Old 10-09-2020, 03:41 PM   #73039
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
NVM... I figured it out. I was thinking too hard
Right angle calculator the triangle with 80° bottom edge is 0.125" right side of the triangle is 0.709
2.5-0.709 =1.791
https://www.calculator.net/right-tri...rv=&x=102&y=33
ineedyourdiddly
strat61caster is offline
ichitaka05 (10-09-2020)
Old 10-09-2020, 03:43 PM   #73040
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
Drives: 15 BRZ
No engineers in this thread. Nope. Not a one.
ScoobsMcGee is offline
The Following 9 Users Say Thank You to ScoobsMcGee For This Useful Post:
Dadhawk (10-09-2020), IceFyre13th (10-11-2020), ichitaka05 (10-09-2020), soundman98 (10-09-2020), spike021 (10-09-2020), Spuds (10-09-2020), strat61caster (10-09-2020), Tcoat (10-09-2020), Ultramaroon (10-09-2020)
Old 10-09-2020, 03:46 PM   #73041
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
2.5-0.709 =1.791
Yeah, that’s what I got too! Thanks!!!
ichitaka05 is offline
Old 10-09-2020, 04:05 PM   #73042
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
Any math expert here know the distance of the “?” Part?
Is rectangle.
Top/bottom length is 0.125”
Both side is 2.5”
I tried to find some online calculator... but all I found was right triangle & other that doesn’t work w this math.
See attached PDF. the number is 1.791"
IceFyre13th is offline
The Following 3 Users Say Thank You to IceFyre13th For This Useful Post:
ichitaka05 (10-09-2020), ScoobsMcGee (10-09-2020), Ultramaroon (10-10-2020)
Old 10-09-2020, 04:06 PM   #73043
ichitaka05
Site Moderator
ichitaka05's Avatar
IceFyre13th (10-10-2020)
Old 10-09-2020, 04:07 PM   #73044
Well, don't keep in suspense, what did you do?
Dadhawk is offline
Old 10-09-2020, 04:10 PM   #73045
ichitaka05
Site Moderator
ichitaka05's Avatar
I just did exactly like @strat61caster did. find the right triangle first and subtract it.
The Following 3 Users Say Thank You to ichitaka05 For This Useful Post:
Dadhawk (10-09-2020), spike021 (10-09-2020), Ultramaroon (10-10-2020)
Old 10-09-2020, 04:22 PM   #73046
spike021
spike021's Avatar
I’m a software engineer who was forced to take (and retake for that matter) way too many math courses.
Sadly I can’t be arsed to remember all the formulae.
Of course to be honest I wouldn’t say I was able to remember them all at the time, either.
Instagram: @spike.grc
spike021 is offline
The Following 4 Users Say Thank You to spike021 For This Useful Post:
Dadhawk (10-09-2020), humfrz (10-09-2020), ScoobsMcGee (10-09-2020), Ultramaroon (10-10-2020)
Old 10-09-2020, 04:59 PM   #73047
Well, I just finished cleaning out the eves on our house. That will be my last time doing that! I finally agree with mrs humfrz, I have no business being that high up on a ladder.
Therefore, next time it's needed it will be a son-in-law job.
humfrz is offline
The Following 6 Users Say Thank You to humfrz For This Useful Post:
Dadhawk (10-09-2020), NoHaveMSG (10-09-2020), ScoobsMcGee (10-09-2020), soundman98 (10-09-2020), spike021 (10-09-2020), Spuds (10-09-2020)
Old 10-09-2020, 05:01 PM   #73048
When you get older, they will all come back to you -
However, ....... however ...... what was my point? -
humfrz is offline
Old 10-09-2020, 05:36 PM   #73049
You said that 4 years ago.
Tcoat is offline
humfrz (10-09-2020), NoHaveMSG (10-09-2020), ScoobsMcGee (10-09-2020), soundman98 (10-09-2020), spike021 (10-09-2020), Ultramaroon (10-10-2020)
Old 10-09-2020, 05:55 PM   #73050
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I don't remember any formulas, that's what the internet is for. You just have to see whether the problem is indeed fully constrained. If so, find the appropriate formula(s) and crunch numbers. If not, assert assumptions until it is fully constrained.
Spuds is offline
The Following 4 Users Say Thank You to Spuds For This Useful Post:
Old 10-09-2020, 06:10 PM   #73051
spike021
spike021's Avatar
I think this is kind of a problem, though.
In school they insist on rote memorization almost all the time and so you're kind of forced into using that tool even if you're not skilled with it (I could never be at least for math, no idea why).
And so by the time you're out in the workforce, your best bet is hopefully analyzing a problem by using pattern recognition, which then hopefully leads you to recall similar-ish problems you've come across earlier, and from there you know what to look up to resolve them. But the whole "researching" to find a formula or whatever can be tough.
Especially since with software engineering the ironic thing about the job is that _while_ on the job, everybody Googles and whatever to research stuff they can't remember, but during interviewing you're expected to use rote memorization again.
spike021 is offline
The Following 3 Users Say Thank You to spike021 For This Useful Post:
Dadhawk (10-10-2020), soundman98 (10-09-2020), Spuds (10-09-2020)
Old 10-09-2020, 06:30 PM   #73052
Spuds
The Dictater
Spuds's Avatar
Yep. It's a common problem when you consider a lot of our teachers and professors were educated pre-internet. I've never applied for a software position so I can't really say much about why that is, but I would guess that if you know concepts by memory you can write effective code/scripts/etc faster than if you have to stop and look it up.
Idk about anyone else, but my college professors actually let us use notes and textbooks on our tests. The test questions were never something they taught directly, but rather more complex problems that would use pieces of what they taught as well as stuff from prerequisite classes. I really liked that because it reinforced the idea that we were there to learn how to engineer, not how to do math.
Spuds is offline
The Following 3 Users Say Thank You to Spuds For This Useful Post:
p1l0t (10-09-2020), soundman98 (10-09-2020), spike021 (10-10-2020)
