Old 09-25-2020, 05:38 AM   #1
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
Valve Spring Issues have finally become Contagious
https://gmauthority.com/blog/2020/09...gm-v8-engines/
ToySub1946 is offline   Reply With Quote
The Following User Says Thank You to ToySub1946 For This Useful Post:
gravitylover (09-25-2020)
Old 09-25-2020, 09:48 AM   #2
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
I haven't particularly looked into the valve spring issue but I seem to recall hearing something about it being a heat treat issue that caused them to be susceptible to failure (which would make sense to me)
Since one supplier would be selling springs to several different manufacturers I wouldn't be surprised to find that this became a widespread issue. The heat treat problem (if that is in fact the issue) might not be that the treatment was spec'd wrong; it could be that one of the suppliers furnaces was running out of spec or miss-reading the temps.
Just my shot in the dark with my understanding of how such things work, but with no research done on this specific case.
CrowsFeast is offline   Reply With Quote
Old 09-25-2020, 10:50 AM   #3
No it was not a manufacturing issue. That was speculation.
It was a design issue that they caught and corrected. The springs themselves were not the problem. The use of that certain spring in the application was.
"The basis for how the recall population was determined: Vehicles equipped with
engines which have an improper design of the valve train which may result in
excessive stress to the valve springs are included in population. In May 2013, the
lower limit tolerance of the valve spring wire diameter was raised to compensate for
the excessive stress.
-How the recalled products differ from products that were not included in the recall:
Products that were not included in the recall are as follows:
1. Products that do not have valve train containing valve springs manufactured with
the original width of the tolerance of the spring wire diameter.
2. Products that were manufactured before January 2012, when introduction of new
type engine and production volume increase resulted in the rate of valve spring
fracture to increase."
https://static.nhtsa.gov/odi/rcl/201...8V772-5413.pdf
Bad parts due to design/materials/processes/assembly methods happen all the time. The majority get caught by the parts manufacturer or the QC at the assembly plant but sometimes things slip through. This can be especially prevalent in new engines. In the Subaru case the design specs of the spring looked good on paper and passed all the engineering reviews but in fact they simply were not the right strength. There is nothing beyond the fact that the GM issue is also springs to tie them together.
Everybody needs to stop thinking that internet speculation is fact and dig a bit further. The Subaru case is well documented for anybody that takes the time to read it all. https://www-odi.nhtsa.dot.gov/acms/c...72&docType=RCL
Ultramaroon (10-03-2020)
Old 10-03-2020, 07:25 PM   #4
SUSPECT_BRZ
SUSPECT_BRZ's Avatar
Drives: 2020 Subaru BRZ TS
The same thing happened with the lifters on the Pontiac G8 GT in the 6.0L L76 engine. Nearly every engine has a weakness but once solved, everything runs smooth. That specific lifter looked good on paper but was too weak in the long run for the assembly and most owners had to swap them before a potential failure after 100-150K.
SUSPECT_BRZ is offline   Reply With Quote
Old 10-03-2020, 08:13 PM   #5
Except for when it comes from me.
Tcoat (10-03-2020)
Old 10-03-2020, 08:25 PM   #6
Speculation.
Old 10-03-2020, 09:20 PM   #7
Speculation.
Oh, wait. Yeah.
Old 10-04-2020, 11:24 AM   #8
sato
sato's Avatar
Drives: Dodge Patitas
Just laughing because of you guys... and then read something to post about it.
To quote the article's quotes: "the service department is instructed to “just replace the affected valve spring,” and that if they determine there is a cylinder leakage, it “will be necessary to inspect further to determine the extent of the engine damage to determine correct repair required.”"
So, I'm thinking the GM line of though could possibly be that they have no evidence to suspect that the OTHER springs could fail? I mean, when has a dealer ever determined that there is NOTHING wrong or can't replicate a problem, when there is obviously something odd/wrong. Sure, I don't see a problem with that... since I don't own a GM.
sato is offline   Reply With Quote
The Following User Says Thank You to sato For This Useful Post:
Ultramaroon (10-04-2020)
Old 10-04-2020, 06:47 PM   #9
I just nabbed this off of a GM forum. I can see how this is more survivable.
? Pil Issues | Warranty | Recalls / TSB 25 05-04-2020 05:52 PM
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 09:32 PM
Valve float after valve spring recall mswbrz Issues | Warranty | Recalls / TSB 5 11-22-2019 07:03 PM
valve spring issue? nikitopo Issues | Warranty | Recalls / TSB 1037 05-01-2019 10:55 PM
Broken Valve Spring sybrite Engine, Exhaust, Transmission 45 11-02-2018 04:20 AM
