Old 10-09-2020, 07:42 AM   #73025
Originally Posted by spike021
I just got a set of tires like 4 or 5 thousand miles ago and I think two of them already have slow leaks. What a RIP.
Maybe it's just the cooler weather? -
Maybe you picked up a couple of nails? -
Maybe you should stop driving down the backstreets of Milpitas looking for women? -
Maybe stop buying tires with an expected life of 12 to 15 thousand miles?
Dadhawk is offline
humfrz (10-09-2020), soundman98 (10-09-2020), spike021 (10-09-2020)
Old 10-09-2020, 08:21 AM   #73026
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Random Thoughts - Part Deux
Originally Posted by Kiske View Post
Did you like her?
Couldn't even rationally reason with myself into a gts on the 981. It just because me buying a GTS yhen paying out the butt to add all the GT4's goodies onto the car spending even more. Kind of the reason I've stayed with this platform through the entire gen. It keeps me in check and not further down the rabbit hole.
Ended up not going. It’s a co-workers car so I’ll get a chance later. I could never justify it, one of the reasons I like the twins is they are easy to replace. Just curious how it benchmarks.
NoHaveMSG is offline
Old 10-09-2020, 10:36 AM   #73027
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
(well to be fair this time around I haven't been checking it often so I went by the TPMS light).
Oh, man ...
facepalm
A bicycle pump costs much less than a set of tires or a new turbo.
bcj is offline
The Following 2 Users Say Thank You to bcj For This Useful Post:
spike021 (10-09-2020), Ultramaroon (10-10-2020)
Old 10-09-2020, 01:09 PM   #73028
spike021
spike021's Avatar
Haha these last longer than that :P.
I think my last set lasted somewhere around 18-20k but had a good mix of daily driving and hard driving so it seemed a decent range.
Oh, man ...
facepalm
I don't have an issue pumping (lol)! I just haven't been driving nearly as often because I work from home now, so I'm needing to check tires and things less often than normal. I do have a gauge all the time in my glove compartment though, so usually I keep an eye on the current pressure with that.
Instagram: @spike.grc
spike021 is offline
The Following User Says Thank You to spike021 For This Useful Post:
Spuds (10-09-2020)
Old 10-09-2020, 01:18 PM   #73029
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I've been lax about pressures recently too.
Spuds is online now
Old 10-09-2020, 01:32 PM   #73030
Hades
Hades's Avatar
Drives: 2013 Scion FRS
The irony of SCCA drivers all having to wear masks for interviews, and then all the guys jumping in the winners car for a parade lap.
At least they don't have to wear a mask while racing (I'd hope)..
Hades is offline
Old 10-09-2020, 02:08 PM   #73031
I think my last set lasted somewhere around 18-20k but had a good mix of daily driving and hard driving so it seemed a decent range..
I was just doing the math based on you saying they only lasted 1/3 the time the should, but i figured you didn't mean it literally.
If I had to buy tires even every 18 to 20K miles I would go broke (ok, not literally). That would be once every 10 months or so for me.
Dadhawk is offline
Old 10-09-2020, 02:13 PM   #73032
spike021
spike021's Avatar
Yeah was probably exaggerating a bit. I do use high performance summers, the Continental ExtremeContact Sports. But they have pretty good TW ratings.
I think my first set lasted 14 months, so not that bad altogether.
spike021 is offline
Old 10-09-2020, 02:14 PM   #73033
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Any math expert here know the distance of the “?” Part?
Is rectangle.
Top/bottom length is 0.125”
Both side is 2.5”
I tried to find some online calculator... but all I found was right triangle & other that doesn’t work w this math.
ichitaka05 is offline
Old 10-09-2020, 02:16 PM   #73034
Is rectangle.
Both side is 2.5”
There's probably some calculation to do it but given the size I would just draw it to scale and measure it.
Dadhawk is offline
humfrz (10-09-2020), NoHaveMSG (10-09-2020), soundman98 (10-09-2020)
Old 10-09-2020, 02:18 PM   #73035
ichitaka05
Site Moderator
ichitaka05's Avatar
I guess it's possible... just width is 1/8", so it just make a hassle to measure. That was the sole reason why didn't measure.
Maybe I need to search app to see if there's any calculator in the app store.
Dadhawk (10-09-2020)
Old 10-09-2020, 02:34 PM   #73036
ichitaka05
Site Moderator
ichitaka05's Avatar
NVM... I figured it out. I was thinking too hard
The Following 3 Users Say Thank You to ichitaka05 For This Useful Post:
Dadhawk (10-09-2020), soundman98 (10-09-2020), Spuds (10-09-2020)
Old 10-09-2020, 02:36 PM   #73037
Spuds
The Dictater
Spuds's Avatar
Is rectangle.
Both side is 2.5”
Yes. Give me a few minutes.
Edit, nevermind you got it.
Spuds is online now
The Following User Says Thank You to Spuds For This Useful Post:
ichitaka05 (10-09-2020)
Old 10-09-2020, 02:36 PM   #73038
This may be helpful -
https://www.calculator.net/triangle-calculator.html
humfrz is offline
