Old 09-18-2020, 10:07 AM   #43
Danny318
Drives: 2019 BRZ
Are there any “newer” engines that have had this issue ?
Danny318 is offline   Reply With Quote
Old 09-18-2020, 03:55 PM   #44
rixter145
Sleep Chomper
rixter145's Avatar
Originally Posted by solidsnake11 View Post
That is the new style rocker arm. For the rocker to jump out it has to have excessive clearance first. When they redesigned the valve train they increased the clearance at which the rocker arm would fly out. I would bet they changed the valve spring rate but I have not confirmed.
Examples of causes: Incorrect lash, valve float, broken valve spring, foriegn material on valve seat or bent valve.
The sr20de has this problem over 7400rpms when the valves float. Unfortunately the fa20 also has gravity working against it.
My shop is taking it out today to diagnose what the issue is. I am hoping that it's just the heads and then I can proceed to order the retainer kit... new heads and whatever components got messed.
rixter145 is offline   Reply With Quote
Old 09-18-2020, 04:25 PM   #45
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by rixter145 View Post
Wish I knew about this sooner...
I found that out the hard way...today... I literally just started the car, heard some sound... didn't think of it much and then on my 12 min drive to my appointment, i noticed smoke and a trail of oil... FML.
Terrible.. broken cast aluminum parts are the ugliest things ever. And comes with a side of heartbreak. Is that a chunk of the cylinder head or the valve cover?
Intent > Content
Old 09-18-2020, 05:10 PM   #46
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Hopefully. When mine popped out the rocker pivot came out too and I lost all oil pressure. It threw the rod when I was trying to get it shut off and in a safe spot on the side of the track. Hopefully your rod and mains survived. I did loose two at the same time, likely making it worse.
solidsnake11 (09-18-2020)
Old 09-19-2020, 02:45 AM   #47
rixter145
Sleep Chomper
rixter145's Avatar
Yeah it's a corner of the exhaust rocker, closest to the front of passenger side.
The Following User Says Thank You to rixter145 For This Useful Post:
solidONE (09-22-2020)
Old 09-19-2020, 02:47 AM   #48
rixter145
Sleep Chomper
rixter145's Avatar
Hopefully, shop's gonna take the oil pan off to see if there any metal shavings or where the rocker lash is. Will be sending it back to engine builder for repair and install retainer kit. I hope Australia shipping is quick.
Old 09-19-2020, 02:48 AM   #49
rixter145
Sleep Chomper
rixter145's Avatar
Originally Posted by mstoj View Post
So for those interested, Subaru/Toyota updated the rockers and pivots but the change didn't combat the issue we're seeing in the video (it was mentioned earlier that the change was for the oil). The height of the pivot didn't change, meaning that retaining kit can be used on any model year.
Note, it's important to check valve clearances during installation and swap out the lash adjuster buckets if required. This is unlikely if each lash adjuster bucket is returned to the original valve.
FYI, the engine in the video was factory sealed.
I have reached out to you by email! Looking forward to getting my hands on a set. Thanks
Old 09-19-2020, 12:11 PM   #50
Danny318
Drives: 2019 BRZ
Can they be installed with engine still in car?
Old 09-19-2020, 12:40 PM   #51
kevaughan
kevaughan's Avatar
Drives: BMW E30, 2014 FR-S
No.
kevaughan is offline   Reply With Quote
Old 09-27-2020, 06:46 PM   #52
soundman98
ProCrastinationConsultant
soundman98's Avatar
the valve covers need to come off the sides of the motor.
better to pull the motor than be a glutton for punishment trying to get anything past the frame rails.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
Danny318 (09-28-2020), DarkPira7e (09-27-2020)
Old 09-29-2020, 12:40 AM   #53
prandelia
Drives: 2015 FRS
Interesting. I just brought up this very topic while discussing a full long-block build with IAG, and they seemed have no concern for this issue when using the 17+ valvetrain parts with heavier beehive springs.
'15 FRS - GLTC spec
YouTube channel race vids: https://www.youtube.com/channel/UClU...phsppnA/videos
prandelia is offline   Reply With Quote
Old 09-29-2020, 02:32 AM   #54
rixter145
Sleep Chomper
rixter145's Avatar
On my rebuild I am using 17+ valvetrain parts and non beehive springs, they are GSC-5756. But it still fell off. I mean if you are OK with taking the risk then go for it, but for an extra $450, I rather have a peace of mind.
Considering I am taking the engine out and shipping it back to put those retainer kits back on, this is a no brainer investment.
Old 09-29-2020, 10:42 AM   #55
prandelia
Drives: 2015 FRS
Good to know, thanks. Interestingly enough, I also questioned IAG's use of such heavier valve springs (about 90lbs seat) vs stock (about 50lbs seat) for an NA car. When I spoke with Element tuning about valve springs, they still recommended using a very light upgrade such as the Ferrea 60lb single (even for high hp), and they still do some sort of rocker stopper as well.
Makes me wonder if this is also somehow related to these significantly higher valve springs being used in rebuilds?
'15 FRS - GLTC spec
Old 09-29-2020, 11:10 AM   #56
rixter145
Sleep Chomper
rixter145's Avatar
It's for people who stay at the higher rev range to eliminate valve float. I am unsure if the Ferrea springs will stay shut for that application but if you are in the rebuilt route, might as well get a heavier spring and retainer
Trans retainer cover Jcas Engine, Exhaust, Transmission 0 04-29-2019 05:24 PM
WTB: spare wheel retainer screw Pat Want-To-Buy Requests 4 04-06-2016 01:57 PM
Pop-Screw Retainer Size? FR-S Matt Scion FR-S / Toyota 86 GT86 General Forum 2 01-20-2013 11:48 AM
big black plastic retainer poormans_LFA BRZ First-Gen (2012+) — General Topics 66 02-11-2012 03:33 AM
