Old 09-30-2020, 07:36 PM   #1
BRZBoosted
Drives: 2013 Supercharged BRZ
Car doesn't want to shift into any gear when stopped
I'm new to this platform and this is the first problem I have run into. My car won't shift into any gear when it is standing still and on, but if I turn the car off it will shift into any gear with ease. To get the car to move I have to shut the car off put it into first then start it and it will run through the gears. Then it has the same problem when I come to a stop again. When I'm trying to shift into first gear with the clutch fully depressed the car drops slightly in rpm but doesn't move.
Thanks,
Matt
BRZBoosted is offline   Reply With Quote
Old 09-30-2020, 07:38 PM   #2
BlOody_BoOger
BlOody_BoOger's Avatar
Thanks,
Matt
Are u letting it warm up when u start it?
Sent from my IN2017 using Tapatalk
BlOody_BoOger is offline   Reply With Quote
Old 09-30-2020, 07:39 PM   #3
Oxyg3n
Oxyg3n's Avatar
Drives: 2017 BRZ - WRB
Have you tried to let go of the brake slightly to let the car move a bit so that it gives the internals some slack and enables you to shift into 1st? Sometimes I do d that when it's difficult to shift into 1st when stopped, that has helped.
Sent from my SM-G973U1 using Tapatalk
Oxyg3n is offline   Reply With Quote
Old 09-30-2020, 11:26 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
are you pushing the clutch all the way to the floor? sounds like the clutch isn't fully disengaging.
Old 10-01-2020, 04:09 AM   #5
BRZBoosted
The car is warm and the clutch is all the way to the floor. I filled the clutch reservoir and bled the system with no results. Tomorrow I'm going to check and make sure that the trans is full.
Old 10-01-2020, 05:37 AM   #6
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Clutch not releasing completely, if it's bled properly, confirm the pedal linkage is working correctly, check for a fluid leak at the master cylinder rod under the dash, if everything checks out your issue will be in the bell housing, either a worn clutch, bad slave or damaged fork.
Old 10-01-2020, 06:45 AM   #7
Stock clutch? Flywheel?
Has the TOB been changed?
Old 10-01-2020, 09:20 AM   #8
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
+1 sounds like a clutch issue
Old 10-01-2020, 09:25 AM   #9
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Have you tried slowly coming off the clutch pedal while trying to get into gear? Sometimes as I have to let it out a bit to get it to engage. It mostly happens to me when going into reverse, but I have felt it a few other times too.
BigTuna is offline   Reply With Quote
Old 10-01-2020, 11:07 AM   #10
dasting
Drives: 2013 BRZ Limited
If this is happening every time it is not a user error issue, some part of the system is not working correctly. Either you have a bad seal in the master or slave cylinder and fluid is getting past and therefore the clutch fork is not fully moving, or the clutch fork is bent, or there is air in the system unlikely since you said you bled it) or there is a pressure plate issue (worn spring diaphragm, bent clutch fork, etc). I would chase master/slave faults first.
2013 BRZ Limited, NASA Instructor, ex-spec miata racer
dasting is offline   Reply With Quote
Old 10-01-2020, 11:54 AM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Any bets on another ACT clutch? Anyone?
Old 10-01-2020, 12:45 PM   #12
humfrz
Thanks,
Matt
Hello BRZBoosted and welcome to our forum -
Have you tried adjusting the clutch?
Old 10-01-2020, 12:58 PM   #13
This is why I asked if stock. The car is boosted so probably a safe bet the clutch is changed.
Everybody is trying to diagnose something when we don't even know what parts are in there.
Old 10-01-2020, 01:11 PM   #14
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
After the threads that have been popping up the past few weeks, we almost need a sticky on "how to ask a question."
High Idle (up to 3k) while stopped in gear Eazy-V Software Tuning 23 01-24-2020 09:37 PM
Car won't shift into first gear Longjohnstrokems Issues | Warranty | Recalls / TSB 48 09-16-2019 06:46 PM
Money gear shift? accel Scion FR-S / Toyota 86 GT86 General Forum 56 04-17-2017 05:53 AM
BRZ shift gear indicator wants you to shift gears too soon? Jfheisenberg BRZ First-Gen (2012+) — General Topics 31 03-24-2015 01:50 PM
MT doesn't like 2nd gear Nubbs Issues | Warranty | Recalls / TSB 18 08-30-2012 08:15 PM
