Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
Getting valve work (recall) done. Should I do anything to bottom end
engine has a lot of track miles on it. Probably 80 hours worth. I'm debating either refreshing (hone, ring, bearings) or just getting a new OEM stock bottom end.
Any other suggestions? Anything to "fix" while I'm in there for a dedicated track car?
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car. 2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc. 1999 NB Spec Miata: 1.8 w/ all the goodies. 2022 CT5 Blackwing: Stock. |
#2 |
Drives: 2013 BRZ Limited
What are compression numbers? Are dyno numbers down?
2013 BRZ Limited, NASA Instructor, ex-spec miata racer
#3 |
Drives: '13 Whiteout
The dealer may ruin your car. They did mine! It's a no win situation. You get a new bottom end and they do the sealant wrong then you're in for another new motor. My suggestion is just stick with getting the recall signed off which is free then do a new motor with a shop that specializes in the FA20. You put a bunch of money in a new motor and there's a good chance it'll self destruct if the dealer does it. . It will self destruct quicker on the track if it is going to self destruct. You can get an IAG short block Stage 1 and it has upgraded internals and better oiling. Its around 1,600 more than a stock short block
| The Following 2 Users Say Thank You to TommyW For This Useful Post: | Irace86.2.0 (10-01-2020), Ultramaroon (10-04-2020) |
#4 |
Rust bucket enthusiast
Consider me a bit afraid of this, but I wouldn't bother doing anything while they're in there. Just pray they can do the single job they've got correctly.
Honestly, plugs and DI seals are the only two things I'd do unprompted. Clutch, TOB, upgrade clutch fork would be peace of mind things |
#5 |
Clutch is a safe bet. Of course the dealer didn't tighten my pivot bolt and the fork came off while nursing a knocking rod on the way home
#6 | |
Drives: Q5 + BRZ + M796
I agree with Tommy. Do the spring recall if you have to and then do a rebuild to freshen/strengthen the motor.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | TommyW (10-01-2020) |
#7 |
Just got off the track at Laguna sitting in the RV with a cold one. Ran the new IAG motor built the RIGHT way and I’m here to tell you it was money well spent. Flawless all day, just felt super tight and had total confidence.
| The Following User Says Thank You to TommyW For This Useful Post: | Irace86.2.0 (10-01-2020) |
#8 |
I’m leaning toward a crate/factory bottom
End and just having them install that instead of my old one. Should I upgrade any bolts or hardware?
#9 |
Get reference UOA now if you haven't already. That's just for the bearings Otherwise, don't fuck with it. You aren't in Cali. Especially with such punishing use, your valve springs are thoroughly battle-tested. I should start a no-recall fund. Everybody kicks in ten bucks and if one of us breaks a valve spring, we get a brand new engine.
#10 | |
#11 |
Used Oil Analysis. The best information can be gleaned from a series of tests to see what's happening changing over time, but a baseline is always needed to start.
https://www.blackstone-labs.com/ |
| The Following User Says Thank You to wheelhaus For This Useful Post: | Ultramaroon (10-07-2020) |
#12 | |
I'm not going to do much by way of power- it will stay with bolt ons and E-85 tune, so I think factory rod, cank and pistons are fine. Is there anything I should upgrade (ie: Rod bolts, oil pump, etc) before doing this?
| Results of the Valve Spring Recall Work | Magoo | Issues | Warranty | Recalls / TSB | 241 | 01-13-2022 02:38 PM |
| Valve spring recall - where did you get it done? satisfied with the work? | fiveoneoh | Northern California | 103 | 09-25-2020 02:10 PM |
| J02 valve spring recall, Toyota will not work on car | drz400dude | Issues | Warranty | Recalls / TSB | 30 | 08-18-2020 02:15 PM |
| CEL and traction control lights on after valve spring recall work | Lord Akbar | Issues | Warranty | Recalls / TSB | 10 | 08-10-2020 09:29 PM |
| valve spring recall/ additional work performed when engine is out | swfrs | Issues | Warranty | Recalls / TSB | 172 | 07-31-2019 12:10 AM |
