Old 03-14-2014, 02:16 AM   #1
ikkomaji22
ikkomaji22's Avatar
Drives: Subaru brz
Exhaust tips question?
Hey guys i was wondering if its possible to cut or remove stock exhaust tips and have the Perrin 4inch tips welded on instead of the clamp install option?? just dont want all the noise and attention aftermarket exhaust bring...
ikkomaji22 is offline   Reply With Quote
Old 03-14-2014, 02:17 AM   #2
dirtymax
Gold Member
dirtymax's Avatar
Drives: 14' SWP BRZ MT limited
why weld them?
dirtymax is offline   Reply With Quote
Old 03-14-2014, 02:19 AM   #3
dirtymax
Gold Member
dirtymax's Avatar
I have the Perrin tips and you can weld them if you want
The Following User Says Thank You to dirtymax For This Useful Post:
ikkomaji22 (03-14-2014)
Old 03-14-2014, 02:27 AM   #4
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
Why weld them? If you ever decide to get an actual exhaust you can remove the Perrin tips still and sell them for like $140-$150ish. Doubt anyone would want your stock exhaust with the tips welded.
ericmpena is offline   Reply With Quote
The Following User Says Thank You to ericmpena For This Useful Post:
Old 03-14-2014, 03:11 AM   #5
suaveflooder
One bolt and the old exhaust tips pull off. One clamp and your new perrin tips go on. Done
suaveflooder is offline   Reply With Quote
Old 03-14-2014, 05:55 AM   #6
ikkomaji22
ikkomaji22's Avatar
Drives: Subaru brz
Originally Posted by dirtymax View Post
why weld them?
Just wondering cause I've seen them installed and they have that screw sticking out the side.. Kinda looks ugly no?
Old 03-14-2014, 09:49 AM   #7
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
I used these: http://vibrantperformance.com/catalo...products_id=78
If you can weld there's no sense in spending twice as much on the perrin ones with a clamp and a fancy logo.
kask2_6.0 is offline   Reply With Quote
Old 03-14-2014, 09:53 AM   #8
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
I broke my bolt off and had to weld my 4" tips. Hopefully you're luckier that me
Old 03-14-2014, 10:44 PM   #9
ikkomaji22
ikkomaji22's Avatar
Drives: Subaru brz
So you welded them after they broke off? How does it look?
Old 09-23-2020, 02:49 AM   #10
Sam86
Drives: Toyota 86 GTS
Just wanted to bump as I have my own question regarding this.
I bought some dual exhaust tips that I wanted to clamp onto my aftermarket axel back- which also isn't installed- however the inlets of the exhaust piping and tip are the same so I can't slip it over. Regardless if I could, the exhaust tip itself is too large.
The only option I have is to get it welded, but i'll likely have to get some of the piping from the axelback cut down as cutting the exhaust tip itself won't be enough.
I don't know the process of going to a muffler shop, so should I get my axelback installed first, and then take it to the muffler shop to be welded- or leave it uninstalled, and take it and the exhaust tip there for welding and then install it after?
Ideally i'd like to do the second option however I'm really worried about the tip length being too long and not sure how they'd go about mocking up the sizing when the axelback isn't currently on the car.
Sorry if that explanation is confusing
Sam86 is offline   Reply With Quote
Old 09-23-2020, 07:57 AM   #11
The other alternative is to just bolt the sleeve on the tip and pipe and then if you want to change the tip later you are not dealing with welds.
The best method is a combination of both. The exhaust should be in place so the shop can make sure the tips are positions properly. Then it should come off for the actual welding.
The best method would be for them to place a sleeve over both the tip and the pipe to strengthen it. A butt weld could be a bit iffy since the pipe material is thin.
Sam86 (09-23-2020)
Old 09-23-2020, 11:12 AM   #12
ls1ac
ls1ac's Avatar
We tack in place then remove and "butt" weld. Same as making headers. No problem.
The Following 2 Users Say Thank You to ls1ac For This Useful Post:
Sam86 (09-23-2020), soundman98 (09-23-2020)
Old 09-23-2020, 11:47 PM   #13
Sam86
Am I going to run into many complications with the length of my tip being too long? it's about 8.5 inches, and is meant to slide over the exhaust piping to be clamped. It can't however, as the tip doesn't have a relief cut. Even assuming it did have a relief cut, it's still an extra 1- 1.5 inches longer than the stock single outlet tip.
(I've had a very hard time finding a dual outlet exhaust tip that was less than 9-10 inches in length, 8.5 was the smallest I could find)
The only solution I can see involves the exhaust piping from my axelback itself to be trimmed down :/
Old 09-23-2020, 11:49 PM   #14
Sam86
Hope I can be somewhat present then despite COVID as my axelback has a valve system motor connected with wiring running into the boot that will be very problematic if they accidentally damage upon removal/ reinstallation
WTB: Exhaust tips retrosmiths Want-To-Buy Requests 1 10-05-2013 06:41 PM
FS: JDM Exhaust Tips forwallblakmail Exterior Parts (Aero, Lighting, Etc.) 6 09-05-2013 01:42 AM
WTB: DC Exhaust Tips or Other Tips Xdragonxb0i Engine, Exhaust, Bolt-Ons 2 05-10-2013 07:36 AM
JDM GT86 Exhaust Tips question.. VADER Engine, Exhaust, Transmission 1 07-02-2012 09:12 PM
