Old 09-08-2020, 02:16 PM   #1
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Can anyone confirm if TWS T66-F Wheels 18x9.5 +45s clear Brembos?
If car has coilovers? Searched all over & could not get confirmation.
TIA
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
Old 09-08-2020, 05:28 PM   #2
CSG Mike
CSG Mike's Avatar
Yes it does.
GTB/ZR-1 (09-08-2020)
Old 09-08-2020, 08:09 PM   #3
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Yes it does.
Assuming you know about more wheels than already listed on this post, the community would definitely appreciate if you could share more info on that thread.
Old 09-24-2020, 06:17 PM   #4
GTB/ZR-1
GTB/ZR-1's Avatar
Well... I just pulled a trigger on a set--so I sure hope they'll clear lol
Seriously, per their site, they will.
I'll post up pics once mounted to verify.
Old 09-24-2020, 06:50 PM   #5
CSG Mike
CSG Mike's Avatar
You got some BADASS wheels.
With the +45 offset, depending on the tires you run and/or suspension, you may want to run spacers to not rub the tire at full lock.
Old 09-24-2020, 08:39 PM   #6
GTB/ZR-1
GTB/ZR-1's Avatar
Got them for the (lack of) weight.
MCS coilovers & 275s (actually A052s Yoks in 265, but they're as wide as most 275s). Will be running -3 in front & -2 rear. Should I be able to get by without rolling? Thanks.
Old 09-24-2020, 08:52 PM   #7
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
You might rub the inner tire on the coilovers with 275s.
Mike_ZN6 is offline   Reply With Quote
Old 09-24-2020, 08:57 PM   #8
CSG Mike
CSG Mike's Avatar
your issue is inboard, not outboard.
Old 09-24-2020, 09:04 PM   #9
GTB/ZR-1
GTB/ZR-1's Avatar
^^^ thinking abt that, too. Ran +42 Mach V 18x9.5s w/ 275 Hoosiers on my old Turbo FR-S & no issues. But... Was only running ~-2.3in front w/ that setup. -3 may be an issue. So a 3mm spacer effectively gets me back to +42.
Thanks, guys...
Old 01-11-2021, 08:57 PM   #10
GTB/ZR-1
GTB/ZR-1's Avatar
Confirmed: yards (or at least fingers) to spare for clearance.
Getting some rubbing, but trying to determine where. The car may be a bit too low in the front. Will try raising it slightly to see if that works. Running -3.2 degrees camber up front.
Rears have zero issues w/ -2.2
265 Yoko A052s square setup.
Very neutral setup & fantastic turn-in.
The Following 2 Users Say Thank You to GTB/ZR-1 For This Useful Post:
CSG Mike (01-12-2021), timurrrr (01-11-2021)
Old 01-11-2021, 09:13 PM   #11
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Thanks for the info, added to the PP Brembo thread
The Following User Says Thank You to timurrrr For This Useful Post:
GTB/ZR-1 (01-12-2021)
Which wheels clear 17+ BRZ Performance Package Brembos timurrrr Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 381 11-03-2025 04:30 PM
Finding wheels to clear brembos jojosbrz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 11-13-2018 08:46 AM
Aftermarket lug nuts on stock wheels: confirm? empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 09-19-2018 07:38 PM
Do BRZ/FRS/GT86 wheels fit over rear Brembos? Elliotw Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 06-13-2018 04:30 PM
just to confirm..about 15inch wheels thebus Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-07-2014 04:32 PM
