Old 09-23-2020, 10:57 AM   #1
R2R
Drives: GT86 TRD CUP
2018 Diff swap
Hi, everyone, we have a 2014 86 with the "basic basic option" used by TMG to develop their race version for europe
It's a 3.7 gear ratio and open diff.
We would like to upgrade to a torsen and a shorter gear ratio, and I found this diff here for a very good price.
It's from a 2018 Auto version, so the ratio is 4.1 instead of 4.3 (that would have been better) but this won't bother us too much.
is there a way to confirm if this is what we are looking for (torsen and 4.1 ratio) and will it be bolt-on on our 86? thank you so much for your support
Marco
R2R is offline   Reply With Quote
Old 09-23-2020, 11:30 AM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I believe that is the diff you are looking for. The 4.1 w/torsen that came out of my car was also a Y38.
Picture in this post when I sold it.
https://www.ft86club.com/forums/show...47&postcount=1
Old 09-23-2020, 02:08 PM   #3
R2R
Thanks! Is it an easy swap on a MT?
Old 09-23-2020, 02:14 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It is not very difficult. I had the car on jack stands and used a floor jack to support the diff during removal/assembly.
Old 09-23-2020, 02:45 PM   #5
R2R
Great. I just wanted to make sure it's bolt on
Old 09-23-2020, 03:30 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Just be sure to inspect the new diff before install. Check that the two bushings are in good shape and that the seals for the CV axle look okay. I replaced the seals on mine before install just to be sure, though I probably didn't need to.
Tcoat (09-25-2020)
Old 09-25-2020, 10:14 AM   #7
R2R
Got it, thanks! will install it and give you a feedback
thank you so much
The Following 2 Users Say Thank You to R2R For This Useful Post:
bcj (09-25-2020), NoHaveMSG (09-25-2020)
2017 diff swap JOE APO Engine, Exhaust, Transmission 97 11-18-2017 08:32 PM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Swap AT Diff with MT Diff sydious Engine, Exhaust, Transmission 2 03-17-2016 02:59 PM
RR Diff swap Triumphrider Engine, Exhaust, Transmission 25 10-21-2014 08:34 PM
Diff swap help wootwoot Engine, Exhaust, Transmission 30 06-10-2013 11:05 AM
