Old 10-19-2020, 12:18 AM   #1
GrayFox_27
Drives: 2017 Toyota 86
Blower Motor “clicking“ sound?
Context:
2017 Toyota 86
So I had my Blower Motor replaced under warranty by Toyota about a year ago (25k miles) because it was making this “clicking” sound and the air coming from the vents seemed weak even on the highest setting. Toyota initially claimed it was the Blower Motor, but I’m now at 40k miles and I’ve been having the same issue recently to the point where the AC just goes completely out.
The warranty is now expired, and I’ve read through other sources that it could be the Relay going bad. I removed the Blower Motor and it works and sounds perfectly fine when I’m holding it in my hand while testing it, and it still looks new. But once I place it back under neither the dash, the same noise slowly comes back from the Blower Motor.
I checked the space in which the Blower Motor sits, and there’s nothing blocking it or getting in the way of the fan itself so I’m not sure what’s causing it to fail.
I ordered a new Relay and I’m hoping that’s all it is and not a major electrical issue.
Hoping someone has a bit more insight on the situation?
Here’s a Link to what it sounds like:
GrayFox_27 is offline   Reply With Quote
Old 10-19-2020, 12:48 AM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
have you replaced the cabin filter every other oil change(12k mi intervals)?
humfrz (10-19-2020)
Old 10-19-2020, 12:58 AM   #3
Originally Posted by GrayFox_27 View Post
Context:
2017 Toyota 86
The last time I heard a sound like that - a plane was taking off.
What do you mean the AC goes completely out?
I have an idea that when the unit is re-installed in the car that the blower motor housing is being stressed/twisted so that the fan blade is hitting something -
Old 10-19-2020, 02:41 AM   #4
GrayFox_27
Yes
I’m using a K&N washable cabin Air Filter, it’s good as new.
Old 10-19-2020, 02:42 AM   #5
GrayFox_27
There’s no air flow. Hot or Cold.
For the past 2 weeks it’s been 50/50 on if the AC will work when I turn on the car, and if it does work, you hear a clicking sound and the air is weak. If not, there’s just no air coming from the vents. I’ve pulled out and inspected the Blower Motor at least 3 times, and twice it’s kicked on full blast in my hand with no sound and no issue, but just recently it hasn’t worked at all.
The Following User Says Thank You to GrayFox_27 For This Useful Post:
humfrz (10-19-2020)
Old 10-19-2020, 12:28 PM   #6
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
Maybe get a voltmeter and see if the motor has the voltage to operate when commanded (or not). The circuit is not too complicated depending upon whether you have manual or automatic controls. This might help determine if there is a motor or relay or other problem.
LimitedSlip is offline   Reply With Quote
The Following 2 Users Say Thank You to LimitedSlip For This Useful Post:
bmacfrs (03-05-2024), humfrz (10-19-2020)
Old 10-19-2020, 12:55 PM   #7
Well, if you're getting power to it and it's grounded and it don't run, Bubba says it's time to get another one from the wrecking yard -
Old 10-19-2020, 04:13 PM   #8
GrayFox_27
Thanks for this.
I’ll take the time to look over it and possibly find a solution. Appreciate it.
Old 10-19-2020, 10:20 PM   #9
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Sounds like bearing failure.
Changing bearing of HVAC blower motor robzz DIY (Do-It-Yourself) Guides 3 11-14-2019 12:14 AM
blower motor roddy Issues | Warranty | Recalls / TSB 21 03-19-2018 10:46 AM
Changing bearing of HVAC blower motor robzz DIY (Do-It-Yourself) Guides 0 03-09-2018 11:30 AM
clicking sound? FR-Sky Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 11-26-2016 10:21 PM
Blower motor (fuse/relay/resistor) problem? fx35s Issues | Warranty | Recalls / TSB 6 01-27-2015 10:06 AM
