Drives: FR-S White - Smexy.
Fuse #4, TAILS
Hi... I don't know how to start this so I'm just gonna get straight to the point
Yesterday at night my girlfriend (who was following in another car) noticed all my lights were off. Valenti Taillight's Boomerangs were off, my side markers were off and my Front turn signals (Daylight running fogs) along with my BRZ Headlight DRL Boomerangs were off. After googling a few topics I ran into a thread here. Stating similar things have happened to other users. They looked at the internet fuse box and noticed fuse #4 for "TAILS" was the culprit. A few minutes ago, I went to Autozone, purchased the same Red - 10Amp - Low Profile fuses to replace the blown out fuse (which it was cuse the middle bridge on the fuse was burnt and severed incase any one else runs into this problem). After swapping it out and testing the lights the fuse burnt out immediately. I burnt 3 separate fuses already and have not come fixed this problem. Unfortunately for me electrical problems are things I have not come across yet... Please tell me there's someone else on here that has dealt with this. The likely suspect to me are anything associated to fuse #4, along with the Hyperflash Relay I bought aftermarket via ft86speedfactory. Before I try anything crazy can someone confirm what I should do step by step so I don't mess this all up? :/ I haven't touched ANYTHING electrical related in YEARS. the last time I touched anything were my two shitty ebay sidemarker LEDs that just burn out all the time. (MAYBE THIS IS THE PROBLEM?!?! XD ) Last edited by SmireyFase; 09-28-2020 at 10:04 PM. |
#2 |
Drives: 2013 frs raven
If you have tapped into any wire anywhere. I would start there, probably touching metal somewhere. Had the same issue with my reverse lights a few months ago.
| The Following User Says Thank You to Gloonge For This Useful Post: | humfrz (09-28-2020) |
#3 | |
quit putting fuses in it till you find the short.What is the last (even non-electrical) thing you did with your car? I'd suggest you start looking around there. If you don't find it, start visually tracing the circuits that fuse controls, looking for a burnt spot or a blackened wire. Bubba suggests you put a 30 amp fuse in that slot then look for sparks or a smoking wire. He always does this when the car is outside and he has a BIG fire extinguisher handy - ![]()
#4 | |
| The Following User Says Thank You to SmireyFase For This Useful Post: | humfrz (09-29-2020) |
#5 |
Site Moderator
Drives: Stuff
And you can start unplugging lights to see if one has a short internally. Do those valentis have a switch? If so it's possible one of the leads for it is shorting assuming they carry full voltage (never checked).
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
| Dashboard fuse box - mini fuse removal | airrick | Electronics | Audio | NAV | Infotainment | 0 | 10-25-2019 06:05 PM |
| WTT: My Valenti tails for '17 stock tails (MD/VA/S. PA areas) | PR138 | Want-To-Buy Requests | 8 | 02-12-2018 04:57 PM |
| Trade: Black Spyder V1 Tails for Tom's Tails | Cross | Exterior Parts (Aero, Lighting, Etc.) | 3 | 07-05-2014 05:19 PM |
| Tails Fuse Location | Ryeong86 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 06-18-2013 03:49 PM |
| WTT: MY USDM Tails for your JDM/ADM/UKDM Tails | ZC6BRZ | Exterior Parts (Aero, Lighting, Etc.) | 2 | 01-16-2013 12:24 PM |
