Old 10-25-2020, 07:13 AM   #29
kyoshi11
kyoshi11's Avatar
how do i test the pulleys besides taking off the belt and free spinning them?
kyoshi11 is offline   Reply With Quote
Old 10-25-2020, 09:40 AM   #30
JD001
JD001's Avatar
Drives: Subaru BRZ
Would a stethoscope work? I've seen mechanics using such things for checking the condition of bearings insitu..
Old 10-25-2020, 06:39 PM   #31
It's the best way to test them if one understands that high speed ball, or roller bearings must run completely silently. Otherwise, they're no longer serviceable. Left in service, they will eventually fail catastrophically.
Old 10-26-2020, 10:17 AM   #32
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Is this only happening when your fan is on? I know you said it happens even with the A/C off, but is it just the fan running in those cases where the A/C isn't on? If so, it could be the fan blades contacting the shroud.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 11-13-2020, 10:40 PM   #33
s3xy_burrito
Taco Flavored Kisses 💋💋💋
s3xy_burrito's Avatar
Drives: Scion FR-S Raven
Any update on this subject? I’m experiencing the same issue. @kyoshi11
Instagram: tilted_h3ro
s3xy_burrito is offline   Reply With Quote
Old 12-10-2020, 07:54 PM   #34
kyoshi11
kyoshi11's Avatar
No update, still screeches and I cant pinpoint the noise. Will bring it to a shop to see if they can diagnose something.
Old 04-14-2023, 11:36 AM   #35
krazer
Drives: 2015 White BRZ
@kyoshi11 @s3xy_burrito I have the same issue, any luck?
krazer is offline   Reply With Quote
Old 04-14-2023, 11:50 AM   #36
JD001
JD001's Avatar
Drives: Subaru BRZ
Screeching hell Batman!! What is going on ....
engine issue, heat shield, problem
BRZ strange screeching noise TOLM Issues | Warranty | Recalls / TSB 13 12-19-2017 11:26 PM
question regarding screeching sound when accelerating kudougw Scion FR-S / Toyota 86 GT86 General Forum 12 07-18-2014 03:37 PM
Another Engine noise Vegas86 Issues | Warranty | Recalls / TSB 4 10-09-2013 12:30 PM
Engine noise somejace BRZ First-Gen (2012+) — General Topics 4 09-19-2013 06:39 AM
metalic screeching turning left raptor87 Issues | Warranty | Recalls / TSB 2 01-18-2013 01:41 PM
