Old 09-24-2020, 03:21 PM   #85
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
Damaged or not, that would be pretty cool if my S13 transformed into an S14 at the end of a drift season.
The Following 3 Users Say Thank You to KR-S For This Useful Post:
ElijahF (09-24-2020), JesseG (09-24-2020), p1l0t (09-24-2020)
Old 09-24-2020, 04:18 PM   #86
p1l0t
p1l0t's Avatar
Assuming the frame is straight... yeah.
Old 09-24-2020, 05:40 PM   #87
pallen
pallen's Avatar
Drives: 2017 Toyota 86
It does get old with this car. I have to do grocery runs late at night when I know there will be plenty of room for all the sliding around. Insurance was getting out of hand.
pallen is offline   Reply With Quote
The Following 3 Users Say Thank You to pallen For This Useful Post:
JesseG (09-24-2020), soundman98 (09-24-2020), WildCard600 (09-24-2020)
Old 09-24-2020, 07:39 PM   #88
JesseG
JesseG's Avatar
Drives: 2016 Scion FR-S
I have a switch for full disable of TC
Does the switch do the same thing as the “pedal dance”? I haven’t ever fully disabled TC.
JesseG is offline   Reply With Quote
Old 09-24-2020, 07:41 PM   #89
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yes, switch initiates PD.
Old 09-25-2020, 12:36 PM   #90
Sasquachulator
Pavement Grey
The missing piece of information is that you crashed the car 2 or 3 times and you had to replace it each time. So by the end of the drift season yes, you actually did move from an S13 to an S14
The Following 3 Users Say Thank You to Sasquachulator For This Useful Post:
KR-S (09-25-2020), p1l0t (09-25-2020), WildCard600 (09-25-2020)
Old 09-28-2020, 02:09 PM   #91
Bluefire98
Drives: 2015 Scion FRS
Yes these are so much fun to pull off some mad skidz in, but even on oem tires, you have plenty of grip for the street. This isn't some prepped dirft car from the factory that doesn't want to through a corner any way other than sideways. I'd say the twins are remarkably stable at freeway speeds considering the weight. Trust me, it won't be an issue even with tc off.
Bluefire98 is offline   Reply With Quote
Old 09-28-2020, 02:19 PM   #92
Bluefire98
Btw only drive with the tc off. Ya never know when you get to hit an empty freeway on ramp ======///////=====hehehehe
Old 09-29-2020, 12:44 PM   #93
Suapak
Drives: White
And how about the "shift lock"? I heard in video that if you downshift from high rpms the car automatically locks rear wheels to get you into the drift (Subaru brz video). How does it work? Is it enabled only in "track mode" or is there any way how to turn it off?
Btw. is there any "grip" differences in BRZ, GT86, FR-S?
Suapak is offline   Reply With Quote
Old 09-29-2020, 01:15 PM   #94
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That sounds like a good way to end up with "engine lock"
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post:
soundman98 (09-30-2020), Spuds (09-30-2020), Ultramaroon (09-30-2020), WildCard600 (09-29-2020)
Old 09-29-2020, 01:21 PM   #95
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Wouldn't locking the rear diff on deceleration make the car understeer like a pig?
In stock trim the FRS has stiffer rear springs and softer fronts which make the rear end more tail happy. BRZ/86 have a closer F/R balance which is more neutral but still a touch softer in the front.
Old 09-29-2020, 01:35 PM   #96
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Shift lock does not "lock" the rear wheels. If you bang the car down into a lower gear without rev matching, sometimes the engine does not get dragged up to speed quick enough to match the speed the car is traveling and it will break traction. This is why a RWD car will spin during a money shift.
Bluefire98 (09-29-2020), soundman98 (09-30-2020), Spuds (09-30-2020), x808drifter (09-29-2020)
Old 09-29-2020, 03:11 PM   #97
Bluefire98
If you haven't already OP, take one for a test drive and see what you think. If you drive a manual older impreza, the clutch will feel a bit familiar, but everything else is proper sports car ergonomics and feel.
Old 09-29-2020, 03:15 PM   #98
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
To elaborate more.
A shift lock initiation is done by downshifting mid turn without rev matching.
The sudden jolt to the driveline can cause the rear tires to lose grip.
Not nice to the drivetrain at all.
And yes, locking on decel can cause understeer.
The Following 2 Users Say Thank You to x808drifter For This Useful Post:
NoHaveMSG (09-29-2020), soundman98 (09-30-2020)
If Anyone's Interested... MuseChaser Scion FR-S / Toyota 86 GT86 General Forum 13 05-01-2018 09:02 PM
2 LCA I am interested in. DriftEightSix Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 02-17-2014 05:05 AM
Anyone interested in doing a dent day? YDNA Southern California 22 11-19-2013 04:10 AM
Who would be interested in this ? Garstang Scion FR-S / Toyota 86 GT86 General Forum 1 11-05-2013 01:27 AM
