Old 09-06-2020, 12:00 AM   #22289
jflogerzi
jflogerzi's Avatar
Added a front splitter. I hope this bumper will hold. This splitter adds some weight
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
MJones_RB (09-08-2020)
Old 09-06-2020, 12:25 AM   #22290
Cedric
Cedric's Avatar
Drives: 2013 Scion FR-S 10 Series
Originally Posted by DarkPira7e View Post
Where did you get that? I just made my own out of steel and some black fabric (steel so that it's magnetic for a phone or tablet mount). You can just barely see it, but I put a single DIN radio at the bottom
Toyota Part Number: 5552252020
It’s a radio cover for a Yaris. Fits perfect, but you need to glue it (or tape it) to the dash so it sits flush.
Sent from my iPhone using Tapatalk Pro
Cedric is offline   Reply With Quote
The Following User Says Thank You to Cedric For This Useful Post:
DarkPira7e (09-06-2020)
Old 09-06-2020, 02:18 PM   #22291
Ashikabi
Ashikabi's Avatar
Made a string rig so I can do my own alignments without tearing my hair out
Sent from my ONEPLUS A5010 using Tapatalk
The Following 3 Users Say Thank You to Ashikabi For This Useful Post:
humfrz (09-06-2020), new2subaru (09-06-2020), Ohio Enthusiast (09-06-2020)
Old 09-06-2020, 04:50 PM   #22292
hmmmmm - looks like something that Bubba would rig up -
Old 09-06-2020, 05:00 PM   #22293
Ashikabi
Ashikabi's Avatar
If it works, it works
The Following User Says Thank You to Ashikabi For This Useful Post:
humfrz (09-06-2020)
Old 09-06-2020, 06:22 PM   #22294
Ohio Enthusiast
Drives: 2018 BRZ
Could you share some more details? Perhaps even a DIY thread? I've been doing my own string box alignments and would be very interested in this.
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
humfrz (09-06-2020)
Old 09-06-2020, 06:26 PM   #22295
Well, Bubba does admit it looks pretty sophisticated, compared to his 7' piece of 1"x1" pine board with a nail in each end of it - plus a piece of chalk -
Old 09-06-2020, 06:28 PM   #22296
Don't ya'll have any alignment shops in the mid west? -
Old 09-06-2020, 06:57 PM   #22297
Ashikabi
Ashikabi's Avatar
I used 8 90 degree elbows and 4 Ts. 2pieces of PVC pipe at 10ft each. Came up with about 3ft left over.
54 inch pipe between the Ts. Clamp the Ts to the spats/splitter to keep the rig from twisting. I'm not sure how to go about doing this with no splitter or spats/diffuser. You'd need a different way to mount it.
Anyways, I just kinda eyeballed the whole thing. Should be plenty good to hold a string in place. Now I can make an adjustment drop and roll the car to settle it and jack it up again without resetting the string box. I left the ends unglued from the central pipes so I could apply tension or disassemble for storage.
Total cost was about 40$ with all fittings, glue, and 4 clamps
@humfrz I've gotten approximately 6 alignments (attempts anyways). No one I've tried to work with has been willing, capable, or both, of working on it. Now that I have the swap and it sits higher I might have better luck but I'm tired of settling for a shit product when they can't figure out how to adjust aftermarket parts. Or how to set camber beyond zero
The Following 2 Users Say Thank You to Ashikabi For This Useful Post:
humfrz (09-06-2020), Ohio Enthusiast (09-06-2020)
Old 09-06-2020, 08:16 PM   #22298
Welp, Brian, down at the corner garage, may be a nice guy, but, you may consider taking your car to an alignment shop closer in to the city -
Old 09-06-2020, 09:37 PM   #22299
Ashikabi
Ashikabi's Avatar
My problems have been in the city. Fucking plebs
humfrz (09-06-2020)
Old 09-06-2020, 11:02 PM   #22300
Welp, maybe alignment machines just won't adjust that far out to give you what you want -
Old 09-07-2020, 12:08 AM   #22301
Ashikabi
Ashikabi's Avatar
First problem is finding a rack that I can drive up on. Next is finding one that mounts the nodes on the wheels, not the tire (because tuck). Then, they still don't know what they are doing. I only had 4 degrees camber. No crazy stance
humfrz (09-07-2020)
Old 09-07-2020, 07:08 PM   #22302
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
While leaving the cottage I heard a "tink" noise come from the left front, then I heard a metallic grinding noise. It sounded like a rock touching the rotor, and would come and go based on brake pressure, steering angle.
Drove it home, took it apart and found that the hardware clip on the caliper was damaged. The clip bent which was causing it to rub against the venting on the rotor. Luckily I had a spare clip on the shelf, so I swapped it out
