Old 08-27-2020, 02:37 PM   #43
hifiguy99
Drives: 19' Toyota 86 TRD
Originally Posted by j_motion View Post
My is exactly the same with the new Perrin engine mount.
There are certain load at idle will make some not so pretty noice.
But once RMP is up it gose away.
I will put the car a bit more after getting tire alignment and see how they are through out the rpm range.
My new Perrin mounts also do the same. It sounds like metallic whine/chatter. Are yours doing the same still? I used german torque specs on mine so I think I am good with tightening it.
They do it the worst at exactly 2700 rpm, or around 50mph in 5th gear. They do it again albeit quieter at around 3300-3500. Its like a harmonic. At first I thought it was my header (ACE350) as I put the header on the same time as the engine mount. I can clearly hear the header rasp when accelerating but this is different. Its more audible with the windows up in the cabin, while the header rasp is more audible with the windows down.
I don't really care for it, it would just be good to know its coming from the mounts itself
hifiguy99 is offline   Reply With Quote
Old 08-27-2020, 02:45 PM   #44
Joveen
Joveen's Avatar
Drives: Bone stock
Its the mounts. They will give more NVH. Mounts also take a bit to break in. I honestly think after breakin they will still give some NVH.
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
The Following 2 Users Say Thank You to Joveen For This Useful Post:
DarkPira7e (08-27-2020), hifiguy99 (08-29-2020)
Old 08-27-2020, 06:12 PM   #45
86TOYO2k17
Drives: 2017 toyota 86
Sounds like header rubbing under tray, did you hammer it down for clearance?
Old 08-27-2020, 06:17 PM   #46
j_motion
Drives: 14 BRZ Red premium
Honest ...The only time notice the NVH is Cold start idle...
When is still not warmed up , idel at 550 to 600 rpm has very shaky klinky rattle ..I assum prob car running in Open loop trying to get up to temp and engine runs rougher as is not referencing to O2 sensor.
But once car is warm up ..the rattle is minimilized even at idel...
Yes you can still feel it but not the crazy Kling Klong Bam Bam jumpy engine.
Mabye I will get my tuner to bump my idel RPM up to around 650~700....
Pretty much at those rpm..the rattle is gone ...even when engine is cold.
I dont really have much resonance at any other rpm range.. (maybe i should drive more)
I even have the IRP shifter.....lucky for me..no rattle on that..
only thing that rattle in my car is my ebrake knob lol ...
j_motion is offline   Reply With Quote
The Following User Says Thank You to j_motion For This Useful Post:
Old 08-28-2020, 12:21 PM   #47
hifiguy99
Good to know the engine mounts aren't supposed to make a noise like mine lol.
I did hammer it down, and pretty aggressively at that. I will check for rubs the next time I am underneath the car, the whine doesn't bother me that much anyways this car makes a lot of weird noises as is. I will update this thread after a few thousand miles to see if the engine mounts "break in" and me checking for any rubs.
EDIT: Yes it was the header
The Following User Says Thank You to hifiguy99 For This Useful Post:
Joveen (08-28-2020)
Old 08-28-2020, 12:55 PM   #48
86TOYO2k17
Maybe exhaust leak. But sounds just like header rub. A weird highish pitch frequency that almost sounds like an exhaust leak but a little different and only happens in 1 or 2 very specific narrow rpm ranges.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
Old 08-29-2020, 05:06 PM   #49
hifiguy99
Okay well I took a video. The camera doesn't pick it up well but if you turn up your audio and ignore the drone you should hear the rubbing at the 4 second mark. It comes on and off depending on how much I press the gas pedal/engine load, as heard in the rest of the video.
Edit: On second thought, you might be right I may have forgot to hammer the other driver side of the tray. I am doubting myself now lol I will take a look when I have some time to spare. It does sound like header rubbing the more I look into it.
Old 09-07-2020, 06:36 PM   #50
Plumbus
Señor Member
Plumbus's Avatar
Drives: '17 BRZ PP
https://photos.app.goo.gl/2YuKjjY4iY3KEyty5
Hey brotha, have you looked into it yet? I have Ace a350 headers in a box waiting to be installed and looking for engine mounts to go with them. Would you recommend perrin or STI mounts?
Plumbus is offline   Reply With Quote
Old 09-07-2020, 06:45 PM   #51
Joveen
Joveen's Avatar
Drives: Bone stock
Ho Sti if worried about NVH
Old 09-07-2020, 08:45 PM   #52
Plumbus
Señor Member
Plumbus's Avatar
Drives: '17 BRZ PP
What did you end up getting Joveen? I seen you looking for mounts as well.
Old 09-07-2020, 09:36 PM   #53
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
He just called you a ho and you're going to ask him politely for advice?! Defend yourself!
Plumbus (09-08-2020)
Old 09-07-2020, 09:48 PM   #54
Plumbus
Señor Member
Plumbus's Avatar
Drives: '17 BRZ PP
We're all hoes up in this bitch I thought you knew
The Following User Says Thank You to Plumbus For This Useful Post:
DarkPira7e (09-07-2020)
Old 09-07-2020, 10:04 PM   #55
Joveen
Joveen's Avatar
Drives: Bone stock
Lmbo. I did not mean to put that obvious typo
DarkPira7e (09-08-2020), Plumbus (09-08-2020)
Old 09-08-2020, 01:32 PM   #56
doku
doku's Avatar
Drives: 2017 Subaru BRZ w/ Performance Pack
Was there any consensus on "Group-N" mounts existing for the BRZ? I only see different parts for the WRX.
2017 Subaru BRZ Performance Pack - Brembo Brakes - SACHs Dampers - Wedsport TC-105x 18x8.5 - Michelin Pilot Sport 4S 245/35 - STI Short Throw Shifter
doku is offline   Reply With Quote
Reliability concerns after major warranty engine repair? guanqi89 Engine, Exhaust, Transmission 10 07-10-2018 09:40 PM
Wtb frs/brz sti engine mount bartuc Want-To-Buy Requests 0 01-05-2018 06:17 PM
FS: Mtec Shift Springs / Perrin Support Mount / Perrin Shifter Mount andy86 Transmission and Driveline 6 05-25-2017 01:26 AM
Perrin Trans Mount and Perrin Shifter Bushing 00vsmcoupe Transmission and Driveline 1 03-09-2016 10:02 AM
sti engine mounts, oem engine/tranny mount, oem radiator sickmint79 Engine, Exhaust, Bolt-Ons 0 08-08-2015 03:15 PM
