Old 09-09-2020, 06:34 AM   #1
Kris86
Kris86's Avatar
Drives: RHD Gt86
Help needed please, High negative short term fuel trims
Hey good day everyone,
I’ve been having A issue with my car running Rich with high negative STFT (-25/30%) while cruising, also unusually rich AFR’s (10.0/10.5) on initial deceleration
At WOT the cat runs normal Afr’s. Until recently starting to break up
This all started after I repaired a fuel leak from one of my gdi injectors, the leak was from the “o”ring at the top of the injector being pinched, repaired it without taking out the gdi injector. Ever since this repair I have generated the issue.
I’ve back check everything and can’t seem to find any vacuum leaks or errors I may have done while doing the fuel leak repair.
Now my car has been down for about three months now because I can’t seem to identify the cause of this issue. I’m hoping someone can help my diagnose. The car can start normally and drive but it “bogs” while cruising as it runs very rich (10.0 afr’s at times)
I changed my MAF sensor and my ignition coils to new DT ones hoping for a change for the better. I also noticed that my #2 plug is “wet” with fuel, seeing as I had 1 New GDI injector already, I went ahead and replaced the gdi injector for that cylinder thinking it may be stuck open, after doing all of that I still have the same symptoms.
Right now I am stuck and need you guys help
My car is fully built and turbocharged. I’ve driven my car around on this tune for about two years without issues, I spoke with my tuner and it is nothing easy for him to diagnose, he says if he had to guess, judging from the logs that it looks like something was changed, which isn’t the case, so I’m just trying to find the issue here.
Any suggestions?
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission
Kris86 is offline   Reply With Quote
Old 09-10-2020, 02:46 AM   #2
dholloway543
Software Hobbiest
Drives: 2015 FRS
Is your long term fuel trim +25/+30? because overall fuel time is STFT + LTFT.
If you changed the injector and the MAF sensor it might have different flow characteristics. So adjusting the tune might be the solution.
The only other thing I can think of is maybe your turbo is worn out. Can you freely spin it with your hand? it might be time for a rebuild.
Would you be kind to supply a datazap.me log it would help out alot.
dholloway543 is offline   Reply With Quote
The Following User Says Thank You to dholloway543 For This Useful Post:
Kris86 (09-10-2020)
Old 09-12-2020, 09:56 AM   #3
Kris86
Kris86's Avatar
Drives: RHD Gt86
here is a log with a WOT and a cruise with a small WOT, stopped midway through WOT because it started miss firing.
what would be causing my RPMS to be fluctuating like that?
https://datazap.me/u/kris86/wot?log=0&data=31
https://datazap.me/u/kris86/cruise-wot?log=0&data=31
this one is me at a stand still free revving
https://datazap.me/u/kris86/free-revving?log=0&data=31
The issue seems to be very intermittent, does not happen all the time. While going WOT the car started to miss fire in the higher rpms in one of the logs so I back off early through the pull
Old 09-12-2020, 10:51 AM   #4
Kris86
Kris86's Avatar
Drives: RHD Gt86
@steve99
would you have any assumptions?
Old 09-16-2020, 06:59 AM   #5
Kris86
Kris86's Avatar
Drives: RHD Gt86
Bump
Old 09-16-2020, 06:20 PM   #6
steve99
Drives: FT86
Originally Posted by Kris86 View Post
@steve99
Check the DI computer on side of motor has all mount bolts thrre of them installed and tight especially the lower hard to get one they provide ground to the di box.
if thats ok could be leaking injectors
log some idle when car warm no throttle jist let it idle and log for say 3 or four minutes
Kris86 (09-17-2020)
Old 09-17-2020, 07:01 AM   #7
Kris86
Kris86's Avatar
Drives: RHD Gt86
just back checked that the ECU is properly secured.
so went ahead and did the idle log before going to work for you
https://datazap.me/u/kris86/5min-idle?log=0&data=31
Also did another revving at stand still, you can see how rich it get every time I stab the throttle.
https://datazap.me/u/kris86/free-rev?log=0&data=31
your help is GREATLY appreciated.
Old 09-17-2020, 09:22 AM   #8
Kris86
Kris86's Avatar
Drives: RHD Gt86
Oh wait. Just realized you asked for a warm idle, my bad. I’ll do that when I go home for lunch
Old 09-17-2020, 05:13 PM   #9
steve99
Drives: FT86
manifold pressure is fine doesnt look like leaks
if you have already cleaned replaced maf then it looks like its could be aDI issue likely injectors leaking damaged seals
if it going rich amd high negitive trims means its over fueling
infortunatly you canmot rearly confirm leaking injectors from logs so its my best guess as other things look ok
it could possibly be leaking port injectors they are easier to get to so maybe check those first.
but DI seals are known issue
Kris86 (09-17-2020)
Old 09-17-2020, 05:42 PM   #10
Kris86
Kris86's Avatar
Drives: RHD Gt86
Thanks for taking the time out your day to assist. I’m going to go ahead with changing the port injectors and then see what happens from there, if nothing at that point then I’ll change the remaining three GDI injectors
Much respects again steve, always giving a helping hand
Old 11-18-2020, 05:52 AM   #11
Kris86
Kris86's Avatar
Drives: RHD Gt86
So I went ahead and installed some new identical injectors, but still having the same issue.
I’ve already recently replaced the following trying to find this issue :
New DT Ignition coils
New DW 900cc injectors
New o2 sensors
1 new GDI injector ( on plug that looked wet with fuel, others were ok)
I’ve done a compression test and a smoke leak test, all is well.
Any other suggestions?
Old 11-26-2020, 05:39 AM   #12
steve99
Drives: FT86
New o2 sensors
Check maf sensor is not dirty or oily, clean maf sensor. If runog speed density tune also check MaP sensor is reading correctly, should read 1 bar with engine off and ignition on
if runnog flex fuel check flex guage reading is same as that logged in ecutek
Kris86 (11-29-2020)
short term fuel trims high at idle and and partial throttle Minidude147 Software Tuning 5 03-28-2019 05:53 AM
Extremely jumpy short term fuel trims all of a sudden silverbullet Software Tuning 5 02-17-2016 04:31 PM
Negative Short term fuel trims at idle w/ no obvi leak IBill4You Forced Induction 21 05-29-2015 09:49 AM
Fuel Trims - Long term and short term victorb Engine, Exhaust, Transmission 6 03-27-2013 02:18 PM
Short Term and Long Term Fuel Trims naikaidriver Engine, Exhaust, Transmission 3 03-18-2013 09:55 PM
