go_a_way1, MisterSheep
Old 09-07-2020, 08:36 PM   #22303
Originally Posted by RToyo86 View Post
While leaving the cottage I heard a "tink" noise come from the left front, then I heard a metallic grinding noise.....
Maybe you outta fix that road back to your cottage? -
soundman98 (09-07-2020)
Old 09-07-2020, 08:44 PM   #22304
Stephen W.
Stephen W.'s Avatar
Drives: 1993 Caterham HPC Evo
While leaving the cottage I heard a "tink" noise come from the left front, then I heard a metallic grinding noise. It sounded like a rock touching the rotor, and would come and go based on brake pressure, steering angle.
Drove it home, took it apart and found that the hardware clip on the caliper was damaged. The clip bent which was causing it to rub against the venting on the rotor. Luckily I had a spare clip on the shelf, so I swapped it out
You were luckier than Vettel.
Old 09-09-2020, 12:22 AM   #22305
Cedric
Cedric's Avatar
Drives: 2013 Scion FR-S 10 Series
Wash
Sent from my iPhone using Tapatalk Pro
Cedric is offline   Reply With Quote
The Following 3 Users Say Thank You to Cedric For This Useful Post:
humfrz (09-09-2020), jflogerzi (09-09-2020), MJones_RB (09-09-2020)
Old 09-10-2020, 04:59 AM   #22306
Compelica
Compelica's Avatar
Drives: 86 GT
Finally took my car - and myself - to drive on track for the first time.
I had gone in without expectations, and being my first time I was fearing the worst with all the higher powered cars cutting me off several feet apart and pushing me out of the racing line, but I eventually got the hang of it. Lap times were way higher than the average 86 could attain but I was still learning to use all the brake and grip capacities I had.
All in all, it was great fun - can't wait to get back out there again.
Compelica is offline   Reply With Quote
The Following 8 Users Say Thank You to Compelica For This Useful Post:
Bobharp (09-14-2020), Cedric (09-10-2020), DarkSunrise (09-11-2020), Kaotic Lazagna (09-10-2020), MJones_RB (09-10-2020), new2subaru (09-10-2020), Quentin (09-11-2020), saltywetman (09-10-2020)
Old 09-10-2020, 06:40 PM   #22307
new2subaru
Weight Weenie
Drives: 15 FR-S
Toasted my first wheel bearing on track. Replacement comes tomorrow.
It sent a bunch of heat into the tire and expanded it to 43psi. Mangled it a bit. There was no noise or grinding. Even when off it was only slight.
The Following User Says Thank You to new2subaru For This Useful Post:
MJones_RB (09-11-2020)
Old 09-11-2020, 02:53 PM   #22308
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
How are your Whiteline sway bars holding up? Any clunking noises?
MJones_RB is offline   Reply With Quote
Old 09-11-2020, 05:43 PM   #22309
new2subaru
Weight Weenie
Drives: 15 FR-S
No noise or clunk on the front. I had a lot of noise on the rear, It sounded like spring bind added squeaking. I tightened/adjusted everything 3 times and it still wouldn't go away. I removed it a week ago and the noise is gone. Now I know it's the bar/end links for sure. I'll try to reinstall and see what happens :/
If I didn't like the setup so much I'd say screw it...
The wheel bearing is done and ready to squeeze in a few more track days!
Old 09-11-2020, 06:17 PM   #22310
MJones_RB
MJones_RB's Avatar
I have the same problem in the rear. At first I thought it was the weak stock mount for the sway bar so I installed Whiteline's mount brace, but that did nothing. It might be the end links binding on the lower control arm. I might try greasing them up real good and adding some slip washers. Good luck!
The Following User Says Thank You to MJones_RB For This Useful Post:
new2subaru (09-11-2020)
Old 09-11-2020, 09:59 PM   #22311
new2subaru
Weight Weenie
Drives: 15 FR-S
The weak stock mount was my next move lol I already greased the crap out of the bushings.
The holes in the sway bar are oversized and sloppy but I don't see how that could be making noise though. A guy at work suggested drilling it out and putting a collar in. I'll post if I find anything. Good luck to you too!
MJones_RB (09-12-2020)
Old 09-12-2020, 05:08 PM   #22312
MJones_RB
MJones_RB's Avatar
The wholes in the sway bar are oversized and sloppy but I don't see how that could be making noise though. A guy at work suggested drilling it out and putting a collar in. I'll post if I find anything. Good luck to you too!
Not sure what kind of lower control arm you have but I just have the SPC pressed metal ones. I'm thinking that the sway bar end links are too tight in there. I.m going to try to add some washers in there or, as a last result, get some billet control arms.
Old 09-12-2020, 09:26 PM   #22313
new2subaru
Weight Weenie
Drives: 15 FR-S
I have SPL and they're tight in those too. That could be the issue.
MJones_RB (09-14-2020)
Old 09-12-2020, 10:44 PM   #22314
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Got bored and suede wrapped my center console and HVAC side trim.
Why not?
The Following 5 Users Say Thank You to DarkPira7e For This Useful Post:
FLIPDADY (09-13-2020), humfrz (09-13-2020), MJones_RB (09-14-2020), new2subaru (09-13-2020), RToyo86 (09-13-2020)
Old 09-13-2020, 01:00 AM   #22315
Why not?
Welp, I can't tell from your pictures, but, I'm sure you did a good job -
DarkPira7e (09-13-2020)
Old 09-13-2020, 10:32 AM   #22316
DarkPira7e
DarkPira7e's Avatar
Thank you! It's Abit rough, but I'll make it nice. You never learn anything if you don't try
humfrz (09-13-2020)
