Old 10-15-2020, 09:32 PM   #15
davidsn_670
Drives: 2015 Scion FRS
I'm leaning towards a belt tensioner pulley considering it does it under load. (A/C cycling and from a stop light)
davidsn_670 is offline   Reply With Quote
The Following User Says Thank You to davidsn_670 For This Useful Post:
Overdrive (10-26-2020)
Old 10-16-2020, 10:58 AM   #16
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
+1 for sage advice.
And current covid-hair
Old 10-16-2020, 01:22 PM   #17
And be careful around rotating parts. Sleeves, scarfs, masks, hair, hands. I have seen enough gruesome injuries from that shit in my industry to make me paranoid of anything that spins under force
Yep, some of us learned that at an early age. Now what could have gone wrong before OSHA?
NoHaveMSG (10-16-2020)
Old 10-16-2020, 01:32 PM   #18
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
One of the guys that worked next to me at the motorcycle shop had a good story. He used to work for this bridge company, worked in their shop and pre-fabbed components. He was drilling this deck plate on a drill press the size of a garage, bit was the size of a fir tree. He went to bat away the chip that was curling off the bit and it caught his glove. He spent the next minute running around the bit trying to keep up with it until the chip curled off long enough he could hit the emergency stop. And that is why you don't wear gloves or long sleeves while manning a drill press.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
humfrz (10-16-2020), Ultramaroon (10-16-2020)
Old 10-16-2020, 04:59 PM   #19
what?
bcj (10-17-2020), NoHaveMSG (10-16-2020)
Old 10-17-2020, 05:56 PM   #20
kyoshi11
kyoshi11's Avatar
I cleaned the pulleys and belt and heard the noise sometimes when revving to ~1200-1350 rpm. The sound could be heard louder at the exhaust and the middle of the car and I lifted the car to check all the bolts (exhaust) and they were all tight. I also noticed when the wheel is turned either ways the noise gets loud when moving under 5 mph. Currently running SWIFT springs on OEM dampers. Could this be a diff or transmission issue?
kyoshi11 is offline   Reply With Quote
Old 10-17-2020, 07:32 PM   #21
That's where the exhaust front pipe is bracketed to the transmission. That whole assembly vibrates and pivots as a unit. Get under there. Remove the bottom panels, and wiggle stuff.
If your jack stands and work area are good enough for you to get underneath the car, It's just as safe to start the engine while you're underneath it.
mswbrz (10-19-2020), NoHaveMSG (10-17-2020)
Old 10-21-2020, 01:57 AM   #22
kyoshi11
kyoshi11's Avatar
I found the clamp holding the heat shield to the front pipe is loose and probably causing the rattling. If I took that shield off, should I wrap it in a new heat shield?
Old 10-21-2020, 03:42 AM   #23
Boom. Heat shield is important. Fix or replace the clamp.
humfrz (10-21-2020), kyoshi11 (10-21-2020)
Old 10-21-2020, 03:52 PM   #24
https://parts.subaru.com/a/Subaru_20...10-440-02.html
Old 10-25-2020, 04:54 AM   #25
kyoshi11
kyoshi11's Avatar
(insert facepalm), i drove with the air conditioner on the other day and the noise came back... i guess it was not the heat shield
Old 10-25-2020, 06:32 AM   #26
JD001
JD001's Avatar
Drives: Subaru BRZ
And here I was thinking that the little crickets had mutated.
Old 10-25-2020, 06:51 AM   #27
kyoshi11
kyoshi11's Avatar
maybe it has 0_o but im thinking it could be a bad ac compressor??? but not sure what symptoms are for that
Old 10-25-2020, 06:59 AM   #28
JD001
JD001's Avatar
Drives: Subaru BRZ
It sounds like a pulley/belt kinda thing as it's intermittent. Load application causing the screech.
engine issue, heat shield, problem
BRZ strange screeching noise TOLM Issues | Warranty | Recalls / TSB 13 12-19-2017 11:26 PM
question regarding screeching sound when accelerating kudougw Scion FR-S / Toyota 86 GT86 General Forum 12 07-18-2014 03:37 PM
Another Engine noise Vegas86 Issues | Warranty | Recalls / TSB 4 10-09-2013 12:30 PM
Engine noise somejace BRZ First-Gen (2012+) — General Topics 4 09-19-2013 06:39 AM
metalic screeching turning left raptor87 Issues | Warranty | Recalls / TSB 2 01-18-2013 01:41 PM
