Old 09-30-2020, 01:29 AM   #15
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
VSC works the brakes to keep the vehicle pointing in the direction it is moving.
TCS works the throttle to keep the rear tires from spinning
ABS works the brakes to keep the tires from locking up while you shit yourself upon seeing a quickly approaching obstacle.
Pressing VSC sport engages VSC sport mode if not already engaged. If it is already engaged, then it puts you back to normal mode. VSC sport mode backs off TCS and VSC just enough for you to realize that you are going a bit sideways before it kills all the fun.
Pressing Trac off turns traction control off until you hit 30mph. If Traction control is already off when you press it, it reverts to normal mode. This is like a mode for snow when your only option is to let the wheels spin, but then kicks back in automatically when you get moving.
Holding Trac off for 5 seconds (this only works if you are stationary the whole time) turns TCS off completely at disables vsc for the most part. Still has brake bias adjustment when on the brakes, but otherwise you are on your own. I think it still has ediff function too but I am not sure. Pressing Trac again should bring you back into normal mode.
Pedal dance turns vsc and tcs completely off. Brakes become a simple hydraulic system and throttle does exactly what you tell it to.
All modes above gave abs enabled. Removing the ABS fuse is the only way to disable ABS I think. And if ABS is causing a problem you are doing it very wrong unless you are legit drifting on a track or in an offroad rally competition at a high experience level.
This has been answered many times on this site. A quick Google search for "ft86club vsc modes" would probably get you what you want to know.
The Following 3 Users Say Thank You to Spuds For This Useful Post:
JesseG (09-30-2020), mrg666 (10-01-2020), RToyo86 (09-30-2020)
Old 09-30-2020, 01:33 AM   #16
soundman98
ProCrastinationConsultant
soundman98's Avatar
In my '14, press-hold works at any speed.
The Following 3 Users Say Thank You to soundman98 For This Useful Post:
jeffchap (10-01-2020), JesseG (09-30-2020), Overdrive (10-01-2020)
Old 09-30-2020, 01:34 AM   #17
JesseG
JesseG's Avatar
Drives: 2016 Scion FR-S
Originally Posted by Vides990 View Post
No probs, but no, they're essentially saying you need to do the pedal dance to turn everything off until the 2017 model (manual only).
Ahhhh gotcha, hence why Track mode is considered much better. I’ve thought about doing the swap, but I don’t push my car hard enough to justify it.
JesseG is offline   Reply With Quote
Old 09-30-2020, 06:26 AM   #18
finch1750 (09-30-2020), HKz (09-30-2020), NoHaveMSG (09-30-2020), Overdrive (10-01-2020), Spuds (09-30-2020)
Old 09-30-2020, 08:01 AM   #19
WNDSRFR
Drives: FR-S,GTI
My '13 does too.
Old 09-30-2020, 08:25 AM   #20
Spuds
The Dictater
Spuds's Avatar
Originally Posted by WNDSRFR View Post
My '13 does too.
Wait really? I could have sworn you could only get it into the first tcs off stage while moving. I'm pretty sure I tested that myself, but I suppose I could try it again today...
Old 09-30-2020, 12:02 PM   #21
JesseG
JesseG's Avatar
It seems like something that should only be allowed when stopped, or below a certain speed. Maybe it lets you as long as Traction Control or VSC isn’t in use?
Old 09-30-2020, 12:40 PM   #22
If only that was explained in like a book or something like that. They could give one out with every car and people could read through it and know how everything works.
The Following 9 Users Say Thank You to Tcoat For This Useful Post:
finch1750 (09-30-2020), g e (10-01-2020), jeffchap (10-01-2020), JesseG (09-30-2020), NoHaveMSG (09-30-2020), Overdrive (10-01-2020), RToyo86 (09-30-2020), Spuds (09-30-2020), The Red One (09-30-2020)
Old 09-30-2020, 12:47 PM   #23
The Red One
Pro Couch surfer
The Red One's Avatar
Drives: 2019 BRZ Sport-tech RS.City car:GD3
A pdf manuel would be much better , you could search key words on your phone.
The Red One is offline   Reply With Quote
The Following 2 Users Say Thank You to The Red One For This Useful Post:
Spuds (09-30-2020), Tcoat (09-30-2020)
Old 09-30-2020, 12:53 PM   #24
Don't be silly. How in the world would anybody ever get access to such a thing?
soundman98 (09-30-2020), Spuds (09-30-2020)
Old 09-30-2020, 12:56 PM   #25
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
You could possibly rig up some sort of series of tubes...
The Following 6 Users Say Thank You to dragoontwo For This Useful Post:
Hades (10-09-2020), jeffchap (10-01-2020), soundman98 (09-30-2020), Spuds (09-30-2020), Tcoat (09-30-2020), x808drifter (09-30-2020)
Old 09-30-2020, 01:27 PM   #26
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
You would need to swap the computer that controls the nannies. I believe it's possible(I read a topic discussion buried in the forum somewhere) but considering you haven't found sport mode limiting, I wouldn't see the point.
I know full off on the newer cars is more like actual full off. No E-diff etc. You keep ABS, but that is it.
The Following User Says Thank You to RToyo86 For This Useful Post:
JesseG (09-30-2020)
Old 09-30-2020, 01:27 PM   #27
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I know, OP doesn't know how to read. Someone needs to explain this is a youtube vid that starts with "Hey guys, sorry I've been busy but I have a ton more content coming soon. Don't forget to like and subscribe!"
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
NoHaveMSG (10-02-2020), soundman98 (09-30-2020)
Old 09-30-2020, 01:56 PM   #28
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
maybe since OP bought his used, perhaps his car didn't come with a manual? :p
idk if it makes me weird, but as soon as i got my '13, i took my manual out of the glovebox and read it in bed every night until i was done...and when i got my '16 i did the same thing lol
HKz is offline   Reply With Quote
The Following 6 Users Say Thank You to HKz For This Useful Post:
finch1750 (09-30-2020), JesseG (09-30-2020), Overdrive (10-01-2020), soundman98 (09-30-2020), Tcoat (10-01-2020), The Red One (09-30-2020)
DIY: Track Mode on 2013-2016 cars Yoshoobaroo DIY (Do-It-Yourself) Guides 206 06-23-2025 06:25 PM
Vsc sport and Sport mode at the same time? Markk Scion FR-S / Toyota 86 GT86 General Forum 22 09-28-2015 02:07 PM
DIY Auto VSC Sport and AT Sport Mode Seattle944t DIY (Do-It-Yourself) Guides 0 09-08-2013 05:02 PM
Cruise control with Sport or VSC Sport mode notout86 Scion FR-S / Toyota 86 GT86 General Forum 12 08-29-2013 06:50 PM
sport mode... pr086 Scion FR-S / Toyota 86 GT86 General Forum 6 06-01-2012 11:50 AM
