Old 09-19-2020, 03:07 AM   #1
Pizzachicken
Drives: Asphalt '16 FRS
E85 LTFT Above 10% at Idle
Hello, another fuel trim thread here.
I read all that I could understand about expected fuel trims for running on e85, but it seems like my LTFT hovers anywhere from +7% to +15%, averaged at 12%, never any lower than 7 at idle. Stock intake, just header and catback. Checked for exhaust leaks and none that I saw. It drops upon load and gets to ~5% @ 3k rpm so I assume that part is good. This happens across multiple fill ups, and fluctuates within the same tank/different days.
I've read that temperature can skew readings a bit and idle isn't crucial, but also that it should be within +/- 10% throughout. So why would this be and is it something to look into? Does this indicate a leak or would that be more severe values? Any suggestions? Thanks.
https://datazap.me/u/pizzachicken/9-...og=0&data=1-11
Pizzachicken is offline   Reply With Quote
Old 09-19-2020, 08:42 PM   #2
dholloway543
Software Hobbiest
Drives: 2015 FRS
If this is a flex fuel tune and your running a flex fuel sensor then your fuel trim can be up to around 10% ltft on one fuel and zeroed on another fuel. This is usually normal.
dholloway543 is offline   Reply With Quote
Old 09-19-2020, 08:54 PM   #3
Pizzachicken
O this is the base map OFT, no flex kit.
Old 09-20-2020, 06:43 AM   #4
steve99
Drives: FT86
oft tunes have lowest fuel trims arround 70-75% ethanol if you hapoen to have true 85% ethanol then you will get high positive fuel trims
Old 09-20-2020, 02:53 PM   #5
Pizzachicken
Hi Steve. A majority of my understanding of e85 is from your work on this forum actually so thank you.
Perhaps I'm interpreting your instructions wrong, but shouldn't "normal" ltft values stay within +/- 10%? Suppose it's possible I'm getting true 85% but these higher trims seem to be consistent throughout multiple fill ups and different stations rated for e70% - e85% (Los Angeles). So you're saying seeing up to 15% ltft at idle should not be alarming? If so i'll take your word. Would there be a max ltft % to allow before being concerned, and if so what else should I look into then?
The Following User Says Thank You to Pizzachicken For This Useful Post:
steve99 (09-20-2020)
Old 09-20-2020, 06:13 PM   #6
steve99
Drives: FT86
if you have stock intake and no leaks intake or exhaust +15 is a little unusual. The leaks wont be huge and often hard to detect. From the logs it does look like a leak as trims are only high at idle then ok once rpm rises and you on throttle
Old 09-20-2020, 06:27 PM   #7
Pizzachicken
Would high positive trims most likely be exhaust leak then or can it be intake as well? Believe I've seen you say intake leaks result in negative trims. I couldn't find any leaks at the flanges, unless it's a crack within the wrapped header piping or the shielding of the overpipe.. thought that was unlikely. Any other reason if I absolutely can't find a leak? And anyhow, is it safe to drive for the time being if it's just at idle? Thanks.
Old 09-22-2020, 06:26 AM   #8
steve99
Drives: FT86
yes it would be safe to drive if its only big trim at idle
exhaist and ibtake leaks can send ltft high positive at idle it only takes a small leak
Old 09-28-2020, 02:09 AM   #9
Pizzachicken
Hmm not really figuring this one out thus far, cannot find leaks. I've been monitoring more on the same tank this week. My trims are at 7% and stays around here instead of seeing a wide variance on/off throttle, at first. But after some driving, say 15 mins, I can watch ltft creep to 12.5% at idle and stay there, and then we can see the wide variance. Turn off car and let cool down for a bit, it's back to 7. Seems like temps has a role?
Also, if I happen to figure out a fix, can I expect to see it reflected in the trims immediately or would I have to get some miles in?
Old 09-28-2020, 07:16 AM   #10
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
I also just switched to E85 with the 4.0x tune and am experiencing the same thing. No exhaust leaks. I haven't been able to monitor the WOT LTFT but next time I am at the track I will try to remember. Seems to be performing great. Solid boost over 93. Only other thing I have noticed since making the switch is that it takes the car a little longer to start. Otherwise I am pretty happy.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Help with e85 oft - ltft is very high Neos Software Tuning 4 05-15-2018 06:25 AM
LTFT high/low? Sel_brz17 Software Tuning 3 05-08-2018 06:48 PM
Super High LTFT +36.77% at idle? (E85 with OFT tune) D4FD Software Tuning 11 09-05-2017 02:24 PM
LTFT reading oft mike7792 Software Tuning 1 02-01-2016 09:21 PM
high ltft at idle, my how to fix it(not fixed yet) trdric Software Tuning 16 06-18-2015 10:27 PM
