Old 09-24-2020, 05:29 PM   #15
yzf219
Drives: 2013 FRS GTX3076R
They may have just been doing inserts instead of the whole bushing. I’d be surprised if these came out easily on a new car.
Yea it doesn't seem possible without removing the subframe. What bushings did you end up going with?
Sent from my SM-G950W using Tapatalk
yzf219 is offline   Reply With Quote
Old 09-24-2020, 06:00 PM   #16
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I am using the SPL solid mount bushings.
https://www.counterspacegarage.com/s...shing-ssb-gt86
Old 09-24-2020, 07:23 PM   #17
Haha thanks. Just got the car and noticed that there is excessive amounts of driveline slop during on/off throttle application. It's probably normal amounts, but my last car had poly diff bushings and I really liked how solid it felt.
How many miles on your car?
Have you compared it to another 2013 FRS, for perceived driveline slop?
Old 09-24-2020, 08:16 PM   #18
yzf219
Nice, I was leaning towards solid bushings as well.
Old 09-24-2020, 08:17 PM   #19
yzf219
34k kms, I've driven others, it's the normal amount of driveline slop. I'm just used to poly mounts on my old car. Wanted a similar feeling in the FRS.
The Following User Says Thank You to yzf219 For This Useful Post:
humfrz (09-25-2020)
Old 09-24-2020, 08:31 PM   #20
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You pick up a lot more NVH from them. My car is still street driven and sees some track time. I think for my taste is a bit overkill. As @humfrz mentioned about drivetrain slop. You may try stiffer trans bushings and some STI motor mounts first. They really take out the drivetrain slop and are an easier install. The biggest thing I noticed with the subframe bushings is a more solid feel and more of a communicative feel from the rear of the car while driving it hard.
humfrz (09-24-2020)
Old 09-24-2020, 10:25 PM   #21
yzf219
I'll look into those options too, I think my car already has an insert for the trans bushing from the previous owner.
Notching Rear Subframe ShutterSpeed Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 08-02-2020 09:27 PM
WTB factory rear subframe Deezee Want-To-Buy Requests 0 01-24-2020 01:00 PM
Tubular rear subframe Manji Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 09-24-2014 08:23 PM
rear subframe bushings? Roadcone Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-09-2014 09:25 PM
REVIEW | DC Sports rear subframe brace / rear subframe lateral brace mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 04-10-2014 08:59 PM
