Drives: 2013 FRS GTX3076R
Camber options.
Hey guys wondering how I should get more front camber. I am lowered 1.2 inches on springs. Have 14mm cam bolts in the bottom hole and crash bolts in the top hole. Currently maxed out a -1.8 camber. Would like to achieve -2.5.
So the options I have come up with are, Option 1, Run a 16mm cam bolt in the strut top hole in addition to the 14mm cam bolt I already have in the bottom hole. Option 2, slot the top hole in the strut and continue to use the 14mm crash bolt in the top hole along with the 14mm camber bolt in the bottom hole. Option 3, slot the 3 holes where the strut mounts to the body. However I'm of the understanding that camber at the hub is more desirable than camber achieved at the top of the strut. Forgot to mention that I do not want to run camber plates as they are far too expensive. Thanks for the help. Last edited by yzf219; 10-14-2020 at 12:52 PM. Reason: Edit 1 |
#2 | |
Sent from my ONEPLUS A5010 using Tapatalk |
| The Following User Says Thank You to Ashikabi For This Useful Post: | yzf219 (10-14-2020) |
#3 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
I dont believe option 1 will benefit any more than current. Option 2 could but I don't think it's necessary. I dont know that I would cut my strut tower in any way like Option 3 |
| The Following User Says Thank You to finch1750 For This Useful Post: | yzf219 (10-14-2020) |
#4 | |
![]() Sent from my SM-G950W using Tapatalk |
Drives: '13 Whiteout
Camber plates are much better than screwing around with bolts plus you have a lot more options.
| The Following User Says Thank You to TommyW For This Useful Post: | yzf219 (10-14-2020) |
DO NOT start cutting slots bigger in the structure of your car or strut.
Save up your money to buy camber plates and do it right or leave it as it is for now. This is not a 1999 Civic sedan! Why are you after so much camber anyway? What size wheels/tires are you running?
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#7 | |
#8 | |
| The Following User Says Thank You to yzf219 For This Useful Post: | Tcoat (10-14-2020) |
Drives: 17 Asphalt 86
Pedders top mounts are an option.
| The Following User Says Thank You to RToyo86 For This Useful Post: | yzf219 (10-14-2020) |
#10 | |
Drives: 17 86
#11 | |
also getting camber from plates is fine. Sometimes its the only way |
| The Following 2 Users Say Thank You to finch1750 For This Useful Post: | strat61caster (10-14-2020), yzf219 (10-14-2020) |
#12 | |
Do you perhaps think it could be from my drop that I'm not getting enough camber? From my understanding our cars being a MacPherson design in front and only gains camber up to 1" of travel anything after we lose camber? So if I'm dropped 1.2" could that be where some of my camber is going? Sent from my SM-G950W using Tapatalk |
#13 |
#14 | |
| Camber Bolt Options? | Maverick986 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 04-05-2018 11:10 AM |
| Top mount/camber plate options for KW V3? | owenxguo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 05-21-2014 10:28 PM |
| Bushing upgrades, geometry options and other component options? | der_rainman | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 06-26-2013 12:53 PM |
| Color options Camber Plates, Stress Bar, & Shock Mounts | GC_Adam | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 14 | 03-26-2013 01:08 PM |
| Rear camber adjustment options? | zooki | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 24 | 09-12-2012 10:46 AM |
