Old 07-24-2012, 04:14 PM   #29
fatoni
Originally Posted by Synack View Post
Does anyone know the stock camber for front and rear? I'll likely be lowering mine 1.5" and won't even need a camber adjustment. I like the way it sits with negative camber and I drift so it will need it as well.
Sent from my Galaxy Nexus
you absolutely need an alignment after you change your suspension. that has nothing to do with drifting or liking camber or whatever. if you seriously intend to use this car in a sporting matter, an alignment should be the absolute first thing you do, even if you are running the car stock
Old 07-24-2012, 04:25 PM   #30
Synack
Boosted
Synack's Avatar
Drives: Sideways
Whoa whoa whoa, I never said I wouldn't get an alignment. I always get alignments after dropping or raising a car. I just wanted to know the stock camber is so I can guess how much I need to adjust camber or maybe not even at all. There are so many other suspension adjustments than just camber. But more than likely I'll likely be leaving camber alone if my 1.5 inch drop gets me around negative 1.5-2 degrees of camber.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 07-24-2012, 04:53 PM   #31
fatoni
haha okay. i guess it just didnt make much sense how you phrased that imo. you are probably going to want to change the alignment since the oem alignment is more a less a range. often times you get cars out of the box with asymmetric alignments and they are designed for tire life and safety. what i would do is look to some of the race shops on the forum and see what they run on their street cars. better yet, buy a lifetime alignment and just play with it to see what works for you
Old 07-24-2012, 05:00 PM   #32
Synack
Boosted
Synack's Avatar
Drives: Sideways
That;s exactly what I'm gonna do!
Old 07-24-2012, 06:47 PM   #33
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Originally Posted by project.sth View Post
Thanks a lot for the result of rear camber. -2.3 don't bother me that much as I will track it. How you lowered as me?
Im on Fortune Auto 500s. Youre definitely lower then me though.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 07-25-2012, 12:39 AM   #34
jeebus
I know you are going for a "look", but the car will handle better, ride better, and have less camber issues if you just raised it up a bit. Suspension travel is your friend.
jeebus is offline   Reply With Quote
Old 07-25-2012, 04:26 AM   #35
ExoticAir
Drives: Lots of Toyota
So this weekend I've installed my BC Coilovers. The only complain I have is I've got a lot of unwanted negative camber. I've lowered my car app. 2.5"
Since we can't ajust the rear camber OEM on our car I want to know if with the same or other suspension setup you got the same problem. Pictures are welcome.
So my wheels are 17X8 +38 on OEM tire.
The option could be the Cusco rear control arm but theirs is no spec of how much degre we can correct camber... I just don't want to spend 500$ and still have the same problem.
Looks great!!!!
ExoticAir is offline   Reply With Quote
Old 07-25-2012, 09:46 AM   #36
trueno86power
[||•]=(86)=[•||]
trueno86power's Avatar
Drives: 2017 Toyota 86
Thanks :P I'll guess I'll try this on the track with the camber and take temperature reading on my tires...
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
trueno86power is offline   Reply With Quote
Old 07-25-2012, 09:51 AM   #37
Racecomp Engineering
That's excessive rear camber for the track too. You don't want that much back there.
Stav (08-29-2012)
Old 07-25-2012, 10:06 AM   #38
Synack
Boosted
Synack's Avatar
Drives: Sideways
Usually trackers and drifter require more camber in the front than back but I think this is more about looks than functionality.
Old 07-25-2012, 12:12 PM   #39
trueno86power
[||•]=(86)=[•||]
Well I want it to look crazy as now minus the rear camber. I'll order Cusco lower arm to resolve everything. I'll update this thread when aligned.
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
Old 07-25-2012, 10:27 PM   #40
trueno86power
[||•]=(86)=[•||]
Originally Posted by Stav View Post
Hi project.sth,
Yes the rear has no factory camber, it is the same as a GRB WRX/STi rear suspension so much so that the Cusco part number is exactlly the same part to fit the GRB/FRS/BRZ to correct your camber issue.
It will easily correct the -2.5 degrees of camber and give you a nicer piece and looks much better especially from the rear.
I am installing the KW V3's this coming Friday as well as the rear camber correction from Cusco or Whiteline.
We are in Mississauga and are the master warehouse for most major suspension companies. We keep the Cusco and Whiteline products in stock in our Mississauga location so that you don't have to deal with the border and all its brokerage and taxes. We ship all over Canada next day UPS so if your ready for it give me a call or pm.
Thank you
A big thanks to this guy and Johnston Research & Performance. In less than 4 hour we contact, made arrangement and he ship my Cusco lower arm for tomorrow! And no duty to pay for Canadian. Thanks again, my car will be align on friday!
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
The Following User Says Thank You to trueno86power For This Useful Post:
schtebie (07-27-2012)
Old 07-26-2012, 06:41 AM   #41
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Dude pm when you get them i want to see them since i am right about to order a set as well!
Silverdub is offline   Reply With Quote
Old 07-26-2012, 04:27 PM   #42
EvoFanatic
Drives: Evo X
False, you can never have too much camber. Wheels must be at -90 camper at all times!
EvoFanatic is offline   Reply With Quote
RS*R Sports-i Coilover system installed (pics) R0ME0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 139 02-05-2015 03:38 PM
Camber plates Captain Snooze AUSTRALIA 7 07-02-2012 06:51 PM
Camber arms? skoodge Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 06-24-2012 10:09 PM
Excessive negative camber? MTeator Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-22-2012 10:30 AM
Drove the 86GT and NC miata back to back on GT5 Hanzo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 39 01-07-2012 12:56 PM
