Old 10-04-2020, 07:08 AM   #15
86MLR
86MLR's Avatar
Somewhere around 270hpatw is nice and reliable if tuned well (turbo is my preference), and your OEM clutch and gearbox won't hate you.
Use a good tuner and sound engineering principles
Camber solution
Good matched dampers and springs (careful with the height, you can easily screw the car up by lowering more than 1").
The Following 2 Users Say Thank You to 86MLR For This Useful Post:
sato (10-10-2020), SUSPECT_BRZ (10-04-2020)
Old 10-04-2020, 07:15 PM   #16
SUSPECT_BRZ
SUSPECT_BRZ's Avatar
Drives: 2020 Subaru BRZ TS
Camber solution
The Edelbrock SC is below those numbers but I'm guessing the clutch will still eventually have to be replaced.
You got that right. I'm set on the CSG package for now. The price is right and only heard good things about them.
SUSPECT_BRZ is offline   Reply With Quote
Old 10-05-2020, 11:25 AM   #17
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
Since you've been pretty well served on the performance front I'll address some minor cosmetic upgrades that really class up the vehicle:
-LED's. Swap out your door lighting, trunk lighting, overhead, fogs (if halogen), turn signals, plate lights, etc for LED's. Get good quality ones as they're still pretty cheap. I like to use superbrightleds.com
-Side markers: You'll want to swap these bulbs to LED's as well (go with amber ones) so while they're out you may as well swap in clear lens ones instead of the orange.
-Roof wrap: a gloss black roof wrap looks really good on these cars. I was tempted to go with black rose myself because it's almost black but has a tiny hint of red to it. Might look good if you're going to keep red as your accent colour (like your brake calipers).
As for skirts I know you said you were looking to go with TS/STI ones but I have a slightly odd alternative to suggest. The PO of my car installed those stick on, 'form to any profile' universal lips (which I believe are actually just garage door weather seals) as side skits and they actually look great! Very subtle, and you don't have to worry about them too much when you're going to jack up the car.
CrowsFeast is offline   Reply With Quote
The Following User Says Thank You to CrowsFeast For This Useful Post:
SUSPECT_BRZ (10-08-2020)
Old 10-05-2020, 11:56 AM   #18
Lantanafrs2
Drives: 2013 frs red
My experience has taught me to leave it alone.
Lantanafrs2 is offline   Reply With Quote
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
Old 10-05-2020, 12:27 PM   #19
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
^^^This
I was modifying a 14MY for some time, but you'll always have compromises. If it is your daily driver just have fun of it and enjoy it.
The Following 2 Users Say Thank You to nikitopo For This Useful Post:
Lantanafrs2 (10-05-2020), SUSPECT_BRZ (10-08-2020)
Old 10-05-2020, 01:03 PM   #20
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
If you want to keep it NA, maybe look into an upgraded final drive ratio? A 4.88 would let the car grip and zip if you get some nice tires.
I think a non-negotiable upgrade on every brz/86 is to be sure you put gorilla tape behind the window switches on the passenger and driver's side door panels to keep them from buzzing.
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
Old 10-08-2020, 05:54 PM   #21
SUSPECT_BRZ
The lighting and side markers are definitely on my list down the road when I'll be bored and have nothing to do. Definitely nice little add-ons. Thanks for the website!
I also totally agree with the roof wrap. I think I have seen a nice roof carbon fiber cover somewhere. It's a little pricey, but I want to do a real carbon fiber theme on that car. I think Seibon sells one.
Yes I did the garage seals on a previous car but I think I will stick with the STI stuff for that one.
Thanks for your input!
Old 10-08-2020, 05:55 PM   #22
SUSPECT_BRZ
Originally Posted by nikitopo View Post
^^^This
I totally respect that opinion and keeping it original. However I have played with all the cars I have ever known and this one still has room for improvement. If I had a Challenger Hellcat Redeye that would be another story
Old 10-08-2020, 05:59 PM   #23
SUSPECT_BRZ
Hasn't the final drive been upgraded in 2017 from 4:1:1 to 4:3:1? Would it still be worth upgrading?
Noted for the window switches. Still no buzzing from mine, car is brand new.
Old 10-08-2020, 06:20 PM   #24
DarkPira7e
DarkPira7e's Avatar
I personally think it's definitely worth upgrading if you just want better acceleration in general with adding power to the car. It's $$$ though, and will work against you if you ever go with a turbo setup or supercharged setup over 250whp (in my opinion)
whataboutbob (01-07-2024)
Old 10-08-2020, 08:46 PM   #25
JAS4
Drives: 2020 BRZ Limited PP
Anyone done 4.88 gear? My living with the 4.30 suggests I wouldn’t like 4.88 on the highway much. I’m 4.88 curious though.
JAS4 is offline   Reply With Quote
Old 10-09-2020, 07:18 AM   #26
SUSPECT_BRZ
There is a few people on the forums who have done it. Just research and you should find a couple of threads.
Old 10-09-2020, 05:40 PM   #27
PenGun
Drives: Red 2019 Subaru BRZ
The motor has 12.5/1 compression. Keep that in mind when you think about boost.
PenGun is offline   Reply With Quote
Old 10-10-2020, 07:42 AM   #28
SUSPECT_BRZ
I'm just weighing the pros and cons of going forced induction and I'm just concerned that doing too much to the car might kill the "nature of the beast". When you upgrade a car to a certain point, I feel that sometimes you just miss the simplicity of the "almost stock" days.
Pros :
The car will accelerate much faster
Installing FI yourself can be good learning
It makes the car more unique and appealing to the general crowd
Cons :
It costs a lot of money to make it bulletproof
Whatever you do, it will cause stress to a certain point on the engine and will shorten its lifespan
A lot of things can go wrong and cause headaches
The twin will NEVER be a drag car, whatever you do to it, unless you reach the very high HP numbers which will require extensive engine work.
That's how I see it, I could be wrong. I would love to do FI to my car, but I'm just not convinced it's worth the smiles per gallon. It's a lot of money, especially in Canada.
2020 tS pricing (MD) Alistia Mid-Atlantic 25 03-05-2020 04:07 PM
2020 BRZ colors? AnalogMan BRZ First-Gen (2012+) — General Topics 18 09-30-2019 09:49 AM
2020 86 cys19 Scion FR-S / Toyota 86 GT86 General Forum 3 08-26-2019 02:40 PM
2020 BRZ tS? funwheeldrive BRZ First-Gen (2012+) — General Topics 114 08-26-2019 01:49 PM
