabrio
e30cabrio's Avatar
Drives: 2017 86
Replaced the bumper mounts near the headlights. Cover never stayed on right after installing my CAI.
e30cabrio is offline   Reply With Quote
Old 10-25-2020, 09:59 AM   #22491
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I love the foam- how is it adhered? Let us know the results.
Those speakers seem sweet, but goodness that's a lot of money for a pair of speakers with a Toyota connector
Old 10-25-2020, 11:02 AM   #22492
alex87f
Meow
alex87f's Avatar
*cough* double-sided tape *cough*
Truth is, once the door card is on, it's kept in place by the pressure between the inner door skin and the card. The tape is only there to keep it in place for the installation.
I don't know how much the speakers cost in the US, but I got them for about $80 shipped, which seemed like a good enough deal.
Old 10-25-2020, 03:03 PM   #22493
soundman98
ProCrastinationConsultant
soundman98's Avatar
$80 is a lot better. i wouldn't consider over $100 for a set like that. is your plan to bypass the oem amp to get around the doors acting as subwoofers in the oem configuration?
Old 10-25-2020, 04:24 PM   #22494
alex87f
Meow
alex87f's Avatar
My plan was to connect them, and that's done .
Does the car have an OEM amp? I thought it didn't.
Old 10-25-2020, 07:21 PM   #22495
soundman98
soundman98's Avatar
unless you have a 2020 86 with the jbl/harman stereo, it's not going to be that easy...
the door speakers are powered from an amplifier in the trunk, under the floor mat, on the left side of the spare tire. that amplifier makes the door speakers work only as low frequency subwoofers.
there's a 3" speaker and a tweeter in the dashboard that make up the difference of the rest of the audio signal.
you'll likely need one of these adapters to bypass the amplifier by plugging this into the wire harness that plugs into the amplifier:
https://parts.toyota.com/p/Toyota__/...T29618191.html
in this guide, installation is on pages 8+9:
http://toyotaparts.sparkstoyota.com/...190-20inst.pdf
for a much cheaper option, you can purchase one of these harnesses and connect the wires yourself in the right order to make the same harness toyota sells for way too much. basically need to de-pin center 2 pins, then split each side to 4 pin groups, and connect to the identical pin position on the other side (top left goes to top left, top right goes to top right, etc)
https://www.amazon.com/Replacement-W.../dp/B075FZ138Y
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
MJones_RB (10-26-2020), Myriad (11-06-2020)
Old 10-25-2020, 07:58 PM   #22496
alex87f
Meow
alex87f's Avatar
Euro cars are different then.
I'm positive there's no amp in the back, and there are only tweeters in the dashboard, the main "hump" of the dash grilles contains no speakers (of course, there are speakers in the door and rear cards as well).
From what I saw, the signal goes straight to the tweeters, which filter the higher-pitched sounds and send the medium / bass to the door speakers. The rears do their thing and are pretty much useless.
I simply plugged in the replacement speakers and tweeters supplied with the kit, and they worked immediately. The connectors are P&P.
The Following User Says Thank You to alex87f For This Useful Post:
soundman98 (10-25-2020)
Old 10-25-2020, 08:53 PM   #22497
Legoshi
Legoshi's Avatar
Drives: 2015 Firestorm FR-S MT
Ditched the TRD USA Quickshifter and went for the STi short shifter (thanks, @DarkSideFRS!) Didn't think it would make that big of a difference but it's night and day. Transmission build is complete now. ~
Also, the shifter bushing that comes in the TRD USA Quick Shifter kit is pretty nice, actually! Probably the one saving grace of the whole kit lol. I kept it in!
Legoshi is offline   Reply With Quote
The Following User Says Thank You to Legoshi For This Useful Post:
Old 10-26-2020, 06:21 PM   #22498
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
Did you add some washers to the bushing bracket so they don't squeeze so hard? I believe the bushings are a bit robust and put too much pressure on the actual bar, which would explain why it squeezes the lube out and brings back the squeaking. Adding some washers to the brackets bolts releases some of that pressure.
MJones_RB is offline   Reply With Quote
The Following User Says Thank You to MJones_RB For This Useful Post:
new2subaru (10-26-2020)
