Old 09-29-2020, 06:44 PM   #57
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by solidsnake11 View Post
The mechanic at element did it on phill's car.
He's obviously a ganster, or simply insane.
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
NoHaveMSG (09-29-2020)
Old 09-29-2020, 07:15 PM   #58
prandelia
Drives: 2015 FRS
Originally Posted by rixter145 View Post
It's for people who stay at the higher rev range to eliminate valve float. I am unsure if the Ferrea springs will stay shut for that application but if you are in the rebuilt route, might as well get a heavier sring and retainer
I understand the point of it, but I'm just questioning the doubling of the spring rate. It seems excessive, and may add accelerated wear to valvetrain components, and cost HP. For a low power NA build, I would thinking using Ferrea's 60lb or 70lb springs would be more a more than sufficient upgrade. Not to mention, the heavier spring you go with, typically the shorter life cycle. I don't want to be taking these heads off for anything to be honest.
Rocker retainers, and some lightly upgraded valve springs and call it a day.
Now sure, for big FI power, I can see this but I can tell you from just a few conversations with some of these companies, they just want to slap in their product of "choice" regardless of the build. Like rods for example, a 200whp, NA motor doesn't need super-heavy duty rods that are heavier than stock ones, especially when you can buy lighter forged ones that are WAY stronger, but yet that's what they "recommend".
Point is, I honestly just don't have much faith in a lot these companies for motor builds.
'15 FRS - GLTC spec
YouTube channel race vids: https://www.youtube.com/channel/UClU...phsppnA/videos
prandelia is offline   Reply With Quote
Old 09-29-2020, 07:39 PM   #59
rixter145
Sleep Chomper
rixter145's Avatar
If you're doing a low power build, why don't you just get a factory block at this point? That would eliminate all the guess work and reliability issues
rixter145 is offline   Reply With Quote
Old 09-30-2020, 12:53 AM   #60
prandelia
Drives: 2015 FRS
It's honestly what I'm leaning toward, except using the '17 block/case and valvetrain components (and intake manifold) for all the good internal upgrades, and then using all my '15 sensors and wiring harness. Then adding rocker lockers, some upgraded valve springs, rods, bearings, but stock pistons and CR. Really, just a reliability build, I don't really need anymore power at this point.
For something like that, prob alot easier and cheaper to just find a nice low mileage full '17 motor and have someone do the work.
It's what I've been racing the past 1.5 years without any issues. Bought my car with about 33K street miles on it, then straight to racing with it. It's unopened inside, but it is a '15, which I know already has the second version of OE valvetrain upgrades. It literally only sees high RPM, and knock on wood has been great so far. Uses 10W50 oil, oil pan baffle, and so far so good.
It's these rockers that have me F-ing paranoid!
'15 FRS - GLTC spec
Old 09-30-2020, 12:58 AM   #61
prandelia
Drives: 2015 FRS
On my rebuild I am using 17+ valvetrain parts and non beehive springs, they are GSC-5756. But it still fell off. I mean if you are OK with taking the risk then go for it, but for an extra $450, I rather have a peace of mind.
Considering I am taking the engine out and shipping it back to put those retainer kits back on, this is a no brainer investment.
The real question is, are the OE pivots the same exact dimensions for 13-17+ cars....there are 3 different versions of internal valvetrain components.
I want to confirm these 100% work for all years by confirming the engine pivots never changed. The kit from the OP seems to only have 1 version which supposedly covers all years.
'15 FRS - GLTC spec
The Following User Says Thank You to prandelia For This Useful Post:
Danny318 (10-01-2020)
Old 09-30-2020, 12:59 AM   #62
rixter145
Sleep Chomper
rixter145's Avatar
Honestly if I were going to open up the heads, I would get the retainer kit so I will never have to worry about staying in the high RPM. Otherwise, just get a 2017 long block spare in case you blow yours. (But this is more of a band-aid than solving the issue)
10W50 is a REALLY thick oil. Did you do any UoA on it after oil changes?
