Old 10-18-2020, 09:38 PM   #1
Deemsim
Drives: 2013 Gt86
Blinkers not automatically cancelling
Hi all,
I have a small issue with my indicator stalk. When i turn right (with the blinkers on), most of the time the stalk dosnt cancel (it has to go past the center for it to click off automatically), meaning i have to manually cancel it most of the time. When i turn left however, it cancels almost instantaneously. It feels like the stalk is 'imbalanced' or something. Does anyone have any idea why this could be and how to fix it?
Would be good to know if someone can upload a diagram of an indicator stalk so i can get a better understanding of how it works.
Thanks
Deemsim is offline   Reply With Quote
Old 10-19-2020, 12:08 AM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Are you the original owner?
Sounds like a clock spring issue.
Usually happens when someone removes the steering wheel and doesn't reassemble correctly.
The Following User Says Thank You to x808drifter For This Useful Post:
Deemsim (10-19-2020)
Old 10-19-2020, 12:20 AM   #3
Deemsim
Drives: 2013 Gt86
Im the second owner, i have a feeling its a clock spring issue too. The original owner had to replace the airbags as he got into a fender accident, so what you're saying makes sense.
EDIT: Would i also need to buy another steering angle sensor? or would i be able to use the one i currently have?
Old 10-19-2020, 12:47 AM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
most likely would need to get it recalibrated at the least.
Old 10-19-2020, 12:48 AM   #5
Oh, I have that problem all the time - it doesn't matter which direction I have turned or which car I drive -
Old 10-19-2020, 12:57 AM   #6
Deemsim
Drives: 2013 Gt86
Thanks ill keep that in mind
Old 10-25-2020, 07:30 PM   #7
Deemsim
Drives: 2013 Gt86
UPDATE:
Turns out the previous owner didnt install the clock spring correctly. it wasnt lined up at top dead centre, but now when i drive the abs and traction control light comes up. Would this be the steering angle sensor that needs to be recalibrated?
Blinkers not working Carlitoz3 Electronics | Audio | NAV | Infotainment 6 04-25-2019 02:01 AM
Photos not automatically resizing Clipdat Site Announcements / Questions / Issues 0 07-23-2018 08:09 PM
Doors won't automatically lock adan Issues | Warranty | Recalls / TSB 18 03-01-2014 11:02 AM
Windows not automatically rolling up mickey177 Issues | Warranty | Recalls / TSB 1 01-18-2013 12:34 PM
Thinking about cancelling... spiller AUSTRALIA 17 09-29-2012 06:40 AM
