Old 09-29-2020, 02:40 PM   #1
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
Getting valve work (recall) done. Should I do anything to bottom end
engine has a lot of track miles on it. Probably 80 hours worth. I'm debating either refreshing (hone, ring, bearings) or just getting a new OEM stock bottom end.
Any other suggestions? Anything to "fix" while I'm in there for a dedicated track car?
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is offline   Reply With Quote
Old 09-29-2020, 04:52 PM   #2
dasting
Drives: 2013 BRZ Limited
What are compression numbers? Are dyno numbers down?
2013 BRZ Limited, NASA Instructor, ex-spec miata racer
dasting is offline   Reply With Quote
Old 09-29-2020, 05:41 PM   #3
TommyW
TommyW's Avatar
Drives: '13 Whiteout
The dealer may ruin your car. They did mine! It's a no win situation. You get a new bottom end and they do the sealant wrong then you're in for another new motor. My suggestion is just stick with getting the recall signed off which is free then do a new motor with a shop that specializes in the FA20. You put a bunch of money in a new motor and there's a good chance it'll self destruct if the dealer does it. . It will self destruct quicker on the track if it is going to self destruct. You can get an IAG short block Stage 1 and it has upgraded internals and better oiling. Its around 1,600 more than a stock short block
TommyW is offline   Reply With Quote
The Following 2 Users Say Thank You to TommyW For This Useful Post:
Irace86.2.0 (10-01-2020), Ultramaroon (10-04-2020)
Old 09-29-2020, 06:16 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Consider me a bit afraid of this, but I wouldn't bother doing anything while they're in there. Just pray they can do the single job they've got correctly.
Honestly, plugs and DI seals are the only two things I'd do unprompted.
Clutch, TOB, upgrade clutch fork would be peace of mind things
Old 09-29-2020, 08:13 PM   #5
TommyW
TommyW's Avatar
Clutch is a safe bet. Of course the dealer didn't tighten my pivot bolt and the fork came off while nursing a knocking rod on the way home
Old 10-01-2020, 06:57 PM   #6
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
What’s wrong with the engine? What do you think/know needs repairing/replacing and why?
I agree with Tommy. Do the spring recall if you have to and then do a rebuild to freshen/strengthen the motor.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
TommyW (10-01-2020)
Old 10-01-2020, 07:35 PM   #7
TommyW
TommyW's Avatar
Just got off the track at Laguna sitting in the RV with a cold one. Ran the new IAG motor built the RIGHT way and I’m here to tell you it was money well spent. Flawless all day, just felt super tight and had total confidence.
The Following User Says Thank You to TommyW For This Useful Post:
Old 10-04-2020, 04:23 PM   #8
GrandSport
GrandSport's Avatar
I’m leaning toward a crate/factory bottom
End and just having them install that instead of my old one. Should I upgrade any bolts or hardware?
Old 10-04-2020, 07:23 PM   #9
Get reference UOA now if you haven't already. That's just for the bearings Otherwise, don't fuck with it. You aren't in Cali. Especially with such punishing use, your valve springs are thoroughly battle-tested. I should start a no-recall fund. Everybody kicks in ten bucks and if one of us breaks a valve spring, we get a brand new engine.
Old 10-07-2020, 08:41 AM   #10
GrandSport
GrandSport's Avatar
What's a UOA reference?
Old 10-07-2020, 09:03 AM   #11
wheelhaus
wheelhaus's Avatar
Used Oil Analysis. The best information can be gleaned from a series of tests to see what's happening changing over time, but a baseline is always needed to start.
https://www.blackstone-labs.com/
The Following User Says Thank You to wheelhaus For This Useful Post:
Ultramaroon (10-07-2020)
Old 10-07-2020, 10:44 AM   #12
GrandSport
GrandSport's Avatar
Well my oil has one track day on it and I am sending the car off in a few days, so that's probably not going to be super helpful. I can check clearances and stuff, but at this point, given it has so many track hours, it's worth peace of mind to put a new factory rotating assembly in.
I'm not going to do much by way of power- it will stay with bolt ons and E-85 tune, so I think factory rod, cank and pistons are fine. Is there anything I should upgrade (ie: Rod bolts, oil pump, etc) before doing this?
Results of the Valve Spring Recall Work Magoo Issues | Warranty | Recalls / TSB 241 01-13-2022 02:38 PM
Valve spring recall - where did you get it done? satisfied with the work? fiveoneoh Northern California 103 09-25-2020 02:10 PM
J02 valve spring recall, Toyota will not work on car drz400dude Issues | Warranty | Recalls / TSB 30 08-18-2020 02:15 PM
CEL and traction control lights on after valve spring recall work Lord Akbar Issues | Warranty | Recalls / TSB 10 08-10-2020 09:29 PM
valve spring recall/ additional work performed when engine is out swfrs Issues | Warranty | Recalls / TSB 172 07-31-2019 12:10 AM
