Drives: 2016 Scion FRS
Car not going into ANY gear
Hello guys,
I’ve been trying to find a solution to my issue but i cant find anyone with the same issue as me. I’ll drive my car fine for about 20 minutes, goes into every gear fine but after the 20 minute mark the car wont go into any gear. Aslong as the car is moving it’ll go into gear fine but when i fully stop it doesnt go into any gear. So far ive: - bled the clutch system - adjusted my clutch pedal - adjust the lockout bracket - now ive opened the transmission thinking i bent a fork (nope) The clutch i have on is the ACT HDSS stage 2 with a lighyweight flywheel. Brainstorm ideas with me! Thank you! |
Software Hobbiest
Drives: 2015 FRS
Sounds like an oil problem.
The 2 brands of transmission oil that ive tried in my car are Motul & Millers Motul is good but in colder climates its kinda crunchy going into gear Millers is a little easier to get into gear in colder climates but is a pain to get in north America. Both are good options. ACT is also known for not letting go of the flywheel entirely so its hard to put into gear sometimes. I had an ACT clutch with the same issue and did steel braided clutch cable, high temp clutch fluid, adjusted the clutch many times to get more throw, tried different trans oils. In the end the only thing that helped was to change the clutch. Now im running the Exedy stage 2 clutch and its holding power pretty good and feels closer to stock. Here is a video of when I had my ACT clutch and how it used to act. Turn volume up and you can hear that it slips the clutch even when fully pressed |
Famous Potatoes
Drives: '15 ultramarine
My clutch troubles magically went away when I got rid of the ACT clutch and flywheel.
Drives: 18 BRZ
I was not impressed with the ACT clutch I had on my STi. Switched to Exedy which was much better. For your issue have you confirmed you are getting full travel at the slave cylinder? You could also try taking the slave off and manually depressing the clutch fork.
Drives: Q5 + BRZ + M796
For me, the warmer the transmission gets, the better it shifts, so what you are describing is odd, so I tend to think it is a clutch problem and not a transmission problem. You seem to be locked out of gears because the clutch is not disengaging completely. Tell me this, at a stop in 1st gear, do you need to have your foot on the brake on a flat surface or the car will creep forward, even with the clutch pedal fully pressed in?
Maybe your clutch master or slave cylinder is shot?
#7 | |
Wheels for Brains
@hamish.frs
ACT clutch... doesn't go into any gear... does it when warm... I've heard about this a few times before. Probably clutch drag. Very common problem with ACT clutches. Mine did the same thing. Went back to OE and never had a problem since: https://www.ft86club.com/forums/showthread.php?t=128871 https://www.ft86club.com/forums/showthread.php?t=141791 https://www.ft86club.com/forums/showthread.php?t=137008 https://www.ft86club.com/forums/showthread.php?t=135661 |
Drives: 2014 GT86
If it's that common thing .. isn't it simply faulty design and product that should be recalled? It will just keep damaging longterm brand reputation instead of netting partial profit, if keeping selling so frequently failing one ..
#10 |
Software Hobbiest
Drives: 2015 FRS
Well the product might hold up to the performance that it suggests and In certain applications it might be your only choice for that price range. The next best thing that holds up like that is a dual plate clutch. So in a race environment where costs might play a big role and Street ability is not a huge concern it might be good enough but who knows what their view on the situation is. It culd be corporate looking at it and saying that enough people don't recall so their margin for profit is still high enough why change it.
#11 |
Why in the hell don't you folks just use the OEM clutch and quit hammering on it? -
![]() Yes, I'm talken to you folks tracking your cars - ![]() And, YES, I've tracked a lot of cars back in my day -
#12 | |
Rust bucket enthusiast
Some of us like to add power to the car to make up for our tiny peckers, and the stock clutch is only good for 6" and bigger- when you've only got 2" or 3" to work with, you.... You... Ok go take a nap, I'm sorry |
#13 | |
Having said that, yes, it is my nap time. It will be a good one since it's Sunday and I won't have the 4 ager kicking me in the back -
#14 |
Cannonball Record Guy
Drives: Series.Yellow, 4C, Fit
Had the same issues with my ACT SB7-HDSS. Even put in the Verus billet fork by a master tech and still experienced lockout issues after 5k miles.
FR-S ended up being a total loss and I started over with a '17 BRZ -- swore never to go near ACT products again.
| Gear indicator not registering 5 th gear on 6mt | sroby | Engine, Exhaust, Transmission | 20 | 03-18-2020 11:43 PM |
| Gear indicator (G-on) shows 2 when in 3rd gear | c8Face | BRZ First-Gen (2012+) — General Topics | 31 | 07-07-2017 07:23 PM |
| Loud Hum/Grinding Noise + Vibration in 5-15mph gear range, in gear and rolling neutrl | jakebrz | Issues | Warranty | Recalls / TSB | 14 | 06-06-2016 06:28 PM |
| Auto gear slippage on 2nd n 3rd gear | shantha | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 11-19-2015 07:26 PM |
| Reverse gear on the first and second gear side | randytindoggy | Scion FR-S / Toyota 86 GT86 General Forum | 50 | 01-29-2012 01:21 PM |
