Old 10-14-2020, 04:38 PM   #15
yzf219
Drives: 2013 FRS GTX3076R
I suspect you're just not adjusted properly. He's right about the eccentric bolt, you have to turn the bolt to change the camber position, not pull on the hub.
Sent from my ONEPLUS A5010 using Tapatalk
That could very well be it. I'll be double checking my work. I do remember rotating the eccentric bolt thru it's whole rotation multiple times and measuring the distance between hub and a fixed point to verify max camber. Thank you.
Sent from my SM-G950W using Tapatalk
yzf219 is offline   Reply With Quote
Old 10-14-2020, 04:40 PM   #16
Ashikabi
Ashikabi's Avatar
It should be pretty obvious just watching it, about where max is
Old 10-14-2020, 04:53 PM   #17
HaXx
Drives: jrsc_brz
Hey guys wondering how I should get more front camber. I am lowered 1.2 inches on springs. Have 14mm cam bolts in the bottom hole and crash bolts in the top hole. Currently maxed out a -1.8 camber. Would like to achieve -2.5.
So the options I have come up with are,
Option 1, Run a 16mm cam bolt in the strut top hole in addition to the 14mm cam bolt I already have in the bottom hole.
Option 2, slot the top hole in the strut and continue to use the 14mm crash bolt in the top hole along with the 14mm camber bolt in the bottom hole.
Option 3, slot the 3 holes where the strut mounts to the body. However I'm of the understanding that camber at the hub is more desirable than camber achieved at the top of the strut.
Forgot to mention that I do not want to run camber plates as they are far too expensive.
Thanks for the help.
i dont blame you, i just looked at ftspeed and camber plates are between 300-400 USD. you might look into onimade camber plates. 200+25 shipping USD. Im not sure if you can use camber plates on stock struts. i know you might not ilke them bc theyre a stance product, but for what they do vs how much they cost...
just another option that you might not have considered...
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
HaXx is offline   Reply With Quote
The Following User Says Thank You to HaXx For This Useful Post:
yzf219 (10-14-2020)
Old 10-14-2020, 04:58 PM   #18
yzf219
Thanks for the suggestion! Glad you understand my perspective. I will definitely look into these plates, 200 is much easier for me to stomach.
Old 10-14-2020, 05:57 PM   #19
TommyW
TommyW's Avatar
Drives: '13 Whiteout
I was under the impression based on my reading that camber added via plates isn't as desirable as camber via the hub due to something called SAI? I don't really understand it, it's just what I read.
That is Steering Axis Inclination. I does have SOME benefit is certain applications as far as scrub radius however when introducing negative camber that way the tires will most likely hit the struts
TommyW is offline   Reply With Quote
The Following User Says Thank You to TommyW For This Useful Post:
yzf219 (10-14-2020)
Old 10-14-2020, 06:24 PM   #20
Ashikabi
Ashikabi's Avatar
Songs like something a low level autocrosser doesn't need to worry about
Old 10-14-2020, 06:25 PM   #21
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Originally Posted by RToyo86 View Post
Pedders top mounts are an option.
I use Pedders top mounts which are good for -.75 along with the 14mm camber bolts (bottom hole) and 16mm camber bolts (top hole) and have achieved -2.75 front camber (aligned by Alex at Burning Rubber in Oakville).
Using a pyrometer, the tread surface shows very similar values all across during 8-10 lap sessions at TMP. This with Conti Extreme Contact Sport 245-45-17.
Using Blox LCA's adjusted at -1.5 rear camber, similar even temps are found out back.
After about 6-7 lapping events these tires, which wear incredibly slow, show dead even wear across their width.
Muskoka800 is offline   Reply With Quote
The Following 2 Users Say Thank You to Muskoka800 For This Useful Post:
RToyo86 (10-23-2020), yzf219 (10-15-2020)
Old 10-14-2020, 07:24 PM   #22
yzf219
Appreciate the detailed response. One of my plans was to just run 2 sets of bolts.
Did you ever run the car with just 2 sets of bolts and no top mounts? If so curious as to what amount of camber you were able to achieve? Also are you lowered at all?
Old 10-14-2020, 07:29 PM   #23
yzf219
Gotcha, I just had a look at the strut to tire clearance. Looks like I still have several mm left at -1.8. Getting a little close though.
Old 10-14-2020, 07:41 PM   #24
TommyW
TommyW's Avatar
Let me know what your specs are
Tire size
Wheel width
Wheel offset
I'll tell you what you can get away with
yzf219 (10-14-2020)
Old 10-14-2020, 08:16 PM   #25
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
DO NOT start cutting slots bigger in the structure of your car or strut.
Save up your money to buy camber plates and do it right or leave it as it is for now.
This is not a 1999 Civic sedan!
Why are you after so much camber anyway? What size wheels/tires are you running?
99 civics had double wishbones up front.
I wouldn't bother tracking with less then -3 degrees of camber up front unless I really wanted to destroy a set of tires. Competitive autox setups are around -4 degrees camber up front.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Tcoat (10-14-2020), yzf219 (10-14-2020)
Old 10-14-2020, 08:31 PM   #26
Just a "lets butcher a base sedan Civic to make it cool" reference. Was not intended to be accurate nor truthful.
Old 10-14-2020, 08:49 PM   #27
Ernest72
OP, why not ask a vendor like RCE or CSG. They have a lot of experience with there own cars and sell suspension parts.
The Following 2 Users Say Thank You to Ernest72 For This Useful Post:
Spuds (10-14-2020), yzf219 (10-14-2020)
Old 10-14-2020, 09:19 PM   #28
Drifter X
Drifter X's Avatar
Drives: 2019 Toyota 86 TRD SE
I second this. Mount them with the holes facing towards the engine for Max camber.
Drifter X is offline   Reply With Quote
The Following User Says Thank You to Drifter X For This Useful Post:
yzf219 (10-15-2020)
Camber Bolt Options? Maverick986 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 04-05-2018 12:10 PM
Top mount/camber plate options for KW V3? owenxguo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 05-21-2014 11:28 PM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 01:53 PM
Color options Camber Plates, Stress Bar, & Shock Mounts GC_Adam Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 03-26-2013 02:08 PM
Rear camber adjustment options? zooki Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 09-12-2012 11:46 AM
