go_a_way1, MisterSheep
Old 09-21-2020, 12:05 PM   #22345
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Sure. They will only last 35 years instead of 40. I'm sure the pads will still be there when the car is long dead.
See. that's exactly what my issue is. They should last at least 80 years!
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
The Following User Says Thank You to Wally86 For This Useful Post:
Sapphireho (09-21-2020)
Old 09-21-2020, 12:48 PM   #22346
So half a Humfrz lifespan?
Ultramaroon (09-30-2020), Wally86 (09-21-2020)
Old 09-21-2020, 01:23 PM   #22347
DarkSideFRS
Drives: 2013 pearl white FR-S
Planning on selling it
DarkSideFRS is offline   Reply With Quote
Old 09-21-2020, 02:33 PM   #22348
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
Finally installed my Crawford Performance Power Blocks.
I'm fully expecting at least 100+hp gains with these.
Pretty well hidden unless you really search for them. No issues with the strut tower brace.
MJones_RB is offline   Reply With Quote
The Following User Says Thank You to MJones_RB For This Useful Post:
FLIPDADY (09-22-2020)
Old 09-21-2020, 03:20 PM   #22349
JD001
JD001's Avatar
Drives: Subaru BRZ
You've got the goddamn "red" version, it is worth more BHP than what you're expecting. Take it easy until you get used to the POWER! Keep it clean and it'll keep giving.
The Following 2 Users Say Thank You to JD001 For This Useful Post:
FLIPDADY (09-22-2020), MJones_RB (09-21-2020)
Old 09-22-2020, 12:38 PM   #22350
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
I bet he backflips his car first day and blames the curse.
The Following 3 Users Say Thank You to Wally86 For This Useful Post:
JD001 (09-22-2020), MJones_RB (09-22-2020), Tcoat (09-22-2020)
Old 09-22-2020, 01:53 PM   #22351
Time to rebadge
MJones_RB (09-22-2020), soundman98 (09-22-2020), Ultramaroon (09-30-2020), Wally86 (09-23-2020)
Old 09-23-2020, 03:41 PM   #22352
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Originally Posted by FLIPDADY View Post
Installed this little guy. Best $25 spent so far on this car.
Sent from my LM-G900 using Tapatalk
Great if you want to slam your hand in the trunk. Would end up pulling it down and then pushing from above anyway.
Edit: What Wally said!
I installed one (paid a little less for it) and I'm glad I did. It's not like our trunk lid weighs 80 lbs or comes down with any appreciable force...unless you're trying to break the sound barrier when you push/pull on it. I'm able to pull on the handle and have my hand well clear of the lid before it closes, no ninja speed required. Once it's moving it pretty much free falls closed. I can appreciate not having to touch the outside of the car lid, especially around here in the wintertime when my car tends to be perpetually dirty and/or salt covered no matter how often I clean it.
Installed it on the right side of the lid for weight balancing purposes since I'm usually driving solo. Every little bit helps.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
The Following 2 Users Say Thank You to Overdrive For This Useful Post:
alex87f (09-28-2020), Tcoat (09-23-2020)
Old 09-23-2020, 04:26 PM   #22353
Overdrive
Sittin' Sideways
Overdrive's Avatar
Finally installed my fog light kit last weekend. Everything dropped in very well, I really can't be disappointed with it at all for an inexpensive aftermarket kit, and can't knock getting an OEM switch with it as part of the kit. It gave me a good reason to go get an OEM switch bezel for a fog light equipped car from eBay.
I tossed the crappy bulbs that came with them and put in some OLM brand LEDs that color matched perfectly with the parking lights. I was going to tolerate having the OEM low beams in place for now, but my buddy who helped me do the install happened to have the right size LED bulbs to drop into the low beam sockets collecting dust in his garage, so now everything matches up very well and it looks like a 21st century car. The low beam bulbs are not exactly the same white color as the four lower lights, but it's close and looks way better than the OEM low beams did (not that the supplied pics show that well, has to be seen with the naked eye). Definitely happy with the results.
Pics are of the finished job and a sort of before and after for the low beam swap. My apologies for the terrible quality. My phone's main camera is dying a slow and terrible death, so I did what I could taking pics with the front facing camera.
-O/D
2016 FR-S, Hot Lava
beltax90 (09-26-2020), MJones_RB (09-24-2020)
Old 09-26-2020, 10:26 AM   #22354
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
It's that time of year...
I ordered a fresh set of winter tires. Went with continental VikingContact7's. Said to be better than the pirellis I had on previously which I find hard to believe.
Old 09-27-2020, 11:31 AM   #22355
mrg666
pessimistic skeptic
mrg666's Avatar
Sea-foam'ed and oil changed. After Sea Foam, engine is running and idling so much smoother. Highly recommended if the engine is over 50K
Old 09-27-2020, 12:48 PM   #22356
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
There are so many different ways to introduce Seafoam's product- what path did you walk? I've used Seafoam on a few old M50 BMWs and saw a large difference. Newer cars with less than 150k that run only full synthetic I wouldn't think have any appreciable buildup
mrg666 (09-27-2020)
Old 09-27-2020, 12:54 PM   #22357
mrg666
pessimistic skeptic
mrg666's Avatar
A 16 oz. bottle is perfect for 4oz. into the oil and 12 oz. into full fuel tank. I changed the oil after using half of fuel since I didn't want to drive with all that sludge in the oil. Engine was already running remarkably better. Drained oil color was very dark. I think the remaining half tank will work a little more on the injectors if the full cleaning is not already done. But the engine is running so much better, I am falling in love with this car all over again.
The Following 3 Users Say Thank You to mrg666 For This Useful Post:
DarkPira7e (09-27-2020), jflogerzi (09-27-2020), RToyo86 (09-27-2020)
Old 09-27-2020, 01:10 PM   #22358
RToyo86
RToyo86's Avatar
I did it with my integra through the vacuum lines and noticed a difference. Also the huge plumes of white smoke out the back. The people watching me leave must have been confused as hell
The Following User Says Thank You to RToyo86 For This Useful Post:
mrg666 (09-27-2020)