Old 09-30-2020, 01:02 AM   #63
rixter145
Sleep Chomper
rixter145's Avatar
Actually, he has both versions(I called him up and you can specify which one you want)
Old 09-30-2020, 01:23 AM   #64
prandelia
Drives: 2015 FRS
Def adding rocker stoppers to my next motor....
It's not really heavy oil at all for racing. Toyota Motorsports Germany, who builds, supports and races factory 86 cars in Europe uses 10W60 and now 5W50 in their motors w/ oil coolers. They won't go anything below 5W50, for proper oil pressure and oil films at high temps/RPM. I've spoken directly with their engineers who see everything from sprint and endurance racing motors, they vigorously recommend it. That's how they avoid spinning rod bearings at similar NA power levels...
This whole "tight clearance" it needs thin oil thing with this motor is a complete myth....10W40 or 5-10W50 racing oil in these cars at 200-230 deg. is right at home. Did a UoA early on and it was fine when I used 5W40, and TMG told me to bump up to any high quality XW50...been using it every since, rods seem to be happy.
'15 FRS - GLTC spec
The Following 2 Users Say Thank You to prandelia For This Useful Post:
PulsarBeeerz (09-30-2020), rixter145 (09-30-2020)
Old 09-30-2020, 11:11 AM   #65
prandelia
Drives: 2015 FRS
Depends on what temperature it is at.
This seems to get lost in this forum.
Use your engine as a viscosity test rig.
If you have 40psi at redline, your oil is the viscosity of water.
Bingo. Oil is rated at 212F. Know your temps and monitor pressure, and use the oil accordingly. At redline, my pressures are routinely 88-90+psi at 215-230 temps, I virtually never see anything over 230F. Care idles warm at about 18-19psi.
'15 FRS - GLTC spec
rixter145 (09-30-2020), solidsnake11 (10-01-2020)
Old 09-30-2020, 11:13 AM   #66
prandelia
Drives: 2015 FRS
Get the newest. Lash will need to be checked anytime you change(or change position) the pivot or rocker or valve.
that's my point. Are the pivots in this kit (http://denstoj.com.au/retainer-kit/) the same as in the '17+ cars, or the 13-14 cars?
If these OE pivots changed spec between 13-14, 15, and 17+ cars, then which pivots is Denstoj selling?
'15 FRS - GLTC spec
Old 09-30-2020, 11:17 AM   #67
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
They are not selling the pivots, you have to send them in to be modified. As far as I am aware the only change in pivots is the size of the oiling hole. The old part number supersedes to the newest last I checked. The early engines had different sized oil holes in each head. The newer ones have the same in both sides.
Old 09-30-2020, 10:19 PM   #68
prandelia
Drives: 2015 FRS
hmm, doesn't read that way to me. It would be terribly inconvenient to have to ship off your pivots to Australia and then wait to receive them back, before you can start building your motor back. That said, it would be the sure-fire way to ensure you get your same exact parts back.
I read it as their "kit" provides you with everything, and once you pull out your old pivots, to send them back to them as core returns. That's usually how a core refund works.
Regardless, I'm shocked nobody here in the USA has come up with a solution like this. I like this alot better than the AWD tuning rocker stopper solution.
'15 FRS - GLTC spec
Old 09-30-2020, 11:05 PM   #69
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I could be wrong. Won’t be the first time.
Old 10-01-2020, 12:20 AM   #70
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
The way it's explained on their website is that they ship everything to you and they refund you a core charge upon receipt of your parts, unless it's changed since I saw it
NoHaveMSG (10-01-2020)
Trans retainer cover Jcas Engine, Exhaust, Transmission 0 04-29-2019 05:24 PM
WTB: spare wheel retainer screw Pat Want-To-Buy Requests 4 04-06-2016 01:57 PM
Pop-Screw Retainer Size? FR-S Matt Scion FR-S / Toyota 86 GT86 General Forum 2 01-20-2013 11:48 AM
big black plastic retainer poormans_LFA BRZ First-Gen (2012+) — General Topics 66 02-11-2012 03:33 AM
