Old 10-01-2020, 02:19 PM   #15
After the threads that have been popping up the past few weeks, we almost need a sticky on "how to ask a question."
The problem is that the people asking don't know what they don't know.
Everybody tries to help but just throwing out random guesses without all the data just confuses the issue even more.
In this case what clutch he has can make a huge difference in what the issue could be. Like you said the ACT one has a huge history of issues here.
NoHaveMSG (10-01-2020)
Old 10-01-2020, 07:20 PM   #16
BRZBoosted
Drives: 2013 Supercharged BRZ
Thank you for all the suggestions. I don't know what clutch was installed by the previous owner. I'm going to spend some time seeing if it is the slave or master cylinder before I drop out the trans. If I end up needing a new clutch which one should I get. The tune I have on it currently has me at around 300hp to the wheels.
BRZBoosted is offline   Reply With Quote
Old 10-01-2020, 07:28 PM   #17
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Another thing to consider, if the previous owner put a heavy aftermarket clutch in it and left the stock clutch fork, the clutch fork could have bent. They are notoriously flimsy on this car. You may also be able to pull the rubber inspection cover off the top of the engine and look down at the clutch. If the pressure plate is colored, it is not stock. If it is unfinished it could still be aftermarket though.
Inspection cover can be seen in this short video.
soundman98 (10-01-2020)
Old 10-02-2020, 04:09 AM   #18
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
If you have a yellow pressure plate, it is an ACT clutch, and they are garbage.
I had lockout issues with mine. When the car is cold, it will get into gear fine up until it warms up.
Made the car so unenjoyable to drive.
2017 Series.Yellow
2013 Whiteout
VINwiki - Changing Automotive History
dhuang is offline   Reply With Quote
Old 10-10-2020, 03:55 PM   #19
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I've heard so many issues with the ACT but I have to admit mine has been fine so far. I'm sure I'll reply to this post at some point in the future to point out it no longer disengages lol
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-14-2020, 08:39 AM   #20
Grady
Grady's Avatar
Any bets on another ACT clutch? Anyone?
Mine gets finicky on going into gear when hot. Won’t make the mistake of buying an ACT again! Took forever to break in and be smooth, now after 10k miles starting this BS.
The Following User Says Thank You to Grady For This Useful Post:
NoHaveMSG (10-14-2020)
Old 10-26-2020, 01:35 PM   #21
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I knew I shouldn't have posted anything lol
This weekend at Sebring the car stopped wanting to shift into gears when it got hot, especially 4th so might be a trans issue as well but all gears were a problem when it got hot. Eventually that was after 2 laps..... so yeah looks like I'll be ripping that crap out. ACT has always been great in my other cars so that sucks.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 3 Users Say Thank You to Dave-ROR For This Useful Post:
bcj (10-26-2020), dhuang (10-27-2020), soundman98 (10-26-2020)
Old 10-28-2020, 02:38 AM   #22
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I feel like I used to have this issue sporadically when my car was new.
After putting some miles on it, it seems to be less common.
It happened to me again a few days ago after a few years of no issues. Driving around giving it the ol' Italian tune up seems to have remedied my situation.
No idea why it's sporadic.
I just force the thing in there when it happens. If it breaks, it breaks, and I'll get it fixed or get something new.
High Idle (up to 3k) while stopped in gear Eazy-V Software Tuning 23 01-24-2020 10:37 PM
Car won't shift into first gear Longjohnstrokems Issues | Warranty | Recalls / TSB 48 09-16-2019 07:46 PM
Money gear shift? accel Scion FR-S / Toyota 86 GT86 General Forum 56 04-17-2017 06:53 AM
BRZ shift gear indicator wants you to shift gears too soon? Jfheisenberg BRZ First-Gen (2012+) — General Topics 31 03-24-2015 02:50 PM
MT doesn't like 2nd gear Nubbs Issues | Warranty | Recalls / TSB 18 08-30-2012 09:15 PM
