Old 09-08-2020, 04:51 PM   #15
stillslow93
Drives: 2015 BRZ JDL Turbo
I have the xt-ss in right now and have the exact same issue. Once the car is hot it will take upwards of 30 seconds of sitting on the clutch to slide into first or reverse...
Does yours sometime get stuck IN first or reverse when you are stopped? A couple times I've gotten into a parking spot only to find I'm stuck in gear. Based off what you have said we have the same problem and I'm not pointing fingers but ACT might need to buy some clutches back
stillslow93 is offline   Reply With Quote
Old 09-08-2020, 08:05 PM   #16
j_ros94
Drives: 2017 Subaru BRZ
I had this issue 2 nights ago when i was driving. I was stopped at a light and suddenly i cant go in any gear. It only happened twice. Is it the fluid? How do i check the tranny fluid in this car?
Thanks
Sent from my SM-G960W using Tapatalk
j_ros94 is offline   Reply With Quote
Old 09-08-2020, 08:29 PM   #17
churchx
churchx's Avatar
Drives: 2014 GT86
Stopped at light and suddenly cannot put into gear? I got exactly such issue two months ago.
Problem was reverse detent, that got worn (or moved? or misadjusted? (had few service work that included gearbox drop month before that)). Most probably if you don't push strongly to left, then you'll be able to slide into 1st or 2nd easily as before, you can try this as temporary fix. If you push lever to left strongly, due misadjusted (or worn) detent you would be able to put in gear only if you rise reverse-lockout .. but obviously that would mean that instead of 1st you get reverse (use this as test if your issue is same - if you can or cannot get into gear easily depending on how strong you push lever to side).
It really freaked me out, as i couldn't understand what was going on. In some cases i could easily put into gear, in some, 1st & 2nd was unusable, and had to start from stoplight in 3rd, dragging & wearing clutch a lot. It started midway during long drive and took me long time and several such fscked up starts at traffic lights, stops at parking to try find wtf is going on. I guess when i got even angrier i subconsciously tried to push even stronger to side, to get into 1st & 2nd "for sure", failing even more often, while with light gearswitches test when parked was fine. Long time and lot of wrecked nerves to notice pattern. Might been there even long before, but by coincidence not triggered until i pressed lever to side too strong, when wanted to put in 1st at that stop light.
For permanent fix, i brought it to dealership, voiced my observations and probable reason, and they fixed it. Though told me that detent looked rather worn, and readjustment will work for now, but if in future issue reappears, i should replace.
Old 09-09-2020, 01:11 AM   #18
Thanks
It's my understanding that there is a fill plug on the side of the transmission, take out the plug and stick your pinky in there to see if you can feel oil. If not, fill it up till it won't take no more, then replace the plug.
humfrz is online now   Reply With Quote
Old 09-09-2020, 10:44 AM   #19
j_ros94
Thank you
Old 09-09-2020, 10:45 AM   #20
j_ros94
The temporary fix works like a charm. Gonna have the adjustment checked out
Old 09-09-2020, 11:31 AM   #21
churchx
churchx's Avatar
Drives: 2014 GT86
Good, now with it knowing you'll be able to drive even if adjustment will be postponed to who knows when. And twice good, as it also with 90% probability pinpointed culprit, so less time wasted on diagnosing and dealership won't charge for unrelated things
To rest, this issue completely unrelated to most of thread, where issue most probable due not completely disengaging clutch drag, where it's for other gears switch too, and is common to that particular clutch.
Old 09-09-2020, 11:22 PM   #22
Moooiiissst
The moisture is real
Moooiiissst's Avatar
Drives: '15 WR Blue BRZ Limited 6spd
Yup, same issue here. I can also attest that I have an ACT SB7-HDSS clutch/flywheel combo kit that I purchased about 12k miles ago and I am experiencing the EXACT same issues as the OP - when my car is cold, it shifts like butter, but as soon as it heats up, it's like I'm trying to push through a very badly misaligned shift gate. I cringe every time I shift because I feel like I'm damaging my tranny, but it's the only way I can get around as this is my daily driver.
I've been trying to look into what it could possibly be and I, too, just recently replaced my clutch master cylinder in hopes that would help. Nope! Nothing. I have yet to replace the slave cylinder, but if I learned anything in this thread and other threads I have read through, it won't make a difference. It seems like the ACT clutch has to go.
Does anyone know if I can JUST replace the clutch or if I have to replace the flywheel as well since it was purchased as a combo kit as the one shown here: https://www.advancedclutch.com/produ...=p4019-c297715?
Also, is there a chance the synchros can be ruined by this? Or would they not be affected in the scenario explained by the OP? Not sure if they are completely independent systems in this case. I'd hate to have to do a whole transmission rebuild...
Moooiiissst is offline   Reply With Quote
Old 09-10-2020, 02:26 AM   #23
dholloway543
Software Hobbiest
Drives: 2015 FRS
This depends. If you buy another ACT clutch then no. If you buy a clutch that requires the stock flywheel then yes. It wasn't cheap from Subaru so maybe you can try picking up a used one from a junkyard or something and doing a resurface
I drove my ACT clutch for 6 months to a year before I could afford to replace it. During winter was the worst, there where times I had to just brute it into gear as there was traffic behind me. Plus I purposefully grinded the synchros a little to record it as posted in page 1 of the forum. I can say though that your synchros are probably not damaged as mine weren't. Remember trucks from 88 still have the stock synchros in them and are shifting fine to this day still through probably many bad drivers. You probably took a year or 2 off the synchros but nothing to worry about.
I do suggest getting a new clutch though, not only for the safety of the trans but also just for sanity.
dholloway543 is offline   Reply With Quote
Old 09-29-2020, 04:13 PM   #24
stillslow93
Did you get anywhere with this?
Old 09-29-2020, 04:54 PM   #25
j_ros94
So far just did a clutch adjustment and its fine. I'm waiting till when it gets cold.
Gear indicator not registering 5 th gear on 6mt sroby Engine, Exhaust, Transmission 20 03-18-2020 11:43 PM
Gear indicator (G-on) shows 2 when in 3rd gear c8Face BRZ First-Gen (2012+) — General Topics 31 07-07-2017 07:23 PM
Loud Hum/Grinding Noise + Vibration in 5-15mph gear range, in gear and rolling neutrl jakebrz Issues | Warranty | Recalls / TSB 14 06-06-2016 06:28 PM
Auto gear slippage on 2nd n 3rd gear shantha Scion FR-S / Toyota 86 GT86 General Forum 2 11-19-2015 07:26 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
