Drives: '13 subaru brz
What parts would I need to completely replace entire suspension system?
I'd like to completely redo my suspension. I'm at 112,000 miles, it just seems so worn out, and from what I can see without lifting up the car, a lot of the suspension is rusted from winter driving.
Most likely I will go with the Bilstein B6 + RCE Yellow combo. Seems everyone is happy with this combo. Aside from Rear LCA & Front Camber bolts, what else would I need to grab to do this. Anything that might be worn I'd rather replace for peace of mind. |
#2 |
Drives: Scion FR-S 10 Series
I would recommend checking and replacing worn bushings.
| The Following User Says Thank You to Jdmjunkie For This Useful Post: | finch1750 (08-31-2020) |
#3 |
[insert cool phrase here]
Drives: BRZ Premium
All those mentioned plus ball joints.
Tie rods inner/outer if they look beat to hell.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#4 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
I would check sway bar bushings and end links for sure. Mine were both completely toast sometime before150k miles
| The Following User Says Thank You to finch1750 For This Useful Post: | norcalpb (09-01-2020) |
#5 |
Rust bucket enthusiast
Definitely look into the white line outrigger bushings for the diff! Quick and easy
#6 |
Thanks for the responses. Writing all this down to research a plan. What about the sway bar itself? Mine looks pretty rusted.
#8 |
That would be awesome!
I can take a pic in the next day or two. |
#9 |
A few other questions.
I see listings for B6's with and without blue boot. Is there a reason why there are two versions? Does it come with boot? If not is there an aftermarket one I can buy? Also, would anyone recommend any of the bushing kits? There's the Whiteline kit that comes with the camber bolt kit I'd need anyway. Worth getting anything else? |
#10 |
We get our Bilstein B6 direct from Bilstein....I'm guessing the different pics you're seeing are just people taking photos with the boots left off.
Post coming today! - Andrew |
#11 |
| Have to replace entire assembly to replace fuel filter? | tobkin | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 08-04-2017 03:26 PM |
| FS: Entire Exhaust System Need Gone! | 86Hiro | Engine, Exhaust, Bolt-Ons | 30 | 04-19-2016 11:19 AM |
| Replace entire OEM clutch assembly, or disc? | radroach | Engine, Exhaust, Transmission | 8 | 08-08-2014 12:00 AM |
| ENTIRE Audio System for Sale | DatDudeLoso | Exterior Parts (Aero, Lighting, Etc.) | 2 | 10-27-2013 09:24 PM |
| Entire Drivers Side Electrical Panel completely dead | Asphalt~86 | Issues | Warranty | Recalls / TSB | 13 | 11-14-2012 03:08 PM |
