Drives: 2014 BRZ
5th gear gate lockout
I boutht a 14 BRZ with 65k miles on it. I think it is the stock shifter. During casual driving, when I shift from 4th to 5th gear (under 3000rpm), sometimes the shifter won't get into the rightmost gate at the first attempt, and it takes me a 2nd try with higher effort to put it into the gate for 5th/6th gear. It happens once every 2-3 drives, and more often when the car is cold. It feels like something got stuck inside the shifter linkage. Any idea on that? Thanks!
#2 | |
Drives: TRD R.S. 1.0 FRS
And our car’s transmissions hate it when its cold. |
#3 |
Shift lever top plate can only make trouble for first and second. Look elsewhere.
#4 |
Run 4th to the red light, clutch in, take a sip of your coffee, let them pass you in the straight, go to 6th, press the gas pedal back to full, do NOT let off for the turn, as they back out and slither around like a snake in wet grass... you just slide on by anyway.
Sent from my SM-G975U using Tapatalk |
#5 |
Drives: Crapcan
Start with a fluid change. I like Redline MT-90.
#6 |
Wheels for Brains
Make sure gate the gear straight into the pattern. |
From your driving position, you may tend to gate the gear diagonally. / Trans doesn't always like this. |
| Tags |
| shifter, transmission issue |
| Where can I find a reverse lockout pin for the stock lockout? | tracerit | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 05-15-2019 03:41 AM |
| Gear lockout / grind | Exrald | Issues | Warranty | Recalls / TSB | 2 | 09-05-2018 03:41 AM |
| Installing Raceseng Reverse Lockout and Ashiko/Slammer gear knob. | The Sentinel | DIY (Do-It-Yourself) Guides | 31 | 03-11-2017 07:55 PM |
| Bad Idle, stalling, clutch chatter, gear lockout, failed clutches: My story and fix | Pneub | Engine, Exhaust, Transmission | 11 | 08-05-2016 10:29 AM |
| Shift Gate | simonweisberg | Cosmetic Modification (Interior/Exterior/Lighting) | 14 | 07-02-2015 05:17 PM |
