Old 09-02-2020, 11:30 PM   #43
vintagemxer
vintagemxer's Avatar
Drives: 2016 BRZ Limited
Originally Posted by Z06ZN6 View Post
I dynoed between 340-350rw on my e-force sc auto then made some exhaust mods and guessing around 360rw now. Torque is just over 250ftlbs. So far so good on the auto with only a temperature controlled trans cooler I pieced together. I used a Setrab 6-13 with an Improved Racing thermostat and some home made brackets and rivnuts. The car sees near bi-weekly uphill trips to the local and not so local mountains. Still shifts like it did naturally aspirated but since the revs climb much faster now in the lower gears, I do need to account for shift delay by shifting early to avoid hitting cutoff. Only time will tell how long this set up lasts, but autos are cheap and easily replaceable. I'll be doing some mods to the valvebody over the next few days cause I like to mess with stuff that aint broke .
Very clean set up, nice job Using the same thermostat, and cooler
vintagemxer is offline   Reply With Quote
Old 09-03-2020, 09:30 AM   #44
86TOYO2k17
Drives: 2017 toyota 86
I dynoed between 340-350rw on my e-force sc auto then made some exhaust mods and guessing around 360rw now. Torque is just over 250ftlbs. So far so good on the auto with only a temperature controlled trans cooler I pieced together. I used a Setrab 6-13 with an Improved Racing thermostat and some home made brackets and rivnuts. The car sees near bi-monthly uphill trips to the local and not so local mountains. Still shifts like it did naturally aspirated but since the revs climb much faster now in the lower gears, I do need to account for shift delay by shifting early to avoid hitting cutoff. Only time will tell how long this set up lasts, but autos are cheap and easily replaceable. I'll be doing some mods to the valvebody over the next few days cause I like to mess with stuff that aint broke .
the valve body will fix the need for early shifting. before i would shift about 400rpm early/before rev limiter after 150rpm early/before rev limiter. shifts are lightning fast and bite hard.
Old 09-03-2020, 09:31 AM   #45
86TOYO2k17
This was my setup. All my temps warmed up super fast in any weather, but stayed very cool once warmed up to operating. and the flip of a switch and you just watch the temps drop before your eyes even at a stop light.
https://www.ft86club.com/forums/show...69&postcount=4
Old 09-03-2020, 12:25 PM   #46
TSaanity
Drives: 2017 Fr-s
Question 350 HP on automatic?
Hello. What are the necessary mods needed to reach 350 HP on a automatic FR-S? Im about to buy a bunch of parts to help me reach this goal, and i live pretty near an E85 Station. Please list any mods needed to safely stay at this HP including valvebody, forged internals, fuel injectors, and such. Including reputable brands would help alot. Thank you so much. Please dont tell me to trade in my car, as im already set on my goal of 350 Hp.
TSaanity is offline   Reply With Quote
Old 09-03-2020, 12:50 PM   #47
86TOYO2k17
trans cooler
Valve body
Turbo kit
Flex Fuel + E85
Good Tune
Oil Cooler
Catch can
Enjoy!
really 230ft lbs to the wheels on a supercharger (roughly 300whp) or 240ft lbs to the wheels on a turbo (roughly 325whp) is pretty reliable on a stock block.
If doing a built block then its kind of pointless just for 30ish whp. you might as well shoot for 400whp with a built block or 325whp on stock block with a turbo+E85.
Old 09-03-2020, 12:56 PM   #48
TSaanity
Drives: 2017 Fr-s
Originally Posted by 86TOYO2k17 View Post
trans cooler
Valve body
Turbo kit
Flex Fuel + E85
Good Tune
Oil Cooler
Catch can
Enjoy!
Thank you. What turbo kit would you recommend? And once i get forged internals, would that kit be able to reach 400? (not sure if i want 400, but if i do id like the information)
Old 09-03-2020, 12:56 PM   #49
TSaanity
Drives: 2017 Fr-s
oh the bottom part didnt load, dont worry about my question didnt see the bottom of your post
Old 09-03-2020, 01:11 PM   #50
Z06ZN6
Drives: 2017 Toyota 86
Good to know there is hope, thanks. I am not doing the SSP valvebody at this point, just looking to poke around a bit, up the line pressure and fab some shims for the accumulator springs (from is-elite site). I wonder what else SSP does to their valve bodies that makes them so expensive? (rhetorical question).
Z06ZN6 is offline   Reply With Quote
Old 09-03-2020, 01:37 PM   #51
Z06ZN6
I recommend you get a bigger pump and injectors. I believe that was implied in 86Toyo2k17 response wrt to the e85 conversion. I use the dw300c pump and their 700cc injectors along with the Delicious tuning Flex fuel kit. Your tuner is a very critical part of making things survive.
With the SC or Turbo, it's very easy to reach your power goal and beyond but expect things can break even with the best of parts. Plan for the best but expect the worst. Read this forum to get an idea of what you are getting yourself into so you are mentally and financially prepared with whatever happens outside ones hopes.
Old 09-03-2020, 01:50 PM   #52
86TOYO2k17
Yeah guess i should have specified that. although pump isn't always necessary though depending at 325whp just injectors is probably fine, but much higher and pump would be required. I would just leave the necessary fueling upgrades to the tuners recommendations and go from there.
Old 09-03-2020, 01:56 PM   #53
86TOYO2k17
You can also change the line pressure in the tune. Not as good as a valve body but my tuner before the valve body was able to improve it from about 400-450rpm early no tune/vb, to about 275-300rpm with transmission tune, then i had him revert back to stock transmission tune when i installed the VB and it was 150-175rpm early. basically what it was when NA. Downshifts do sacrifice a little bit though with both the transmission tune and VB upgrade.
Old 09-03-2020, 02:05 PM   #54
86TOYO2k17
Depends on goals and budget. a lot of solid kits. Greddy, and Full blown or maybe even SBD have kits / turbo options that would most likely do what you want. Just do some google searches.
FT86club "insert any question you have" and tons of great info will pop up.
I think Full blown's kit can be very inclusive if you choose all the options and seems to have a good reputation on this platform. I would call or email them for proper turbo sizing based on needs/goals.
Old 09-03-2020, 03:17 PM   #55
Z06ZN6
Can you elaborate a bit on your experience with the sacrifices to downshifts? Thank you.
Old 09-03-2020, 03:51 PM   #56
CSG Mike
CSG Mike's Avatar
@TSaanity check out my FS thread to see what a reliable turbo setup looks like.
CSG Mike is online now   Reply With Quote
forged, help needed, turbo, turbo fr-s
No longer needed, mods please delete wheelsun Software Tuning 0 08-11-2016 02:17 AM
No longer needed, mods please delete wheelsun Want-To-Buy Requests 0 08-11-2016 01:11 AM
Turbo kit needed Cuztomizer Want-To-Buy Requests 0 11-30-2015 07:34 AM
Rocket Bunny V2 Bumper - Mods Needed? HachiRo Cosmetic Modification (Interior/Exterior/Lighting) 1 10-09-2015 11:33 PM
FA20CLUB turbo kit advice needed joedaniali Forced Induction 26 02-24-2014 01:25 PM
