Old 02-13-2014, 05:55 AM   #1
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
2 LCA I am interested in.
Can someone please tell me the pros and cons for the shape difference.
Goal: I am lowering the car about 20mm-30mm(not that much).
Wanting to fit nice 17x9+35 wheels so want LCA to help achieve the -2 to -3 camber required.
What is the difference with the Racer X:
& the
Voodoo13?
Voodoo have a steeper middle section what does this help with?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 02-13-2014, 06:16 AM   #2
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by diss7 View Post
You're right. But its no worse than any other lowering at the same height. The advantage of this setup, is you can have a ride height at say 40mm lower, but with the shock travel of a setup with 15mm lower. (Or what ever the figures work out to be)
DriftEightSix (02-13-2014)
Old 02-13-2014, 06:26 AM   #3
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Voodoo is basically a copy of stance. It lowers car by "x amount" as the bottom of strut is physically lower. Made to allow more stroke for coils like KW, ST and others by that design. Coil choice is important when choosing between the two styles you show.
The Following User Says Thank You to OICU812 For This Useful Post:
Old 02-13-2014, 06:41 AM   #4
DriftEightSix
Pegasus White
Drives: 86
I will be getting the MAC Blues - http://mcasuspension.com/blue-series/
Old 02-13-2014, 06:49 AM   #5
OICU812
Just a dude
OICU812's Avatar
In such case consider the racerx over voodoo.
MCA I never heard of them, but they're like rsr in how they height adjust, hence the racerx style would be more suited given your height desires etc..
Old 02-13-2014, 06:53 AM   #6
OICU812
Just a dude
OICU812's Avatar
Btw with that wheel offset and size "same as mine" currently you'd be fine at -1.5 camber all around unless you want to track it, then of course up to -2.
Old 02-13-2014, 07:00 AM   #7
DriftEightSix
Pegasus White
Drives: 86
cool! beans will await Racer's reply on shipping costs ahah
thanks for the advise (they are an Australian Brand is why you might not of heard of them)
what else have you had to do to dial the camber in?
Old 02-14-2014, 05:50 AM   #8
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Just get std style ones. It changes the shock length set by MCA if yo go the stance style. You would need to adjust the lower collar to compensate for this with the MCA struts.
Ultimately if doesn't matter with coilovers as you can adjust them to compensate anyway. But why make work for yourself!
86•BRZ is offline   Reply With Quote
The Following User Says Thank You to 86•BRZ For This Useful Post:
DriftEightSix (02-17-2014)
Old 02-14-2014, 06:04 AM   #9
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
http://www.motoiq.com/MagazineArticl...ilvia-S13.aspx
Great story.
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
Anthonytpt (02-14-2014), u/Josh (02-17-2014)
Old 02-14-2014, 11:13 AM   #10
OICU812
Just a dude
OICU812's Avatar
Originally Posted by mav1178 View Post
Lol that's some wild aero and ya interesting, thanks!!
Old 02-14-2014, 12:08 PM   #11
OrbitalEllipses
Drives: Attitude
Good read.
Old 02-17-2014, 05:05 AM   #12
Crossover Auto
Drives: FR-S, BR-Z, 86
Just some clarification from Voodoo13. The Voodoo13 control arms have 18mm of drop built into them and the design has changed quite a bit since those photos were taken. The Voodoo13 arms have 3 positions for shock mounting including a wide range of camber adjustment.
Crossover Auto is offline   Reply With Quote
The Following User Says Thank You to Crossover Auto For This Useful Post:
Anyone interested in doing a dent day? YDNA Southern California 22 11-19-2013 04:10 AM
Who would be interested in this ? Garstang Scion FR-S / Toyota 86 GT86 General Forum 1 11-05-2013 01:27 AM
Anyone Interested in a GB for the OEM underpanel kit? xDBOYx NY / NJ / CT / PA 29 09-24-2013 12:26 AM
Interested in buying an FR-S... Thanntos Scion FR-S / Toyota 86 GT86 General Forum 44 07-15-2012 08:54 PM
