Old 07-23-2012, 12:46 PM   #1
-max-
Drives: Firestorm FRS
Door Card Removal
Step by step removal of the door panel.
First there are 3 screws that need to be removed.
First is inside the door handle.
Second 2 are under the door pull handle.
So first you must pull off the trim piece that covers the screws. Start at the bottom.
The 2 screws are behind.
Last thing to remove is the clip in the upper forward door. Just use a flathead screwdriver to pop it out.
Now you just pull the door panel off. There are a bunch of clips inside and it takes quite a bit of force to get off.
Once you get it loose you will have to diconnect the cables that hook to the lock and door handle.
Last thing holding on are the wire plugs connected to power window and locks.
-max- is offline   Reply With Quote
The Following 17 Users Say Thank You to -max- For This Useful Post:
1strwdcar (12-09-2012), avusblue (11-28-2012), BRZranger (07-25-2012), Choco (01-21-2015), Dadhawk (02-09-2013), dangerfield (09-04-2012), DetroitJake (02-21-2014), Efferalgan (08-19-2013), encity5 (11-26-2012), GhostOp86 (04-04-2015), iniguez310 (05-24-2014), lordgrover (08-13-2014), mit_peid (04-07-2013), phenryiv1 (07-25-2012), Shad0ez (03-01-2014), Thefuzz (07-24-2012), willypongtb (04-24-2014)
Old 07-23-2012, 12:47 PM   #2
-max-
Reservered!
Old 07-24-2012, 04:03 PM   #3
phenryiv1
Drives: 2011 WRX
Do you mean the door panel?
phenryiv1 is offline   Reply With Quote
Old 07-24-2012, 06:58 PM   #4
|-Goku-|
|-Goku-|'s Avatar
Drives: 2011 Civic Si
Curious myself what this is referring to.
|-Goku-| is offline   Reply With Quote
Old 07-24-2012, 07:28 PM   #5
-max-
Yes door panel removal. I took pics. Just wondering if there was a thread up on it. Or anyone wants one.
Old 07-24-2012, 07:44 PM   #6
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
Post the pics, I'm interested in a write up
Sent from my Mind using Brainwaves
Flat Black VW is offline   Reply With Quote
Old 07-24-2012, 08:56 PM   #7
phenryiv1
Drives: 2011 WRX
I will gladly host your pics and mirror any writeup on my website, with your permission.
I will give you credit on the page.
Shoot me a PM if interested.
Old 07-24-2012, 09:12 PM   #8
-max-
Updated.
Phenryiv1, Use the pics wherever you like.
Old 07-24-2012, 10:07 PM   #9
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Thanks for the pics - why does it say door CARD removal instead of door panel? O.o
I've never heard of this terminology
Old 07-24-2012, 10:22 PM   #10
-max-
Form the other responses, I guess I'm the only one that calls them that.
Old 07-24-2012, 10:23 PM   #11
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
probably, I really have Never heard of Anyone call the panels cards :X
Old 07-24-2012, 10:32 PM   #12
phenryiv1
Drives: 2011 WRX
Door cards are typically a fabric or leather insert or inserts in the door panels. As some cars (older, in particular) had solid inner door skins with just a "card" to accent, I can see the confusion. In most modern cars, the whole inner cover is called the door panel and accent portions that are removable or re-coverable would be called door cards.
The Following 2 Users Say Thank You to phenryiv1 For This Useful Post:
Bonburner (07-24-2012), Monkey_Boy (07-26-2015)
Old 07-25-2012, 12:05 AM   #13
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
My BRZ didn't need those other two screws taken out, only the one. The rest just pop out. FR-S differs I guess?
michaelahess is offline   Reply With Quote
Old 07-25-2012, 06:48 AM   #14
-max-
They are screwed into nylon nuts in the door. If you pull hard enough they might come out. lol
Pillar Removal? kmbkk Electronics | Audio | NAV | Infotainment 2 07-12-2015 11:55 AM
Dent Removal 7thgear Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 10-23-2012 06:38 PM
Scion boost card? Mo707 Scion FR-S / Toyota 86 GT86 General Forum 30 08-01-2012 09:20 AM
Buying a car on credit card? SteelReign Other Vehicles & General Automotive Discussions 8 06-25-2012 12:54 AM
FR-S Badge Removal skoodge Cosmetic Modification (Interior/Exterior/Lighting) 0 05-31-2012 12:46 AM
